Question about Dell 924 All-in-One InkJet Printer
Printer doesn't work form the computer to the printer
Printer doesn't work from the computer to the printer. Each can work seperatley but doesn't if I press print on my computer Dell all in one 966 PHOTO
    Scholar:
  • 53 Answers
You may want to uninstall and reinstall the printer. Be sure to use the Driver Install CD or download the latest from the manufacturers website.
Allow the computer to find and recognize the printer and prompt the install process.
Hope this helps...
Posted on Mar 07, 2009
GARO W1225
Merhaba,
make sure you download a copy f the latest driver and software for the printer form the Canon website and save them in a file titled "Canon" so you can easily find it again. Go into My Computer and open "printers". Click on the Canon and then "uninstall". This will remove it from your system. You will next need to go into "Programs" called Programs and Features in Win7. Highlight each Canon program one at a time and them select "remove". Reboot your computer and follow the installation instructions for your printer. In most cases, you will install the driver first, connect, and then turn "on" the printer. If everything looks ok, then begin installing the software. Reboot your PC and print a "Test Page" by going back into My Computer>Printer> select "canon" > properties> print test page If the page comes out ok, you're ready to go. If this doesn't work, call the Canon support telephone number for assistance. Good Luck
iyaksamlar
Oct 05, 2012 | Canon imagePROGRAF iPF9000 InkJet Printer
Custom size doesn''t present on your driver on Form to Tray Assigment in
Hi, I can't understand what "Custom size doesn''t present on your driver " means. the drver is just the piece of sofware used by windows to make your printer work. Custome size setting should have nothing to do with the driver.
Feb 23, 2008 | Epson LX-300 Matrix Printer
No web cam nor mic working
Please check on the voltage on the section concerned. If there is voltage then the connectors must be checked. Also the webcam and mic can be checked seperatley to confirm the fault on the monitor unit.
Jun 05, 2012 | AOC Computers & Internet
When I connect the printer esp5 to the computer it doesn't seem to recognize it, why?
remove the cable and insert again.if it doesn't work change the cable
Oct 29, 2011 | Kodak ESP 5 Printer
Hp compaq dc 7600 small form factor CMDS and check sum invalid
boot into safe mode and run CMD.exe and type in CHKDSK and run that program to fix any errors. If there still is a problem. Grab the CD in your computer came with and install it. What I mean by that, is insert a disk into CD-ROM drive. Before turning off computer. Turning on computer and booting from CD to fix any errors. If that doesn't work reinstall Windows. Please rate me for assisting you today have a great day. :-)
May 09, 2011 | HP dc7600 Small Form Factor P4 531...
Printer suddenly stopped working with quickbooks but will still work with all other programs. window states: change port assignments or reinstall software. printer is hooked up wirelessly
  1. Open the QuickBooks sample company and try to print the same form or type of form. If it prints successfully, your company data, form template, or customized report may be damaged.
  2. Reopen your company file and try to print an uncustomized (standard/default) form template or non-memorized report. If the issue occurs again, refer to Verifying and rebuilding the QuickBooks company data and then attempt to print again.
  3. If you were printing a batch of forms in QuickBooks, attempt to print a single form. If successful, try printing smaller batches.
  4. If you were able to print from QuickBooks in the past from this company file:
  5. Turn off the printer, restart your computer, and then turn the printer back on.
  6. In QuickBooks, choose File > Printer Setup and check the printer settings for the specific form you're trying to print.
  7. Click Help in this area for more detailed instructions on these settings.
  8. Ensure that you have the latest printer drivers for your printer. Go to the manufacturer's website to download and install the most current drivers.
  9. Replace the QuickBooks Qbprint.qbp file:
  10. Close QuickBooks.
  11. Rename the qbprint.qbp file.
  12. Open QuickBooks and attempt to print again.
  13. If the issue persists, repair the QuickBooks installation.
Mar 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
Computer can't communicate with printer
whatever be the OS, get into control panel, go to printers and see the printer that you are using is set as default,,, there would be a check mark on that printer icon,, if not make it default,, and try again, If you are using a usb cable connect the usb cable of the printer to the back usb ports and try,, use the printer driver disk that came with your computer, perform a reinstallation of the driver
Feb 05, 2009 | Lexmark X2470 All-In-One InkJet Printer
DatamaxI class 4208 top of form fault
The printer must be calibrated or the type of sensor is wrong. Verify that the sensor type is correct for your label (gap or black mark) and you can calibrate it by pressing the FEED key for about 5 seconds approximately.
Jun 22, 2008 | Datamax M-Class 4208 Thermal Label Printer
Not printing on last copy
My guess is it?s probably the print head. These things are designed to print on single sheets so even though it?s probably well within specs it still doesn?t have enough force to push an image to the last page. Less likely but never the less a possibility this could also be caused by inconsistent paper in the two boxes. Continuous feed, multi-part forms in a box are made by several manufacturers and have different characteristics. -You might try flipping the box of forms from the printer that works to the one that doesn?t just to make sure it?s not the forms. When I used to use multipart forms we would place orders for several boxes of the same form and occasionally some would be from a different manufacturer. The paper looked the same but the characteristics were way different. By the way we tried to do four-part but could never print beyond three part forms. Our fix was that we decided we only needed one in-house copy. -If the problem doesn?t follow the paper then I would suspect the print head. Panasonic print heads are fairly easy to replace and fairly inexpensive so I would try changing it out. With a lot of use the print heads do wear out so even if this doesn?t solve this problem you?ll have a spare when your vertical characters start looking wavy?. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 14, 2007 | Panasonic KX-P2023 Matrix Printer
Dell 924 All-in-One InkJet Printer Logo
66 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
