Question about Samsung RS2630SH Side by Side Refrigerator
Freeer motor wont operate, motor ok,
Have a samsung refrierator, model RS267LABP, motor ok, no voltage to it, freezer and food door switches ok.
  • 700 Answers
Check the connections to the sensors inside of te evaporator compartmnet to the freezer. the fan won't come on untill the evsaporator temperayture is 0 degrees. hAVE YOU CLEANED OUT THE CONDENSER IN THE BACK LATELY? it may be dirty.
Posted on Mar 07, 2009
Refrierator side is not cooling- Freezer side is fine
Twin Cooling System
·The refrigerator and the freezer have two
evaporators. Given this independent system, the
freezer and the refrigerator are cooled individually as
required and are, therefore, more efficient. Food
odor from the refrigerator does not affect food in the
freezer due to separate air flow circulation.
Because of the dual system one of your evaporators may need servicing.
Aug 16, 2014 | Refrigerators
My samsung refrierator is making a chirping noise
It most likely is the fan motor. When the bearing wears out, the fan motor shaft tends to run "off center" every few seconds and it sounds like a "chirp". See if it stops when the door is open and starts after the door switch is held closed for a minute or so.
If it is the motor, find a replacement online.
Jul 13, 2014 | Samsung Refrigerators
Frost forming on top/front panel in freezer side subzero 632
In your freezer section there are 2 door switches -- press each one. One turns off the light. The other turns ON the freezer evaporator fan. If the freezer compressor is running the evap fan should RUN when the switch is depressed. If not, the fan motor is defective OR the switch is defective. Easy to troubleshoot the switch - just pry it out with a screwdriver, short the terminals with a piece of insulated wire. If the fan runs, it's OK and the problem is the switch.
If it's the fan, it's not hard to replace. Get replacement motor, turn freezer control to off, remove food and shelves, then the back sheet metal panel. Fan is right behind the panel.
Aug 02, 2017 | Sub-Zero Overlay Design 632/O Side-By-Side...
Freezer ok, fridge not cooling
That could be the motor up in the freezer is not working or it could be a defrost problem. If you see frost on the back side of the freezer that is most likely a failed defrost circuit. If you cannot hear the fan motor or possibly a fan switch mounted in the door jamb. Sometimes the drain can stop p and water puddles between the top and fresh food bottom. Forms a slab of ice and blocks the cold air from getting to the fresh food section.
Jul 28, 2011 | Kenmore Top Freezer Refrigerator
Samsung model rsh1dbbp: fridge running at 19 degees. have cleared ice build up in lower left hand side. freeer and water ok. no ice build up in freezer
The accumulation of ice on one side indicates a refrigerant problem. Basically there is a refrigerant leak and some of the refrigerant has been lost.
A technician can repair the leak and re gas the refrigerant for you.
Apr 01, 2011 | Refrigerators
Freezer makes ice, but will not freeze food. control board has been replaced
Is it a side by side? Do you have model number? Was the control board replaced because of this issue? Does the fan motor in freezer operate? Open freezer door and push in door switch to operate fan motor. If it is a side by side sometimes when the fan motor goes bad it damages the motherboard. Is their ice build up on back wall of freezer?
Mar 31, 2011 | GE Refrigerators
Fridge at the top is not working, freeer at the bottom is working perfectly. Our fridge has stopped working, all lights are on inside. We have turned the power off and then back on again. It is only 4...
All cooling takes place in the freezer (bottom, in your case). Freezer air must be circulated into the fresh food compartment to cool it. There is a fan in the freezer called the evaporator fan, which is supposed to do this job.
1. You have a blockage in the return vent to the freezer. Remove item that is on the floor of the fresh food section and find this return vent (hole or passageway) and prove to yourself that it is clear.
2. Freezer fan is not working. You should hear it when opening the freezer door. Some units shut opff when the door is open, so see if pushing the button that turns off the freezer light does that too. If not working find out why. Fan blade stuck on something? Motor seized? Replace failed motor.
3. Defrost system has failed, allowing ice build-up on the evaporator (behind freezer back wall). Test heater, defrost limiting thermostat, and defrost timer circuit. If a circuit board determines defrost cycle timing, replace it if the def. thermostat and heater are good.
Jan 29, 2011 | Westinghouse Refrigerators
Light in refrierator does not go out when you close the door.
Check the door switch is operational by pressing it with your hand. When you press it, it should turn off the light. If it does that, then check the door if the door braket is worn or loose or is not hitting the door switch when closing.
Aug 16, 2010 | LG LRBC22544 Bottom Freezer Refrigerator
The door posts of my fridge freezers gets very hot. so the door seals become hot the only way it stops is if i shut the doors hard. why is this happening, it did it not long after i got the thing but now...
This is pretty normal unless you are having problems below the refrigerator fan. Good air flow equals more efficient. What you feel is call a yoder loop and that is hot Freon coming from compressor and circulating around doors to prevent moisture. If it becomes hotter and temperatures begin to increase inside freezer and fresh food compartments is really when you should be concerned. If the pipes were not there you would beging to see moisture form around door seals and rust also. At this point I believe your refrigerator is OK. Just watch for changes in temperatures inside combined with the heat around door frame. Other model refrigerators use electric heat strips to do the same thing and they can be switched off at a switch called energy saver. Your model does not have that and hot days the hotter it seems. Let me know if you have a safe temperature of 38 degrees inside fresh food compartment and if that changes we may need to clean dust and check condenser fan motor. Thanks, Sea Breeze
Mar 15, 2010 | Samsung Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
117 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
