Question about HP LaserJet 1500 Printer
Cant instal this ink cartridge
Theres an orange pull tab on the side of my ink cartridge (36A) pulled it out cause it wouldn't go in the printer anf theres a tape with ink attached the old one dosent have this?
    New Friend:
  • 52 Answers
This pull tab is on the cartridge to prevent it from leaking during shipment. You have to remove it to let the toner get to the drum.
Posted on Mar 06, 2009
How do I a new install an ink cartridge?
No, you do not remove the orange device. there should be tabs on the front of that to push or pull. that will unseat the cartridge and you can then remove it by hand and replace.
Feb 21, 2015 | HP 564 XL Series Ink Cartridge Set for...
6510 Model. How do I change the in k cartridges
Step one: Open the All-in-One
  1. Press the Power button ( ) to turn on the product, if it
    is not already on.
  2. Open the cartridge-access door. The carriage moves
    to the center of the product. Wait until the carriage stops moving before
    proceeding.
    Figure 1: Open the cartridge-access
    door
Step two: Replace the old cartridge
  1. Press in the tab on the front of the cartridge,
    and then pull it out and up to remove it from its slot.
    Figure 2: Remove the cartridge from its
    slot
    CAUTION:Do not lift the gray latch next to the
    carriage to install the cartridges. Doing so can result in incorrectly seated
    ink cartridges and printing problems. The latch must remain down to correctly
    install the ink cartridges.
  2. On the replacement cartridge, pull the orange
    pull-tab straight back to remove the plastic wrap.
    Figure 3: Remove the plastic wrap
  3. Twist the orange cap counterclockwise to snap it
    off the cartridge.
    Figure 4: Remove the orange cap
  4. With the cartridge contacts facing the printhead,
    slide the cartridge into the correct slot. The color-coded icons on the
    cartridge and in the printhead indicate the correct slot.
    Figure 5: Insert the ink cartridge
  5. Press down on the ink cartridge until it clicks
    firmly into place.
    Figure 6: Press the cartridge into place
  6. Repeat these steps for each cartridge that you want
    to replace.
  7. Close the cartridge access door. The carriage moves
    to the right side of the product.
Aug 19, 2013 | HP Officejet 6500 Wireless All-in-One...
U150 error on canon mx885
Solution 1:
  • Open the paper output tray.
  • Turn on the printer and open the scanning unit. The printer cartridge carriage will move to the center. Open the inner cover securing the cartridge in place by pulling it downward.
  • Press the tab on the problematic ink cartridge and lift it to remove it from the printer. You will be able to tell which ink cartridge is causing the problem because its indicator light will be off or flashing.
  • Open the replacement ink cartridge and pull the orange tape in the direction of the arrow to remove the protective film. Tear the orange tape off along the dotted line.
  • Place the ink cartridges into the printer and press where indicated on the cartridge until it clicks into place. Ensure that all ink cartridges have a red indicator light showing that they are properly installed.
  • Close the inner cover on the cartridge carriage and the scanning unit. The printer will automatically start a print head cleaning cycle. When the cleaning cycle is complete, the printer is ready to use.
Solution 2:
  • Put the little green circuit board from the old ink cartridge of the same color in the new cartridge.
Apr 17, 2012 | Canon Office Equipment & Supplies
Would like instructions for installation of new ink cartridge in 6500A printer
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube Step one: Open the All-in-One
  1. Press the Power button (c01602202.gif ) to turn on the product, if it is not already on.
  2. Open the cartridge-access door. The carriage moves to the center of the product. Wait until the carriage stops moving before proceeding. Figure 1: Open the cartridge-access doorc01638336.gif
  1. Press in the tab on the front of the cartridge, and then pull it out and up to remove it from its slot. Figure 2: Remove the cartridge from its slotc01495178.gif
    CAUTION: Do not lift the gray latch next to the carriage to install the cartridges. Doing so can result in incorrectly seated ink cartridges and printing problems. The latch must remain down to correctly install the ink cartridges.
  2. On the replacement cartridge, pull the orange pull-tab straight back to remove the plastic wrap. Figure 3: Remove the plastic wrap c01493650.gif
  3. Twist the orange cap counterclockwise to snap it off the cartridge. Figure 4: Remove the orange cap c01495123.gif
  4. With the cartridge contacts facing the printhead, slide the cartridge into the correct slot. The color-coded icons on the cartridge and in the printhead indicate the correct slot. Figure 5: Insert the ink cartridge c01493652.gif
  5. Press down on the ink cartridge until it clicks firmly into place. Figure 6: Press the cartridge into place c01493653.gif
  6. Repeat these steps for each cartridge that you want to replace.
  7. Close the cartridge access door. The carriage moves to the right side of the product.
Jul 27, 2011 | HP Officejet 6500 Wireless All-in-One...
Hi! I just changed my print cartridge (HP LaserJet- C7115X, ink 15x) and the printing quality is still low! It's as if it's still running out of ink, however the cartridge is brand new. Please help!
Did you remove the strip that the printers ship with? If the pull tab is still in then there is typically enough toner to print a few pages and then it fades out. Remove cartridge and check on left and right hand sides for a plastic loop usually orange. The instructions would have been in the box.
Mar 23, 2011 | HP LaserJet 1320 Printer
Installed a new cartridge and printer continues to say install new cartridge press
Did you pull out the plastic tab to allow the ink to flow? It is sometimes an orange or green plastic tab which when pulled, has a long plastic ribbon attached to it. Pull it completely out.
Oct 27, 2010 | Epson Stylus NX400 InkJet Printer
How do i install a ink cartridge into a canon pixel printer
Turn printer on and lift lid, carriage will centre, simply unplug cartridge by pressing down on tab and pulling backward., ensure you replace with a new one as the print head can dry out.
Mar 09, 2010 | Canon PIXMA iP1600 Printer
Replaced Yellow Cartridge, Red light on, close lid, not working,
Hi ...
I would suggest that you follow the below stesp to install the ink tank ..
. Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
Note: If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2. Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3. Remove the ink tank whose lamp is flashing fast or is off.
Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Caution: Handle ink tanks carefully to avoid staining clothing or the surrounding area. Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
Note: Be sure to replace ink tanks one by one when replacing more than one ink tank.
4. Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
Unpack the new ink tank and completely pull off the orange tape. Then, remove the film. Remove the orange protective cap from the bottom of the ink tank and discard it.
Important:
  • Be sure to remove the clear film from the ink tank in the exact order shown in step 4, as failure to follow this step may cause the ink to leak and stain your clothes and hands.
  • Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
  • Do not re-attach the protective cap once you have removed it.
  • Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
  • Ink on the removed protective cap may stain your clothes and hands.
  • Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5. Install the ink tank.
(1) Insert the ink tank into the Print Head.
(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important: Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6. Close the Inner Cover.
Note: Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7. Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
  • The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
  • To maintain optimal print quality, use an ink tank within six months of first use.
  • Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
  • Color ink consumption may occur even when black-and-white or gray scale printing is specified.
    Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
  • When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I have installed new ink cartridge but printer says it is empty
make sure you pull out the orange tab thingy on the cartridge before installing it.
Mar 30, 2009 | Brother MultiFunction Center MFC-440CN...
HP LaserJet 1500 Printer Logo
Ben Johnson
