Question about HP Officejet Pro L7780 All-In-One InkJet Printer
I am having trouble setting up the fax for a HP L7780. The book says it needs a filter but when I hook it up to a line with a filter it still just rings and rings. The machine shows that a call is coming in but it doesn't answer. I have it on auto answer any ideas?
  • 62 Answers
Check where you have it pluged into the fax,
there is line and phone
plug into line
Posted on Mar 07, 2009
Partial print on incoming fax
Check your incoming line and settings or try to reinstall the drivers. Also, check the user manual for HP Officejet Pro L7780
Jun 25, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
L7780 is not receiving FAXE'S. Only Some of it ??
This is strange. Sounds like noise is in the line. Try searching the line for bad spots or replace the line. The ends could have corrosion on them also. The wires are most likely copper and the corrosion will be green. Check the box on the side of your house also. I would have the phone company check for noise in the line for you. Good luck.
Jul 21, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Our L7780 has a message saying phone off the hook. It doesn't have a phone! No faxes can come through, the phone rings, but doesn't pick up automatically as it used to.
Double check every phone that is on the same line, there is another device on the line that isn't hanged up properly and throwing things off.
Mar 28, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
My HP 7780 always says phone off hook. When I disconnect the phone line for awhile and reinstall it faxes once properly then the phone off hook message reappears.
I use a VOIP line and get the same error msg. Here's what I do- I dial the fax number with the line unplugged (hence no off-hook message), press "start Fax", and as soon as I hear the fax machine "Click" to pickup the line, I put the line in the machine. Works every time!
Oct 10, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
The fax will not answer even though I have it set to answer after 2 rings. It is on a dedicated line. Help!
There is a check box that must be checked in order to enable automatic answering.
Also, you have to have the phone line plugged into the Officejet machine
Oct 28, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
My fax machine is hooked to my main line, how do I keep my fax machine from picking up all my calls? Do I have to set my fax to more rings?
The only real solution is to have a different number/line for your fax or a special phone exchange.
If you're just having problems getting to the phone in time and you're not worried about people leaving voicemail you could increase the number of rings to the maximum but it will still intercept anything that hits that point.
Probably not what you were hoping to hear but unfortunately it's not a high powered system.
Hope it helps.
Oct 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Can't receive a fax
There are some settings that you need to change.
You need to turn off the following:
Error Correction Mode
Auto Reduction
to get to these options you need to go to the setup menu by pressing the setup button
then scroll to advanced fax settings and select it and you will find the options listed under it
You also need to check the fax speed under Advanced fax settings.
set it to medium.
hope this will help you :)
Aug 09, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
We have an HP L7780 and have problems rec. faxes - error 232
Hate to say it, but it means "Don't buy HP printers". You'll be a whole lot happier with Canon or Epson. I had no end of trouble with more than HP all-in-one. They just get flaky after awhile, and the software (particularly scanning) is terrible.
Apr 18, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
Slow Faxes
Slow faxes would have to do with the fax machine itself or the line quality of the line that is connect to this fax, noise on the line will do this and will also give error messages on the other end so check this..
May 21, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I want to fax using my HP OfficeJet Pro L7780. I
Click here for online manual and setup guides.
Clcik here to view DSL phone line setup instructions
& here for the general fax menu
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
59 people viewed this question
Ben Johnson
