Question about Lexmark X85 All-In-One InkJet Printer
Lexmark x85 paper jamming on right side
I Need a technical or service manual to remove the rollers and troubleshoot.  Can you tell me where I can find one or if you can tell me the steps to remove and clean the rollers?
Thanks, Mickey
    Problem Solver:
  • 8 Answers
Go here and download the manual you need..
http://support.lexmark.com/perl/support/support.cgi?ccs=227:5:0:0:0:0
Rgds,
Geoff
Posted on Apr 06, 2009
I have a lexmark x85 printer that is misbehaving. Weather I try to copy or print from the computer,t will not feed properly. The unit feeds about half way and then the printer heads start to move as if it...
You simply need to find a way to clean the inside of the printer, especially the rollers of dust. I will explain.
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. Sometime one side grips well and tries to pick the paper while the other doesn't resulting in a jammed. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Jul 30, 2011 | Lexmark X85 All-In-One InkJet Printer
I have Lexmark x85printer. Bought new Ink Cartages. Printer Will not Feed Paper All I get is paper jam Clear paper
Either the ink cartridges are incorrectly inserted, and block the paper path jamming the paper, or the paper drive roller got slightly out of kilter when replacing the ink. Sometimes, powering down the printer, manually moving (gently) the printer head halfway from home position, closing the printer and powering it on will clear a roller problem (never tried on a Lexmark, though. It works on Epsons and HPs). If the head doesn't move, though, don't force it. Try instead taking out the ink cartridges and putting them in again, without forcing, and gently wiggling them until they click in place.
If you get the message without any paper in the printer, check the insides for any scrap of paper which could have lodged in the sensors.
Also, verify there is no paper elsewhere in the paper run (paper out tray, etc.). Sometimes the "paper jam" message is a sort of "catch-all" error.
Nov 04, 2009 | Lexmark X85 All-In-One InkJet Printer
Lexmark x6170 paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
May 01, 2009 | Lexmark X6170 All-In-One InkJet Printer
My Printer won't print
If the problem repeats then there is the problem with rollers you may need get it replaced if its within warranty or get it serviced .......
Good luck...
Nov 25, 2008 | Lexmark X5495 Printer
Lexmark X2250 uneven paper feed
Oct 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
LEXMARK 3500 4500
Jun 10, 2008 | Lexmark All-in-One Printer with PictBridge
Lexmark X4850 paper jam
May 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X2470 Jam
IF this did mot work ,Please contact Lexmark as they sent you refurbished printer which may defective roller on it , ask them to send a good printer this time..............
Mar 22, 2008 | Lexmark X2470 All-In-One InkJet Printer
Paper only being taken in on one side.
In some printers there is a roller which can be removed. Once the roller is removed it should be possible to remove any thing which would prevent the roller pulling the paper through evenly.
Feb 23, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X85 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
