Question about Nintendo Wii Console
Wii disk won't spin
When a disk is inserted into the disk drive all you can hear is clicking sounds, so when you enter into the game an error occurs.
I opened up the wii and from what I could tell everything was working although the disk didn't spin when inserted. Is there anything I can do at home?
  • f_hergert Mar 08, 2009
    thanx the wii has been bugging me for weeks ill send it into nintendo.
  • 6,784 Answers
Hi, this will have to be repaired by Nintendo unfortunately. there is a relay switch that initiates the spinning of the disc when it is inserted all the way. this switch also has a sensor telling it to initiate the play/run option. all of this is automated and if either one of these important devices are malfunctioning, it will cause the Action's you are witnessing.
Posted on Mar 06, 2009
Console makes clicking noise when disc is inserted and disc will not start? Screen says error has occurred and to consult manual. It happens with every disc I insert
I Had the same thing happen! It has to do with the retention clip. Here you go:
How to Fix Wii Disk Read Errors Game Front
After you fix it, don't leave game disks overnight or in for extended periods of time as that pulls the clip down.
Sep 13, 2014 | Nintendo Wii Console
Clicking sound after spinning disk - error
The problem is the installation. A slight variation of the read head angle is all it takes to misalign the laser beam. If the angle is not precise, the light emission will not tract correctly, thus you get a read error. It is like phonograph needle sitting in a groove and making direct contact with the data sectors.
Dec 21, 2013 | Nintendo Wii Console
Wii "An error has occured" when disc is inserted.
Maybe the disc is inserted in the wrong direction switch it to the other side that will work.
Apr 23, 2017 | Nintendo Wii Console
My disks are not playing. It states. An error has occurred. Press the eject button and remove the disc,then turn the wii off and refer to the operations manual. I have tried everything
i am having this same problem.... found this bit of info, hope it helps.
The most common reason for the Wii not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
Jan 04, 2011 | Nintendo Video Game Consoles & Games
Makes squeeling sound when disk is inserted
this kind of problem normally occurs in nitendo wii......make sure that the disk u using is original disks.. by using pirated disks create such problem...clean ur lens before insert disks..
otherwise using repair guide u easily solve this problem..all the best
Dec 06, 2010 | Nintendo Wii Console
Power on disk inserts then states can't find disk not reading disk
This is a common error ........this error occur due to the internal defect caused by crashes in the cd you used
you can fix this easily don't worry .......... their are repair guide available for nintendo wii console you can download it and solve your problem just like that ...... Click this link
CLICK HERE to download guide
Dec 03, 2010 | Nintendo Wii Console
My Wii console fell and will no longer read disks. When I put a disk in, after a minute or so a message will pop up saying, "An error has occurred. Press the Eject Button and remove the disk, then turn the...
Sounds like the drive or the laser has been dis lodged and needs to be repaired. Simple if you have basic electronics repair experience. Shouldn't cost too much to be repaired at a service centre, unless parts need replacing.
Hope this has been helpful.
Ian
Feb 22, 2010 | Nintendo Wii Console
Crunching sound after disc inserted and it starts spinning. then screen reads "error occurred, eject disc..."
there mite be something jammed inside the disk drive take a look inside to see if theres anything inside if so just pull it out with something long and thin that dosnt conduct electricity.
Dec 20, 2009 | Nintendo Wii Console
Wii reads gamecube games, but won't read wii games.Any solution?
the drive might need taken apart and inspected for something blocking the bigger wii disk. Can you hear the disk spinning?
Jul 19, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
889 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
