Question about Enermax (by Coolergiant) EG495P-VE SFMA V2.0(24P) Noisetaker Series 485W ATX Power Supply ATX 12 Ver... (CSPSEMEG495P) Power Supply
Power supply , small plug hook up?
Hi, I bought a power supply , an Enermax EG495P-VE 24pin ,SFCA ATX , 12V, VER 2.0 There is a fan type plug,it's brown with 3 small holes in it and there are 2 wires attached to it . One on each side and nothing in the middle. One wire is white and the other one is black with a white stripe down the side. Does anyone know what it's for and where to hook it up to? I have an Asus motherboard Model #M2N68-AM. Thanks, Ron .
  • 34 Answers
That plug is for the fan RPM monitor, it is not needed for normal operation.
Posted on Mar 06, 2009
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Where can I find a schematic diagram fot Enermax EG465P-VE ATX
You can't found any diagram for and specific ATX PSU
but there are some generics
Dec 01, 2012 | Computers & Internet
What fuse is in a Enermax EG495P-VE Noisetaker 485W Power Supply
Just buy a new power supply. If you touch the wrong thing inside that psu you will die. Seriously.
Aug 15, 2012 | Enermax (by Coolergiant) EG495P-VE SFMA...
My computer will not power up at all been looking for another compatible power supply since this one is discontinued need help immediately.. enermax eg425p-ve
I'd check into a DiabloTek PHD650 650-Watt Power Supply. It's a higher voltage module, but has similar features to your Enermax power supply. If you can't find it locally, check out (my fave) or These two sites are likely to have these, and are competitively priced.
Aug 31, 2010 | Enermax Noisetaker EG425P-VE...
I installed the Corsair Professional HX650W 650W and it didn't po
make sure the switch on the back of the PSU in switched to I not O. If thats not it check the largest connector, the atx connector.
Apr 02, 2010 | Computers & Internet
Enermax EG495P-VE (Off warranty) will run for 1 sec to 1 min and then shut down. No volts to 12/5/3.3. For the brief time that it stays on it supplies the correct volts under load. Is there a overload...
It's probably an accumulation of lint, dust, pollen, and anything else in the air over time, if you're lucky. This isn't the easiest of things to do, but you will have to use a small brush for a lot of clingy stuff, to compressed air for most cases. It could be a slight short in the fan motors, or a bad electrical connection or connector that's causing the current to rise and trip a thermister, or other heat sensing device. I would take it apart and see what I could see. Most of the time it's something simple, never know till you look.
One thing...if you do find an overload switch or circuit, figure out the problem that's making it overload. It's probably not the switch that's bad, but something else. Good luck!
Mar 27, 2010 | Enermax EG495P-SFMA24P Very Quiet...
I am looking for a wiring diagram for my emachine front power switch
Power Supply Types
There are two basic types of power supplies. There are AT power supplies, which are older and in older computers, and ATX power supplies, which you will find in virtually every new computer you can buy.
There are two fundamental differences between AT and ATX power supplies. First, the switch mechanism is different. AT power supplies use a normal on-off switch, which directly turns the power supply on or off.
ATX power supplies use a momentary switch which does not directly control the power. Instead, the switch signals the motherboard, which performs one of three actions:
  • If the computer is off, the power supply is turned on (which turns the computer on)
  • If the computer is on, the computer goes into power-saving mode (standby)
  • If the switch is held for more than 4 seconds, the power is cut and the computer turns off.
Because of this difference, ATX power supplies are better for projects that require the second power supply to turn on automatically when the computer is turned on.
The second difference is in the motherboard connector: AT power supplies provide two 6-pin connectors (figure 1), which are easy to insert backwards. The ATX connector is a single 20-pin connector that only plugs in one way (figure 2).
Figures 1 and 2: The difference between AT (left) and ATX (right) motherboard connectors.
Both power supplies provide two types connectors for plugging devices into. These connectors are called Molex connectors, and they come in two sizes (see figure 3 and 4). A power supply will generally have a few of each size.
Figures 3 and 4: Large (left) and small (right) Molex connectors.
There is no difference between the two sizes other than the size itself. Both sizes provide the same amount of power to whatever device is plugged into it (12V and 5V). The small Molex connectors are generally used only for floppy drives. Large Molex connectors power hard drives, CD/DVD drives, and many fans and lights as well.
Note: You can purchase large and small Y-adapters if you run out of Molex connectors. Be careful when using the Y-adapters however, because if your power supply does not have enough power for all the devices attached (especially true for older, lower-wattage supplies), you can damage it.
Dec 03, 2009 | E-Machines eMachines Desktop PC
I have an old e machine 500 (origional operating system was windows 98). I am replacing the ATX switching power supply , 230 wat, model lp6100a. My problem is connecting it. I know all the connectors...
The old AT power supply that these old computers uses has two six pin socket connectors and these are different to the ATX connector.
You cannot buy these power supply now, most likely you might find one/computer in a junk shop.
If you have electronic knowledge you might be able to cut off the connectors from the old power supply and connect it to the ATX power supply and modify the ATX power supply so you can switch on the power to the old computer. The old AT power supply uses a mains power switch whereas the ATX uses low voltage to turn on the power supply.
Good luck & have fun.
Nov 29, 2008 | Powmax 400 Watt ATX Switching Power Supply...
No power to 12 volt, Hard drive, or Disk drives.
Retrace your steps there may be a loose wire(s). Have you checked and rechecked your pinouts? maybe one of the wires is backwards. Hate when that happens. It could be bad out of box. Try unhooking everything then one by one rehook your components. Maybe by terrible coinsidence a part fried and is preventing the machine from booting. Make sure your CPU fan is plugged in. I am installing a new motherboard now and those are the pitfalls I keep track of.
Mar 08, 2007 | Enermax (by Coolergiant) ELT400AWT Liberty...
Computers & Internet Logo
263 people viewed this question
Top Enermax Computers & Internet Experts
David Payne
David Payne
Are you an Enermax Computer and Internet Expert? Answer questions, earn points and help others
