Question about Acer X193W LCD Monitor
Just bought an Acer AL2216WBD flat panel monitor. Have an old Dell computer; "Jewel Quest" game loaded. When I plugged in the new monitor, tried to play the game. Good sound but no picture. Only "input not supported" floating around. No menu to get out of the game; can only do so by pressing CTR ALT DEL. I am by no means computer literate! Is there an easy fix?
  • 558 Answers
The resolution is incorrect for that new monitor , it does not support it, attach the old monitor reduce the display resolution and then hook in the new monitor, up the resolution until it fails again and do nothing it will reset to the last good display resolution and you can leave it there.
hope this helps
Posted on Apr 05, 2009
Can't Install My JEWEL QUEST game .. need an
I am having this same problem, my mom bought it and asked me to install it. I now have it being installed. After the CD has been loaded, that notepad info will pop up. But thats because the AutoPlay is not working for some reason. Instead open up the CD in My Computer. Open the game folder and there will be a ".exe" setup file. Double Click that and it will begin installing the game. At least that worked for me so hopefully it does for you too! Good Luck!!
May 11, 2012 | Video Game Consoles & Games
How do i fix this hta file association problem so that i can install Jewel Quest Heritage Mysteries 2?
Jewel Quest Games notepad message hta incorrect. Steps 1. Insert CD a) If CD does not open, open manually via clicking onto your computer D drive. (start icon to computer icon) 2. Click files a) A list of files on the CD will appear on the D drive 3. Click Heritage Mysteries 2 (Same step for any other games) 4. Click setup (application) a)If you receive a message, asking you to turn off your virus protection, do not turn off your protection because the game(s) will still download correctly. 5. Game(s) will start downloading and you can play. Enjoy!!!!
May 08, 2012 | 2K Games Jewel Quest for Windows
I have been given a DELL8400 computer with a Acer AL506 monitor, when I turn it on a out of range message comes up, how do I fix this..
The Acer monitor was not likely used with that computer, they were just mated together.
Assuming the video card is the original Dell, Download the Dell video driver from Dell for that CPU that you have, and install it, use a different monitor if you have to load it. Try attaching the Acer monitor when that system is shut down, and boot up. It should see it as a plug and play monitor and then auto select the monitor settings. The old monitor setting is what was stored in the computer inf file.
With the driver installed it will match a driver to that monitor.
http://www.dell.com
If the card is not original Dell, then you need that video card's driver installation file. You may need to resort to doing a search for the first part of the data on the DB15 header if there is no clear manufacturer tag with number on the card itself. Such will be the case with some Nvidia cards made for other vendors like AOpen.
Then you can right click "Properties" and select the screen resolution you want.
it is more critical to have the video card driver than the monitor, however the Acer driver may have some features that are not accessed by the Dell driver.
Jan 27, 2012 | Acer AL506 (Ivory) 15 in. Flat Panel LCD...
Jewel Quest 3 game will not show video, just sound. Used to work but suddenly quit showing video.
Could be driver needs updating for your video card on your pc or change the resolution of your screen
May 06, 2011 | 2K Games Jewel Quest for Windows
In same games as Jewel Quest 3 the monitor give this message the single over rang
Signal OVER RANGE?
Monitor unable to cope with the frequency the computer is sending (for want of a better explaination.
Boot the computer to VGA mode and adjust the display settings, or boot to safe mode
Jan 04, 2011 | GNR 19M1 19" LCD Monitor
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
Acer AL2216Wbd blurry
get it checked that a problem with the monitor also check it on another monitor if you can
Nov 20, 2017 | Acer 19" LCD Monitor
Acer X193W LCD Monitor Logo
251 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
