Question about Amana ARS266KB Side by Side Refrigerator
Amana Side by side ARS266KBW
ARS266KBW not getting water to ice maker. For a while there was too much water dripping in and it would make a big ***** in the back of the ice bucket. Now the water won't come through at all.
  • 700 Answers
The solinoid valve in the back of the refrigerator need to be replaced because it is leaking water through it when it is not suppose to.
Posted on Mar 07, 2009
Amana drs2663bw ice maker drips water into the back of the ice bin forming an ice build up
Make sure your refrigerator is level. also check that the ice maker inside the refrigerator is level after leveling the fridge.
Jul 20, 2012 | Amana ARS9266BS Side by Side Refrigerator
I have an amana side by side model # JXD2252L. The ice maker is adding too much water at the beginning of the cycle and is dripping water into th ice bucket. It freezes and casues the ice dispenser to...
Adjusting Ice Maker Fill
Use a flat-head screwdriver to remove the screws on the ice maker's front access panel, and then remove the panel.
  • Locate the adjustment screw, located about mid-point on the side of the ice maker. Do not turn the crew more than one full turn in either direction.
  • Turn the screw clockwise ½ turn to decrease the water fill level.
  • Turn the screw counterclockwise ½ turn to increase the water fill level.
  • Close the access panel and restore the screws. Turn the refrigerator back on.
  • bobicehouse_20.jpg Look at mid point for adjusting screw
    Jul 10, 2011 | Amana ACD2232HR Side by Side Refrigerator
    Water is dripping into ice recepticle and causing ice to freeze together. seems to be dripping near the front. the model number on my amana is DRS 246 2B or(RB) orDRS266312 those are the numbers on the...
    sounds like u have a bad ice maker or a bad water solenoid in the back of fridge just not shutting off all the way and letting water continiously drip into ice trap
    Feb 24, 2010 | Amana ASD2622HR Side by Side Refrigerator
    Ice maker overflowing
    If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
    If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
    Nov 16, 2009 | Amana SXD524VW Side by Side Refrigerator
    Outside ice despenser is dripping, no ice
    water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
    ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
    Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    Amana ARS2665AW side by side ice maker not filling
    Is the freezer cold enough? Should be close to 10 degrees.
    Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
    If it does dump the ice but don’t refill with water.
    Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
    The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
    Aug 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
    Amana side by side ice dispenser leaking water
    Take the ice maker out and look at the mold. If the coating is flaking off then that is where it is leaking. Will need to replace the ice maker.
    Sep 29, 2007 | Refrigerators
    Amana side by side
    if the unit has been runfor some time prior to connecting the water the fill tube may be frozen up, he solution is to turn off defrost overnight with door open and then turn back on, flush water through when turned back on to clear old water and air.
    Sep 02, 2007 | Amana ARS9266BS Side by Side Refrigerator
    Amana ARS266KB Side by Side Refrigerator Logo
    155 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
