Question about Microsoft Windows Vista Ultimate Edition
I changed my display settings now screen is blank
Like i said ive changed my display settings while playing a game the next time i started pc up thereis nothing displaying on the screen its vista ultimate help me please
  • 320 Answers
What you need to do is, go to the safe mode with vga (press F8 after POST) and log in then you can change the settings of your graphic card in control panel. if you need assistance let me know
Posted on Mar 06, 2009
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
My display driver R3000 or w/e, messes up like everyone elses, but not while im on yourube..only while im on World Of Warcraft.. ive spent months trying to fix the problem..ive done everything i believe i...
It is possible that your VGA is malfunctioning. But you will notice it when the screen resolution is set to a specific resolution and color depth.
Games play at it's own resolution. Not at the resolution you set for Windows. Probably WoW is setting the screen resolution and color depth to a values at which the VGA fail.
Did you try changing the screen resolution in WoW options? If not try it. Also try changing color depth.
Also, download GPUZ and check your VGA.
Best of luck!
Aug 20, 2011 | Toshiba Satellite A135-S2276 Notebook
I have a samsung 920mw monitor.My problem is that i cannot change my refresh rate to 60 hz. Thus i am not able to play any games as a blank black screen ends up as soon as i start my game.
you change the refresh rate on the video card, go to Control Panel and Display, go into Advanced Setting and change the monitor setting from there
Jan 24, 2011 | Samsung SyncMaster 920NW Monitor
My screen blacks out when i am playing games or using vista
If a game you want to play is given control over your computer settings it may increase the screen settings and the computer may not be able to handle it and give a blank screen. What does it display on an external display?
Jan 01, 2011 | Acer Aspire 5610-4648 Notebook
Black Screen when playing 3D games on ATI Radeon 9550 X1050 Serie
the game resolution is not supported by your monitor....this is the reason your screen goes blank....
by the next time if the screen goes blank, press alt+ctrl+del together and check are you able to see the task manager....
if you can see the task manager, then close the game from that window by selecting end task....
if you cant see the task manager, then press ctrl+alt+del together 2 times and check....
if nothing works, then try by checking with any HD monitors if available with you or with your friends...
May 09, 2010 | ATI RADEON 9550 Graphic Card
Acer al1716 monitor input not supported
You get the message because the game try to run at the PC video resolution that you monitor cannot display/support. You need to run your game at native resolution of the monitor.
Mar 25, 2010 | Acer AL1716 17" LCD Monitor
My screen stays blank when I turn on. Lights blue and green come on but screen stays blue
If your display settings aren't set to automatic this can occur. Example: if you have set resolution to 1080i and are trying to play it on a display that has 1080p you will get a blank screen or no signal message. you will have to connect your PS3 to the last display you had an image on and change the "display setting" to "automatic" for your PS3 to work on all displays. when you choose a specific resolution to the "display settings" it will only work on that specific resolution. hope this helps.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Screen resolution changes to 800x600 after exiting a game
It sounds like you are playing an old game that cannot be run in the highest resolution your system could run in, therefore the game adjusts the screen resolution. To revert to your highest setting right click a blank area of the desktop, click personalize --- display settings -- and drag the resolution slider to the far right, as far as it can go. Of course when you start the game windows alert you that it is changing the resolution, you may click no to the change, but your game would be blurred. its one or the other. Choose!
Sep 30, 2009 | Microsoft Windows Vista Home Premium with...
Screen won`t display games.
  1. Re install Direct X new version on your laptop
  2. reduce or lower down the resolution settings of your screen. On desktop right click select properties and under the settings tab reduce your resolution to a lower setting like 600*800 and click on Ok an OK again and retry playing your game
  3. If it fails try restoring your computer to a previous date when you were still able to play the games. Start > all programs > accessories > systems tools > systems restore and click on the new window restore to and selct aday you remember you played the game well and resore to it.
Mar 24, 2008 | Fujitsu AMILO PC Laptops
Microsoft Windows Vista Ultimate Edition Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
