Question about Dell 1600n All-In-One Laser Printer
Dell 1600n will not connect
I just got a used dell 1600n off craigslist. The system came with a disk but I can not get it to load. If I choose personal installation the next screen tells me "no printer found" and I can go no further. I tried installing using network but also ran into a similar problem. When i put in the ip address it can not find the printer. If I ping the address it does reply though. My computer (vista based) will print to the system - that works fine but I really need it for scanning. Any help would be appreciated because frustration is setting in.
  • 62 Answers
One of the most common problems when networking is adding the correct subnet address. To check your computers.
Click on start
click on run
type in the box "cmd" (no quotes)
click in the black dos box and type
This will tell you the ip address and subnet of your computer.
The ip address need to be different for the computer and the printer but the subnet address needs to be the same
Posted on Mar 06, 2009
Connect dell 1600n to computer
This model Dell printer can connect to your computer by -
Hi-Speed USB cable, or
a LAN cable over your network using Ethernet 10 Base-T/100 Base-TX
May 18, 2012 | Dell 1600n All-In-One Laser Printer
Have got new pc driver for Dell 1600n needs to be installed
Here is the link from Dell Official Support for Drivers download for Dell 1600n
Select Operating System and get the drivers and software.
Good Luck!
Appreciate generously if the solution could have been of any help!
Dec 16, 2010 | Dell 1600n All-In-One Laser Printer
Mac user can't scan on Dell MFP 1600n
That's because you can't scan over wireless. In order to scan, you need to be connected via USB, so I hope you've got a MacBook...
Jul 24, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n to be used on an imac
Hello! Unfortunately, Dell printers mainly supply Windows drivers on their website. To print to this printer, your new iMac will probably pull a generic driver to use with the printer. It should still work no problem, as you're saying, however you won't be able to use the software that's available on the PC. The downloads available for your Dell printer are here:
Dell 1600n Printer Downloads
You can tell by clicking that link and looking under Operating System that only Windows operating systems are available, as well as the software shown below, which is only made for Windows based systems. As for the PaperPort software, that program is made by a company called Nuance. When you purchased your printer, you most likely received a trial or full OEM version from Dell along with your new printer as a software bundle deal. From what I can see, the software is only Windows based. Sorry!
Below is the link to a free viewer that can still read your PaperPort files:
PaperPort Viewer for PC and Mac OS [Free]
Mar 16, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Slow Printing
Most times the PCL driver will work just fine for printing .pdf documents. Occasionally you will need to us a PS driver to print .dpf docutments. PCL was designed to work best with MS Word, Excel, etc programs and PS drivers were designed to work best with Adobe .pdf.
One way to see if you have the PS driver already installed, is to (in Windows XP) start>control panel>printers and faxes>in here look for an Icon that represents your printer that has PS in place of the PCL. If this is installed then when you go to print your docuement, choose this icon to print with.
If you do not have the PS driver already installed, try adding the printer to your system. You would do this by (Windows XP) start>control panel>printers and faxes>add a printer wizard>Next>Choose your connection(local or network)>Next>Select a printer port>Next>Install Printer Software(If you have downloaded the most recent drivers, choose have disk and navigate to where you saved it. If you have the CD, use have disk and navigate on the CD to where the PS driver is>Next>You may or may not get the next window asking you to choose whick model of printer you are installing, it varies from printer to printer. From here it is pretty straight foward, just read the wizard and click next. The last step you will need to click finish for the drivers to actually install.
As a side note, not all printers have a PS driver available.
Feb 23, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n printer driver for Windows 2003 Server
I had a similar problem deploying these printers, however i found using the XP drivers in 2003 does work fine. Not sure why dell doesnt have an installer for this printer in 2003 server, but here you go.
extract that file, note its destination directory. do not attempt to run the setup.exe, it will fail saying your operating system is not supported.
instead navigate to (if you didnt change the path) C:DelldriversR165289p0nPrinterPCLWINXP
this folder contains the driver you need to install manually.
one stange thing about these lexmark based network printers is the need to select 'local printer' during install, uncheck automatically search for my device, and then create a new TCP/IP port. Use the IP address provided by the network configuration print out you can access on the front panel of the printer. now just make sure to select 'lexmark network card' as the type of network interface. it should now ask you for your printer type, click have disk, and point to the driver folder mentioned earlier.
hope this helps. thanks alot dell.
Oct 30, 2008 | Dell 1600n All-In-One Laser Printer
Have a Gateway laptop with Windows XP. Want to use Dell 1600n printer
Download the drive from Dell, and run it to unzip it. When adding the printer, click "Have Disk" and point it to the folder that you downloaded the driver to.
Jun 19, 2008 | Dell 1600n All-In-One Laser Printer
Driver for mac OS for Dell 1600n
If you install the Xerox1600n it should work for you. That is what we had to do.
Feb 24, 2008 | Dell 1600n All-In-One Laser Printer
Printer is not found by Computer
If the printer is connected through the USB than there could be an issue with the cable for the port that you have connected it to.So try different cable and ports.Also incase there is a software issue and reinstalling is not helping than you have to do a complete operating system reinstallation.
Dec 26, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
237 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
