TV refuse to come on. Standby light blinks several times pause then blinks again and again. I heard a clicking sound as though its trying to startbus failed. This tv is only3.5 years old. What can I do?
I have the same problem except my tv doesnt turn on .. its a 1999 60 phillip magnavox rear projection screen. what can i do
Posted on Mar 06, 2009
  • martinezjd2l Mar 06, 2009
    where do i find the data plate on the tv or model number
KDF-60XBR950 Red light blinks 5 times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 01, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Was watching TV, heard a pop and the screeen went black. Now when I turn it on, the pwoer light blinks green but their is no picture or audio. The light then starts blinking red
Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info.
It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem.
Hope this will help.
Thanks.
Mar 09, 2011 | Sony KDS-50A2020 Television
Pressed power, heard the unit turn on, heard the tv show sound for a moment then it went into standby mode and the red light flashes six times, then pauses, six times then pauses, over and over and over. ...
Either your power supply is bad and needs replaced, or their is other circuitry issues. Bets to have a trained technician look at this and give you a quote for repair, it might be cheaper in the long run to replace the set.
Jan 18, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony KDL-46S5100 As the customer was watching it he heard a loud crackel sound and went dead. now all it does is click when I press the power button. No Bad Caps. Any suggestions? Thanks. Alltech TV Repair...
Let me know does power light is blinking on KDL-46S5100 tv front when it refuse to turn On?
If yes, how many times it is blinking as there would be 3 seconds long pause between blinks so count pause to pause and let me know to diagnose possible cause of problem and provide you its solution.
Thanks.
Nov 15, 2010 | Televison & Video
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony KV40XBR800 will not turn on. Standby light blinks 6 times.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • This sounds like you do indeed need a professional to repair it. Most shops charge a check- out fee to investigate. Horizontal problems are usually some of the more difficult to diagnose
  • Mar 12, 2009 | Sony Televison & Video
    Sony KV34XBR800 Red Flashing Standby Light No Power
    The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
    Tim
    Experttv@comcast.net
    Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
    Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
    This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
    It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
    Jerry G.
    Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
    Televison & Video Logo
    43 people viewed this question
    Top Televison & Video Experts
