Question about Black & Decker Black Decker Dualtemp Soldering Craft Iron CI500S
Tips are corroding & disappearing
I've been using the B&D soldering iron, and after a little while, I noticed that my tip was getting smaller and smaller - I think it's corroding away. It's now down to a little nub. What am I doing wrong?
I clean off the tip on a moistened paper towel, and I tried to cover the tip in solder before putting it away, but it won't always stick.
I use this for crafting, and use lead-free solder, and been using different types of flux. I also typically have the iron on for about 1-2 hours at a time, if that's significant.
Thanks for any help!
  • stellardoor Apr 28, 2009
    I am getting holes in the tip of my soldering gun and have ruined 2 tips! I use filtered water on a sponge to clean the tip but it has been getting a rusty corrosive build-up. I suspect there something in the water that might be doing this and will try bottled water next. I am using DGS Lead-Free Solder. Have you ever heard of this problem before?
  • 226 Answers
That is normal for a soldering gun especially if you are using acid core solder. I do a lot of soldering with rosin core & have to change the tip about every 6-8 months. Just get a couple of new tips. Rick
Posted on Apr 11, 2009
  • 122 Answers
Do not overheat the tip!try to adjust the temperature at 390c maximum for leaded solder or 410c max for lead free.if your gun is not automatic try to push the trigger as needs for soldering not continuously!try a cadmium type tip those tips are better tha the nickeltips!
Posted on Jun 13, 2010
Do stained glass soldering tips go bad or stop working. I have a weller soldering iron that doesn't heat up hot enough to solder. is it the tip or the iron
If this is the dual trigger Weller gun and your tips are held in place by either set screws or by locking nuts, Just loosen both of the parts that are holding the tip to the gun and then retighten them back up. Soldering iron tips that appear to be tight might not be and this will insure that the tip is indeed tight and also cleans up the connection of the tip to the soldering iron. Oxidation from heating and cooling will cause a tip to not get very hot. Loosen the tip holder and then retighten it. Hope this gets you going again.
Dennis
Apr 15, 2017 | Weller Welding Tools
After a few minutes of use, my WESD51 read out goes up to 902F but the tip is actually very cool (like 350F - 400F). If I put a load on the tip, it straightens out for a while, goes back to the set temp....
I was searching this and accidentally found the answer. Just for future reference, the issue with mine was the contacts between the station and the tip, where you have to lock it. Wiggling it would get rid of the error, so I looked at the contacts (the pins that go into it) and sure enough they were mildly corroded. I brushed them off a little bit and it worked fine. If I get a new tip, I'd look into something that prevents rust, possibly WD-40, to prolong the life.
Sep 04, 2011 | Weller Wesd51 Digital Soldering Iron...
Whats the little cup thing on top of the battery in a iso-tip soldering iron and is it glued on to that black thing with wires on or soldered ?
The cup thing allows thermal transfer to black thing which when gets hot trips switch adding resisters lowering charge current to trickle not to overcharge battery. Then red led lights, and is reset by pushing white slide towards bottom base. It is not glued it is pressure fit on bottom of black thermal switch and has a little thermal grease like heat sink compound. Should come apart if you pull hard enough maybe need to use pliers.
Mar 20, 2011 | Wahl Soldering Iron, Iso - Tip 60,...
I have a weller wp35, 35 watt iron. It came with the ST3 tip. I want to solder automotive wire, Say 14 to 20 gauge wire. Two questions: 1 is the wp35 strong/hot enough to do this type of soldering? 2...
The WP35 is strong enough and the ST3 tip will do the job. The larger tips are really only for covering larger items but when soldering it's the wire you heat, rather than the solder, and melt the solder with the wire. The tip will reach the same temperature regardless of the size and while the larger tip might heat the wire a little faster the difference would not even be noticeable.
Jan 30, 2011 | Welding Tools
I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Jul 11, 2010 | Weller Welding Tools
Does not melt solder
The body contains a transformer, which steps your 120AC down to a lower voltage. The lower voltage runs THROUGH the tip, heating it up. Possibility ONE: Transformer is no good, throw it away. TWO: Not enough current is running through tip, because tip is corroded OR those mounting nuts are corroded, loose, OR somebody put new tip into nuts but neglected to bend both legs of new tip 90 degrees. Look at the barrels, you will see little holes in the sides, tip's legs go into those holes.
Mar 15, 2010 | Weller 8200 Soldering Gun
Tinning tips
Flux the tip, heat the iron, apply solder all over the tip and wipe, while hot, the solder off with fine steel wool.
If the solder is flux core, no need for additional flux
Good Luck
Jan 27, 2009 | Weller SP175 12 - 1/2'' Marksman Extra...
No longer melts solder with tip....
You have burned out residue on the tip. Clead it off with a damp cloth when the iron is hot. If this doesn't get it all, use steel wool. Immediately afterwards, get flux & solder onto the tip or it will get coated again.
Jan 24, 2009 | Weller BP860MP Dual Heat Battery Powered...
Soldering iron troubleshooting
Bits: It's useful to have a small selection of manufacturer's bits (soldering iron tips) available with different diameters or shapes, which can be changed depending on the type of work in hand. You'll probably find that you become accustomed to, and work best with, a particular shape of tip. Often, tips are iron-coated to preserve their life, or they may be bright-plated instead. Copper tips are seldom seen these days.
Aug 27, 2008 | Cooper Industries Weller Soldering Iron,...
Black & Decker Black Decker Dualtemp Soldering Craft Iron CI500S Logo
247 people viewed this question
Top Black & Decker Welding Tools Experts
Bill Boyd
Are you a Black & Decker Welding Tool Expert? Answer questions, earn points and help others
