Question about Samsung RS2534 Side by Side Refrigerator
Fregerator not cooling
The compressor running,but the fan in freezer is not and the coils frozen, and the refrigerator is not cooling "samsung side by side" I did this and the only light that flashes is the bottom right side of like a digital 8
8
8 8
8
8 8 8
It all lights up but this one stays on so whats wrong? It just cost me $91. for someone to tell me it might be something they will charge me $500 or more to fix
  • 700 Answers
Check out the refrierator defrost sensor for the refrigerator side. the connection may not be making a good contact. open up the refrigerator evap section and behind the lights for the crisper is the connections. be carefull because the evap may be frozen up and the styrofoam wil break if its frozen up. thaw it out first with a shop vac blowing air out.
Posted on Mar 07, 2009
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
Doesn't cool
Hi, Yes, If the evaporator was not frozen over then I agree with you. The unit has lost its refrigerant charge. The only thing you can do is to have a licensed refrigeration man find the leak, repair it and recharge it or replace the refrigerator. If the evaporator is frozen over the defrost timer would be the problem. In this case, manually defrost it and it will be good for a few days until you get it replaced. kstfas
Sep 27, 2007 | Viking VCSB483 Side by Side Refrigerator
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Freezer side of my RS2534WW Samsung is not working, fridge side is fine, evap coil fan is running,,, what could be wrong , it's only 7 years old
Your indications does not make sense! Your unit has ONE compressor that uses ONE evaporator coil to cool both sides. So if the FREEZER side is not cooling the fridge side should not cool either! Are you sure you don't have the freezer and refrigerator sides reversed?
Aug 14, 2011 | Samsung RS2534 Side by Side Refrigerator
Fridge coil is frozen but the fridge is not cold. Freezer coil is not frozen but freezer is cold. Icemaker doesn't produce ice and the water in the ice maker is not cold. What do you think?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
234tghj
Jun 12, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Samsung rs21dcsv not cooling displaying high temperatures evaporator fans running, but compressor not running
heatman101
Dec 01, 2009 | Samsung RS2534 Side by Side Refrigerator
Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Jul 07, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Freezer not working properly
heatman101
sdfaghsd
Jun 07, 2009 | Maytag MSD2655HE Side by Side Refrigerator
it can be fan defect or fan switch or timer as well as thermostat defect causing build-up of ice jamming the fan
Jan 30, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung RS2534 Side by Side Refrigerator Logo
242 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
