Question about Symbol LS 4000i Handheld
How to install the LS4006I-I100 series?
I down loaded the 123scan.exe program and I still cant get it to read my barcodes.
123scan - leanguage problem
there are bar codes for the country you are in underneth programing bar codes 3rd one down in the 3rd colom
if this helps you out pleazse take a moment to rate this. anything else i could assist you with?
Jan 14, 2013 | Symbol DS9808-SR00007NNWR - Motorola...
Bar code not working
sounds like a scan engine failure. I can arrange for a repair if you contact me:
Nov 21, 2011 | Symbol LS4000: LS4006i
I need to strip the last character from the barcode when scanned with a Symbol P370 scanner. Is there a procedure for that?
If the barcode is a UPC-A or UPC-E you would scan the Do Not Transmit UPC-A or UPC-E Check Digit barcode from the P370 Product Reference Guide.
If the barcode is something other than a UPC-A or UPC-E the last character can be stripped using Advanced Data Formatting which would require the use of 123Scan. You can download 123Scan from
The P370 is NOT supported by the newer 123Scan2.
Jan 21, 2011 | Symbol P370 Wireless Barcode Scanner
I am trying to find the software installation file for a 123scan LS4071-I1US
OK try this trick . take any product lets say a tissue box and scan the barcode and see if it show the same problem?
if it is the same try to clean the scanner until we figure out something else.
if it reads it full the n the printed barcode are the damaged ones.
May 11, 2010 | Symbol LS 4071 Handheld
I have a new LS4278. I need to congigure it to read fedex barcode
All you have to do is create a rule to transmit only the 12 digits you want.
You can create a rule with the Programming manual or the 123scan software.
Both of these are available online at Here is a short cut:
if you need additional assistance please let me know - Thank you, Kim Ganoe 800.933.2839 x251
Mar 05, 2010 | Zebra LS4278 Cordless Bar Code Reader...
Symbol LS 4000-I100 to a PC Help connecting
That depends on your exact model, it could be USB, Keyboard Wedge, or RS-232. In any case, you just plug it in and turn it on.
Oct 15, 2009 | Symbol PN: LS4000-I100 Laser Scanner...
Barcode reader language
Concerning the Z issue you should select german keyboard from 123scan
Else you will have to program macro to substitute the caracters
Sep 03, 2009 | Symbol LS2208-7AZK0100S Handheld
Handheld Symbol LS4000-I100 barcode reader
you need to use the code book (the programmers book) to configure the reader, you need to tell it how to communicate with the PC (bit rate, stop bits etc....)
this code book should have come with the reader...
this book has barcodes on many pages and also configures the types of barcodes that the scanner can read....
if you do not have the code book you can download it from the maufacturers website
Jul 08, 2008 | Symbol PN: LS4000-I100 Laser Scanner...
Part of code
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS? I would like to recommend you to used visual basic 6.0 for better outcome.
Hope you like my solution please rate me Solved.
best regards,
Nov 02, 2007 | Symbol LS2208-1AZU0300S Handheld
123Scan File
P370 WILL NOT connect with your terminal or base, so forget about this intent and go for the goal which is loading your programming to your scanner. According to Motorola the work around is simple and faster than trying to resolve this.
Start with Reseting the scanner completly back to Defaults.
In the 123Scan, PRINT Barcodes and the rules ADF Rules of your programming.
Start scanning from
"Parameter Settings" until the last page barcode "Reset Scanner".
That is it. Problem solved.
You will need to do this for every new programming Rule.
Nov 18, 2006 | Symbol P370 Handheld
Symbol LS 4000i Handheld Logo
1,171 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
