Question about Acer Power FG (APFGUP5161) PC Desktop
Is there a bios for the acer motherboard E915GV M3 that will allow voltage and frequency adjustment?
  • 404 Answers
Posted on Mar 06, 2009
How to tweak your computer
Step 1
Back up important files. This includes impotant datas stored on your computer
Step 2
Update the firmware of your computers BIOS. Also update or patch your OS to the lates update and even your hardware devices must be updated as well.
Step 3
Also before proceeding ,remember to get a BENCHMARK test program that will help you see the changes and also monitor the temp. of your processor after overclocking
Make sure that your BIOS is also set to shutdown once illegal voltage or temp. will be detected
Step 4
Ensure that the CPU FAN is clean and is still calibrated to the right rpm
Step 5
Power on your unit ,hit the hotkey to access setup.On the BIOS go to ADV. CHIPSET option.Then look for"clocks, "frequency/voltage control" or "voltage options." This will look unique on each brand of computer.You can overclock by modifying "CPU bus frequency" or "CPU FSB frequency." Increase this value slightly. In some cases, you will be able to increase your "CPU multiplier" through the BIOS.If your BIOS has none of these options,your motherboard is not capable of overclocking the processor.
Step 6
You can also try overclocking your MEMORY AND VIDEO speed. Some motherboards have this options on the BIOS as well
Step 7
You can consult your motherboards manual to know the operating voltage of your cpu or type in the model of the board on yahoo or google.
on Dec 19, 2009 | Computers & Internet
How to adjust jumper settings of ecs mainboard mcp61m-m3
onbly jumpers on that board should be for bios cmos clear. the cpu setting snd such are to be adjusted inside the bios setup utility.
Mar 09, 2011 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
I have an ECS gf7100pvt-m3 motherboard. The
Reset the CMOS on the board (remove the battery for about 5 minutes) and restart. Press 'Delete' (or the required key to enter the Bios) to re-configure the board options.
Oct 02, 2009 | EliteGroup Lga 775 GF7100PVT-M3/MCP73T-M3...
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Jun 20, 2009 | EliteGroup ECS P4IBMS Socket 478pins...
Overclocking a CPU Type Intel Pentium IIIE, 581 MHz
If you have an adjustment for the VCORE voltage in your bios, bring it up by one value, then try overclocking the CPU.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
Error Message on 1st page boot up
Hi Chris,
Reset the bios jumper on the board. Use your manual, go to the bottom of page 9. Please unplug the power cord from the PC.
Clear the cmos/ bios & remove the bios battery as well. (You may use a small flat tip screw driver to help lift the battery out). If you have a voltage meter check the battery for 3volts DC. (If you have a voltage meter suggest you check the battery for 3volts DC while its out).
Re-place the bios battery & reset the bios jumper back to Normal. Re-connect the power cord to the PC. Boot the system & enter the bios menu. Adjust all your setting as needed.
(DO Not over-clock anything)!
If you still receive an error message your only other option would be to flash the bios. Even if you have the latest bios software already installed. The current bios software may be corrupt.
Good luck Chris!
Nov 06, 2008 | EliteGroup RS482-M754 Motherboard
ACER 180 (AMD 64 3800+) upgrade
any amd 64 will work. bios should be ok if you stay with just the amd 64 if this is a aspire t180 then you might want to go to a 64x2 which you will have to flash the bios. hope this helps
Aspire T180 Language
English Model
Aspire T180 Specifications Specifications
AMD AM2 Athlon 64 x 2 or Athlon 64 or Sempron (940 pin)
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Yes you can. Any DDRII RAM can function at 1.8v.
Every memory module has profiles written into it, this allows it to function at various speeds and voltages, and 1.8v is the default voltage for DDRII.
Voltages above 1.8v are used for overclocking, to take full advantage of high speed DDRII memory you should manually set the voltage and frequency in your motherboards BIOS (accessed by pressing DEL or F1 during boot), if your motherboard does not have options to set these parameters manualy then your memory will function at the default speed and voltage
Hope this helps!
Oct 02, 2008 | Intel Motherboard
Can not upgade memory from 2G to 4G
have you checked the frequency of the new ram you are using if its not of the same type and of same frequency as of the another one your system wont boot
Sep 14, 2008 | Acer Aspire™ T180 PC Desktop
Acer Power FG (APFGUP5161) PC Desktop Logo
206 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
