Question about Polaroid i733LP Digital Camera
My camera won't turn on and the lens won't go back in
I have tried getting new batteries
i hold the power button and nothing
the batteries are in the right way
and i have recharged all of them and none of them work
HELP!
"My camera won't turn on and the lens won't go back in"
  • 10,594 Answers
Check battery terminals that should be shiny and does not have any corrosion.
If still camera does not power up then it has some problem on circuit board (power supply section) then take it to local camera repair shop for proper fix.
Posted on Mar 06, 2009
  • Polaroid Master
  • 13,433 Answers
The lens seems stuck the gears are possibly broken, most likely just stuck, try slaping the camera on the sides top bottom back, everything else but the lens. You may carefully try helping the lens to move.
Does the lens attempt to move inside or outside?
How is warranty?
'Kodak AF 3x Optical Aspheric Lens' won't turn on ...
Hello Bernard, There seems to be a lot of this going around !! Possible bad battery contacts or a faulty main switch. you will need to have it looked at by a tech.
Best Regards, Russell
Dec 24, 2012 | Kodak Easyshare C813 Digital Camera
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
Camera is stuck with lens out and won't turn on or
If this camera takes ordinary batteries you may have inserted them the wrong way around.
If it takes a rechargeable pack recharge it for average time recommended and try again.
Sep 20, 2011 | Sony Cameras
Lumix digital camera lens won't open all the way. I live in Orange county Califonia. Please give me a place to get it repaired it might be the battery charger. Help need telephone number...
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Sep 16, 2011 | Cameras
Dropped my camera and now the lens won't retract back in. When I press on the screen says lens error M425-12 (7f80). Can this be fixed and should I take it to a camera repair shop? Thanks
It could be one of two things, you bend the lens when dropped or the pins in the lens has become loose and are stuck.
You can try:
Taking the battery out for about 5 minutes and putting it back in to reset the camera. Also you can try hold the power button down and the ok or select button to to reset it. Also can hold the power and the menu button to try and force the lens out to dislodge the pins. If not,
The funny the is that I would have you drop it again on a carpet but on the opposite side to see if you can dislodge the pins from being stuck, try and have it land flat on its back from a decent height.
If the lens in bent you will have to bring it to a repair shop to have it fixed but it usually costs as much as a new camera.
Sep 06, 2011 | HP Photosmart M425 Digital Camera
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
Error message: "Lens error, restart camera" unable to get it to work Have powered on & off several times. Also removed batteries and powered on several times all to no avail.
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 01, 2010 | Canon PowerShot A560 Digital Camera
Power on n off
sounds like a battery power problem or problem with the terminal of the camera ; you know the point where the battery meets the camera.
I would recommend a service center
May 31, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
M527
my camera lens doesnt work every time i turn it on the screen stays on and then the lens error: M527-22 error comes up can you help me
thanks
Feb 25, 2008 | HP Photosmart M527 Digital Camera
Polaroid i733LP Digital Camera Logo
26 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
