Question about Maytag M7DH45B2A Dehumidifier
Can't find plastic casing for styrofoam floater.
  • judy828 Mar 11, 2009
    This part won't work for our dehumidifier because the bar that supports the float in the tank is about one quarter the size of the support bar use in our tank. Our tank is a 45 pint tank and the this is for a 30 pint tank.
    Problem Solver:
  • 10 Answers
Order today, they only have 18 in stock. Maytag does not make this anymore. I ordered 2 myself.
Posted on Mar 10, 2009
I thought the styrofoam inside the dehumidifier float was packing material & threw it away. Now my dehumidifier gets too full before the "full" sensor comes on. Can I replace the styrofoam?
Hi Kim - I understand that you removed the styrofoam inside the dehumidifier float thinking it was packing material, however I would recommend contacting the manufacturer to verify if it the part is available and can be replaced.
Sep 05, 2012 | Frigidaire FDL50R1 Dehumidifier
The float is broken
If all you need is the Styrofoam float, you're in business, If it's the entire float arm you're not so lucky.
See ref numbers
Sep 20, 2011 | Fedders A7DH45B2A Dehumidifier
My floater fell off the dehumidifier. Can I connect it back on?
If you are referring to the Styrofoam ball at the end of the float valve, you can if it's not cracked or water logged. Just be careful doing it. Also, make sure the float valve's shaft/arm is not broken off. If it is, you will need to replace the entire float valve assembly.
Hope this helps and thank for choosing FixYa.
Aug 25, 2011 | Dehumidifiers
I have a Maytag dehumidifier that needs a Styrofoam floater. It's an older model. Model number is m7dh45b2a
If all you need is the float bulb, you can find it at the following link. It's part number CRCFD5405-000
Hop this helps you. Please let me know. Thanks.
Jun 25, 2011 | Maytag Dehumidifiers
How do you put floater device back in water tank
It should just snap back into place, inside the small compartment in the top left of the water tank.
When you snap it back into place it should be able to move freely, up and down.
Hope this helps you.
May 09, 2011 | Maytag M3DH30B2A Dehumidifier
Do you know where I would be able to get the floater assembly for a Maytag Dehumidifier model #M3DH30B2A?
Is the picture of the unit here accurate? can you post an image of the broken part?
Oct 11, 2010 | Maytag M3DH30B2A Dehumidifier
Indicator says "tank full"
The switch is the most likely problem,check the switch with a multimeter
Apr 03, 2010 | Amana D545M Dehumidifier
Need water bucket and floater for Model m7dh45b2a cannot find replacement parts all that I need is a water bucket and floater
I have one that I just moved to my garage to junk out. My bucket and float is next to new. Email me at to hook up.
Aug 08, 2009 | Maytag M7DH65B2A Dehumidifier
Unit collects water but periodically continues running despite full bucket which is flush in unit, what could be causing this it doesn't happen everytime.
there is a floater switch on the machine over the bucket (and sometimes in it). the floater tells the machine that the bucket is full. if the floater is stuck, the machine will assume that the bucket is not yet full, and will continue to run. check that floater switch with the bucket out. you may need to press in the bucket switch so the machine thinks the bucket is in. then lift the floater and see if it stops running. if not, the switch is bad.
Jul 29, 2009 | LG LHD45EL Dehumidifier
Wont turn on
Check to see if the styrofoam float is in place correctly. Hopefully this fixes your problem. If the little plastic finger is broken on the float, then it will allways read full. At this point you could use the plastic tube that came with the owners manual to hook up a hose and then have it drain to a drain or try to super glue to finger back together. Here is a link to the tube that I was talking about.
Jan 18, 2009 | Maytag M7DH65B2A Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
232 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
