Question about Danner Pond Pondmaster 500 Gph Mag - Drive Pump
What is involved in changing water pump 2000 300m
  • 47 Answers
Remove the upper radiator support panel, remove the engine front covers, remove timing belt (should be replaced when replacing water pump). You will need a large bench vise to compress the timing belt tensioner. Book says to remove the crank pulley but you can get by without doing it. Be sure to wash all of the spilled coolant out of the timing belt area as coolant tends to do nasty things to timing belts.
Posted on Jun 13, 2009
How i change water pump in a toyota siena
Very involved job, the water pump is driven by the timing belt, you have to take off the whole front of the motor. Recommend you change timing belt and pulleys too, recommended interval is 60,000 miles. Several good videos on youtube cover the process.
Jul 22, 2014 | 1999 Toyota Sienna
Changing water pump ona 97 subaru impreza outback sport
do i have to take cambelt of to change water pump
Jun 03, 2012 | Cars & Trucks
Changing the water pump in the 1999 oldsmoble alero involve the timing chain? and is it easy to chance it?
YEP THE 2.4 ENGINE YOU HAVE TO REMOVE TIMING CHAIN TENSIONER AND TIMING CHAIN.THIS JOB NOT EASY OR HARD BUT IF YOU NEVER DONE ANY KIND AUTO MECHANIC WORK BEFORE JOB WILL BE HARD.IF YOU WANT TO TRY IT.BUY A HAYNES REPAIR MANUAL READ THROUGH IT.THAT WAY YOU KNOW WHAT YOU HAVE TO DO TO REMOVE AND REPLACE WATER PUMP.
Sep 21, 2010 | 1999 Oldsmobile Alero
If my water pump needs to be replaced will there be other changes I may need to do?
in most cars the water pump is outside the engine and is driven by the serpentine belt (that also drive the generator and air conditoner) ... so its a good idea to change that belt since it involves no increase in labor (they may charge for it but it takes no more effort to install a new belt then the old) ... also inspection of the belt tensioner and idler pully is a more than a good idea .. they may have frozen pivots or bad bearings that will cause later failures ...if they are in good shape then no need to change them unless they are available at a reasonable cost .. most off the shelf antifreeze contains silicates and thats responsible for most water pump failures .. silicate free antifreeze is available but at a higher cost .. thats money well spent... some cars have the water pump driven by the timing belt inside the timing belt housing .. now that can involve much more labor .. its prudent to change the timing belt and any warn idler or tensioner pullies while you are at it ... timing belt driven water pump repairs are expensive but those extra parts wont add a lot to the bill but will increase long term reliability greatly ... on a few cars the whole front end must be removed in order to change the water pump or even thermostat .. thats additonal labor ... hope you dont have one of those ..
Jun 30, 2010 | Cars & Trucks
What is involved in changing 1995 subaru outback impreza water pump
water pump is ran by the timing belt. when changing the water pump the belt should be changed to. and sometimes the timing belt tensioner needs to be replaced too.worst case senerio. about a 350-400$ repair.
Apr 19, 2010 | 1995 Subaru Impreza
Is water pump easy to access? have to change someones water pump and have never look under hood of Intrepid. Have to fix in driveway and have like 2' of snow here. Just wondering if there is any under car...
No under car work involved - this operation can be done from above - hard on back -- water pump is located inside timing cover - runs of timing belt
Jan 09, 2010 | 2000 Dodge Intrepid
How to change the water pump on a 2002 kia sportage
Hi:
Once you get the timing belt removed, the water pump is relatively easy to remove. It has approx 5 bolts.
Oct 28, 2009 | 2002 Kia Sportage
Water pump how hard is it to change or is it alot involved
quite a lot involved. cambelt has to be removed as well, and would be advisable to change, then all timed up ,etc
Oct 08, 2009 | 1998 Volkswagen Passat
Leaking water pump
hello,yes you can do it,first remove negative cable of battery,remove all belt,remove engine fan,shroud,water pump pulley,then remove water pump,installing in vise versa, ty
Apr 22, 2009 | 1986 Mercedes-Benz 300
Replace water pump 1994 isuzu rodeo 3.2
How do I change water pump on 1994 Rodeo 3.2 .
Jul 15, 2008 | 1997 Isuzu Rodeo
Danner Pond Pondmaster 500 Gph Mag - Drive Pump Logo
124 people viewed this question
Top Danner Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Danner Garden Expert? Answer questions, earn points and help others
