Question about Cell Phones
Koycrea ostyr cell phone does not ring when i receive a call...when I go to adjust the ringtoone volume in the settings or on the side of the phone where there is a rubber slider control....the phone shuts down and has to be restarted
  • nodot Mar 06, 2009
    is there any way I can get the to access the ringtone volume as it is two years old and out of warranty
    otherwise...i am inclined to throw it out and get another phone
  • nodot Mar 07, 2009
    thanks
  • 11,896 Answers
If the phone shuts off when you try to control volume, two things are causing the problem, low battery or firmaware/software errors.  You can try to go to settings, phone settings, sounds and ringtones, and adjust sound volumes.  If your phone shuts off again, than I would replace it.  It would cost as much to fix as would be to replace.
Posted on Mar 06, 2009
  • 6,784 Answers
This is internal software and hardware failure. you will need to send back to the manufacturer or take to your provider for a complete rebuild. this phone will need another main board and software.
  • Cell Phones Master
  • 13,433 Answers
Sounds like a hardware fault. Is your phone still covered by warranty? if it is, would be best to use that.
The phone seems to have a hardware fault that causes it to down. This will need repairs and diagnostics at a professional.
  • 4,472 Answers
How long have you owned the phone? It sounds like the phone is defective so bring it into your nearest cell dealer, and inquire about repair/replacement. if you still need assistance let me know.
Thank you,
Lee
  • Lee A.
    Lee A. Mar 06, 2009
    No there really isn't. The way technology works these days it is most likely your best bet just to replace it. If you need further assistance let me know. Also please take a moment to re-rate my solution accordingly.
    Thank you,
    Lee
  • Lee A.
    Lee A. Mar 07, 2009
    I am not sure the difference in the solution you accepted and rated fixya over my solution that was given first and is the same thing if not giving you better instructions on what to do. Not sure the reason for the rating. If you would like to correct your rating please let me know.
    Thanks,
    Lee
What is the code to increase the volume of Samsung C3010
Hi
By volume do you mean Ring tone volume or Handset volume?
Ring tone volume adjustments.
Press menu >settings >phone profiles
Scroll the phone profile you ares using.
Press on options >edit and select call alert volume.
Scroll right or left to adjust the volume levels.
press on select and then save.
The handset volume adjust is done by pressing on the 1st side key in idle mode.
Feb 27, 2012 | Samsung Cell Phones
No sound can't hear on phone and no ring on phone
Hi Wilma,Remove the cell's battery and then reload it again.Check user profile settings and make sure 'Silent's not the selected option.Select 'General' and then customize the settings increasing tone volumes.Make a call and after the person on the other end receives it,press on the ^ up navigation key to adjust the speaker volume.Problem solved?If not,your phone's speaker may need repair or possible changing.Have it fixed in a repair shop.
Hope this helps.Thanks!Please rate this answer.
Dec 13, 2011 | LG Cell Phones
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
Samsung Convoy cell phone will not ring in. screen shows bell with a red hash through it.
try the volume button on the side. the red bell means u have it on mute. otherwise find the profiles settings im using a rugby and they are in settings, profiles and adjust your ring volume in there
Jan 17, 2011 | Samsung Convoy Cell Phone
The ringer of my phone is off. How do I turn it on?
flip open your phone -then increase volume with side ^ button...this toggles ringer on/off
no need to go into phone settings...
Aug 05, 2010 | Cell Phones
No ring when phone call is received
Hello. Most likely the ring has been turned off. The volume adjustment setting goes from loud to soft to vibrate only and finally to no ring and no vibrate. The volume key is on the outside of the phone on the right hand edge.
Regards, Joe PS - kindly rate my answer as helpful. thank you.
Feb 18, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
My sony erisson mobile ringing volume low how can increase
go to menu,ringtone settings,then go to ringtone volume and adjust it according to ur need,u can use side buttons for this also.
Dec 05, 2009 | Sony Ericsson w580i Cellular Phone
How to disable side volume key
1. In Idle mode, enter an
area code and phone
Press [ / ] to adjust the
volume.
During a call, the
exposed keys are locked.
Press [Centre] to unlock
the keypad.
To change the sound profile:
1. In Idle mode, press
[Centre] and select
Settings → Phone
profiles.
2. Select the profile you
Jan 25, 2009 | Samsung SGH-U700 Cellular Phone
Motorazr v8
Go to settings
Choose sound profile
press right key to go to alert tab
choose playback volume
Jul 03, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
