Question about Compaq Computers & Internet
My compaq presario MV730i color monitor will turn on from hibernation mode and then turn off when the computer is turned on. Any ideas what I can do to correct this issue? Can not afford new monitor.
I heated the monitor up with a heating blanket and a space heater. then reconnected to the computer. turned computer on and the monitor worked.
Posted on Mar 07, 2009
Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Feb 12, 2010 | HP Compaq Presario SR2010NX PC Desktop
Monitor is off and the white hibernation mode flashing
Turn off your pc and unplug the monitor from the power source wait 1 minute then plug it back in and reboot your pc.
Jan 12, 2010 | HP Compaq Presario V2000 Notebook
HAVE A COMPAQ MODEL SR2177CL IF THE SCREEN HIBERNATES IT WILL NOT RESPOND HAVE TO POWER THE SYSTEM ON/OFF WILL WORK FINE TILL IT HIB. AGAIN PLEASE HELP
Attempt to turn off hibernation mode in the Windows Power Options.
Start > Control Panel > Power Options
Find the Hibernation option and change it to Never.
This way, the laptop will go to sleep, but not hibernate and store data to the hard disk.
Nov 25, 2009 | Compaq Presario F572US Notebook PC
My Compaq presario f572us notebook screen turns black upon normal startup. The screen does not turn black if I start-up in the safe mode. It only when i attempt to start windows normally. Everything loads...
i also have a compaq presario f572us that's been having similar problems. when i went onto the hp website i saw that apparently they've been having similar problems with this type of computer as they offer free repairs for 2 years after you bought it. you should probably check if this works for you too
Oct 23, 2009 | Compaq Presario F572US Notebook PC
Re move hibernation mode
press the power button for ten to twelve secons and it should reset
Mar 24, 2009 | HP Compaq Presario V2000 Notebook
Compaq presario C300 stuck in hibernate mode
Try unplugging from the a/c adaptor, and removing the battery for a couple of minutes. Replace the battery and turn the computer on. It should be fixed now.
Mar 14, 2009 | HP Pavilion dv6000z Notebook
New compaq
check your devices make sure no errors
control panel display scrennsaver hardware
set harddrive and monitor time to shutdown
set sleep or standby to never
then remove check from hibernate
also look in advance at top and check your settings
Jan 22, 2009 | Compaq Presario C700T Notebook
Monitor malfunction, says VGA Input: No Signal and goes to sleep
If it was your video card, you would have no picture at all. Try to boot in safe mode and do into your options and make sure your hibernation is not on. Only other thing I can think of, it could be *********** board.
Nov 29, 2008 | HP Compaq Presario SR2011WM PC Desktop
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
CRT Monitor-Compaq presario VM700
Hi Snandy, I absolutely despise monitor and computer sleep or hibernation modes. Before I started routinely disabling this on all the computers I supported my users were always having problems no matter how computer literate they were. I know this sounds simplistic and you may have already done it but have you just unplugged the monitor? If that doesn?t work maybe the PC itself has gone to sleep as well. Try moving the mouse, hitting a keyboard key. If that doesn?t work try pushing the power button on the computer to turn it on. If all else fails pull the power plug on the computer itself, plug back in and it should start up. I would suggest disabling all of this via Windows Power settings in the control panel. Let us know if you have any other questions and again please don?t forget to rate the post.
Feb 02, 2007 | Compaq V700 17" CRT Monitor
Computers & Internet Logo
275 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
