Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 shuts down and won't turn on
I have an HP 7410 All in One, and it continully shuts down by itself, goes into what looks like a sleep mode first, then just turns off. When I press the "on" button, it won't start up. I switch the plug into a new outlet in my wall-mounted surge protector, and then it will boot up. When it happens again, I switch it back to the original outlet, and it boots up once again. I have 3 other devices plugged into this 6 outlet surge protector, and everything else works fine. Any ideas as to why this would happen and what a fix would be?
  • 14 Answers
Try this partial soltion; it's worked for nearly everone who's tried it. Unfortunantly, you lose your wireless capabilities, but at leat you're not left with a $500 paper weight:
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
(It's interesting that the majority of posts with this issue have occured on numerous sites during the last two months).
Posted on May 17, 2009
  • 101 Answers
Possible that one of three your electronic devices creates the electromagnetic hindrance in electric network. Try to manipulate of plugging some miscellaneous equipment to miscellaneous outlet. Sometimes meet the stabilizers of the voltage which do not manage with strong hindrance even.
Posted on Mar 07, 2009
I have an HP 2709m full lcd monitor and it shows osd lockout and I dont know how to unlock it. Ive tryed doing it with the menu with know help. I have to shut it down and then turn it back on and it works...
the manual say push the menu button for 10 seconds, and it unlocks.
sleep mode too go in and turn off power saver
its clock timer that and goes to sleep on time inside the monitor
why not read the manual costs nothing to read
at hp
http://h10032.www1.hp.com/ctg/Manual/c01725831
read page 25
and then read
page 27
amazing no, books, yah, books are so OLDSKOOL
Dec 31, 2017 | HP 2709M Monitor
Monitor going to sleep
juanmgerman0, Connect SDM-X82 to known-good pc that has all sleep mode, power-save mode disabled. (turned-off) If unit still goes to black screen mode, then look at the "date of Manufacture" on rear of unit and let me know if you see "2002 -2004" as the year produced. Retrevo lists unit as "time to retire". Power supply may be going into shut-down mode having detected a problem with itself or the CCFL inverter circuit. 12fixlouie
Aug 19, 2010 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
L1910 Monitor: goes to sleep when turned on...
It may have gone into shut down mode becuase it sensing problem. Try it on another PC, check VGA cable.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | HP L1910 Monitor
Monitor reading power lockout when try to shut off
the PC never turns off power to the monitor, it has its own power.
and sure, the monitors all do that 2004 to now. called VISA sleep.
modem has nothing to do with this.
Some monitors have this features called that.
its in your users manual. 2009m?
your page.
https://support.hp.com/us-en/product/hp-value-20-inch-displays/7274733/model/3884700/manuals
the words are clear.
it has power saver mode, turn that off
it has osd LOCK,
but no powerlock. as some do,. as your manual. shows.
page 24 shows.
quote, power button does this.
turns the monitor on and to standby or sleep mode.NOTE:
The power button is located on the top or front of the monitor depending on the model
off , on, and sleep.
my guess you are putting the power button i Sleep mode
a feature of this monitor.
Aug 24, 2017 | HP 2009M Monitor
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
My hp2009m monitor goes into sleep mode
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Feb 15, 2010 | HP Computers & Internet
LAPTOP WILL NOT COME OUT OF 'SLEEP' MODE
Turn it on, then wait, u will hear the computer turning itself on and off, but nothing is showing on the screen. so make it turn on and off, 3 time.( such as hearing the computer turned off, so that one,THEN IT TURNS ITSELF ON AGAIN, next time it turns off, that count as 2, and so on). on the third shut off then u press and hold the off button, to force it to shut down, then wait. about 5-10min., or less then 5. after then u turn the computer on.it should be on by now. if not try it again. if it happens again try one more time, if it happens again. then there something really wrong with your computer.
Jun 15, 2009 | Nikon COOLPIX L20 Digital Camera
HP 7410 shuts down
how long it takes before it shuts down,
answer quickly or else i'll forget helping you.
Mar 06, 2009 | Acer TravelMate 290 Notebook
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
HP OfficeJet 7410 All-In-One InkJet Printer Logo
402 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
