Question about Acer TravelMate 290 Notebook
HP 7410 shuts down
I have an HP 7410 All in One, and it continully shuts down by itself, goes into what looks like a sleep mode first, then just turns off. When I press the "on" button, it won't start up. I switch the plug into a new outlet in my wall-mounted surge protector, and then it will boot up. When it happens again, I switch it back to the original outlet, and it boots up once again. I have 3 other devices plugged into this 6 outlet surge protector, and everything else works fine. Any ideas as to why this would happen and what a fix would be?
  • dnappi Mar 07, 2009
    I would say about 12-15 hours. I've never actually timed it....just know it does take awhile. I'll use it one day, and it's usually down the next.
    Master:
  • 404 Answers
How long it takes before it shuts down,
answer quickly or else i'll forget helping you.
Posted on Mar 07, 2009
  • lotfi bouakaz
    lotfi bouakaz Mar 08, 2009
    Overheating
    Basically every computer and laptop has a processor inside
    That processor gets extremely hot when on however there
    Is a heat sink with fan which cools it at all times.
    Over the years dust builds up around the fan and heat sink
    And blocks the air vents preventing cool air from coming
    In and out. This causes the processor to overheat and
    The reason why it’s shutting is because your laptop
    Is doing so automatically to protect it.
    To sort this out, you should switch off your pc or laptop
    Remove the cover and access the heatsink and fan
    It will need to be cleaned with a brush or an air-can
    Properly and once this is done air should go in and
    Out easily without overheating.
    It is also recommended to add thermal paste
    To the top of the processor however
    You’ll need to remove the heat sink completely
    For that. Making sure it is applies 100% back
    On the processor.
    Overheating is serious and must be taken care of
    Asap. Here’s a link to a tool you can download and
    Install to monitor your computers temperature
    Download SpeedFan 4.37. free.
I have an HP 2709m full lcd monitor and it shows osd lockout and I dont know how to unlock it. Ive tryed doing it with the menu with know help. I have to shut it down and then turn it back on and it works...
the manual say push the menu button for 10 seconds, and it unlocks.
sleep mode too go in and turn off power saver
its clock timer that and goes to sleep on time inside the monitor
why not read the manual costs nothing to read
at hp
http://h10032.www1.hp.com/ctg/Manual/c01725831
read page 25
and then read
page 27
amazing no, books, yah, books are so OLDSKOOL
Dec 31, 2017 | HP 2709M Monitor
Monitor going to sleep
juanmgerman0, Connect SDM-X82 to known-good pc that has all sleep mode, power-save mode disabled. (turned-off) If unit still goes to black screen mode, then look at the "date of Manufacture" on rear of unit and let me know if you see "2002 -2004" as the year produced. Retrevo lists unit as "time to retire". Power supply may be going into shut-down mode having detected a problem with itself or the CCFL inverter circuit. 12fixlouie
Aug 19, 2010 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
L1910 Monitor: goes to sleep when turned on...
It may have gone into shut down mode becuase it sensing problem. Try it on another PC, check VGA cable.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | HP L1910 Monitor
Monitor reading power lockout when try to shut off
the PC never turns off power to the monitor, it has its own power.
and sure, the monitors all do that 2004 to now. called VISA sleep.
modem has nothing to do with this.
Some monitors have this features called that.
its in your users manual. 2009m?
your page.
https://support.hp.com/us-en/product/hp-value-20-inch-displays/7274733/model/3884700/manuals
the words are clear.
it has power saver mode, turn that off
it has osd LOCK,
but no powerlock. as some do,. as your manual. shows.
page 24 shows.
quote, power button does this.
turns the monitor on and to standby or sleep mode.NOTE:
The power button is located on the top or front of the monitor depending on the model
off , on, and sleep.
my guess you are putting the power button i Sleep mode
a feature of this monitor.
Aug 24, 2017 | HP 2009M Monitor
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
My hp2009m monitor goes into sleep mode
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Feb 15, 2010 | HP Computers & Internet
LAPTOP WILL NOT COME OUT OF 'SLEEP' MODE
Turn it on, then wait, u will hear the computer turning itself on and off, but nothing is showing on the screen. so make it turn on and off, 3 time.( such as hearing the computer turned off, so that one,THEN IT TURNS ITSELF ON AGAIN, next time it turns off, that count as 2, and so on). on the third shut off then u press and hold the off button, to force it to shut down, then wait. about 5-10min., or less then 5. after then u turn the computer on.it should be on by now. if not try it again. if it happens again try one more time, if it happens again. then there something really wrong with your computer.
Jun 15, 2009 | Nikon COOLPIX L20 Digital Camera
HP 7410 shuts down and won't turn on
Try this partial soltion; it's worked for nearly everone who's tried it. Unfortunantly, you lose your wireless capabilities, but at leat you're not left with a $500 paper weight:
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
(It's interesting that the majority of posts with this issue have occured on numerous sites during the last two months).
Mar 06, 2009 | HP OfficeJet 7410 All-In-One InkJet...
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Acer TravelMate 290 Notebook Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
