Question about Gateway MT3422 RTL Notebook
Gateway MT3422 Screen will not turn on.
When I first turn unit on, the screen will not come on. The hard drive light does not illuminate.
  • 11 more comments
  • jrhome2002 Mar 06, 2009
    When the unit is first turned on: The blue power light comes on as well as the charging light. The hard drive light flashes briefly then goes off, the fan spins and the dvd light stays on during dvd check thens turns off. No light or image appears on the screen. I have removed the hard drive, memory and battery. I do not know how to remove the cover entirely to check connections on the motherboard.
  • Anonymous Mar 22, 2009
    i have the same problem, i happens when i install 3 vista updates... that was the only change in my laptop..
    first, the laptop reset itself suddenly wen i was working, but it don't turn back on... it looks like it was suspended, but it doesn't respond .. i had to hold down the power button to turn it off.. this happens 3 time in the day... next day, i only get black screen, the dvd spin, the fan works, it appears to boot but i never reach the logo screen ...
  • opsimathic Mar 24, 2009
    I also have a Gateway Mt3422 with problem exactly as described.  The only difference is that after 15-20 (or more) attempts at holding the power button down to force a reboot it will sometimes boot OK.  During the most recent reboot I pressed F12 while booting (PXE Boot) this briefly flashed an error message "Media Failure - Check Cable) does this clue help anyone?
    Thanks!
  • tickedofftoo Mar 28, 2009
    Same issues here...fan runs but no screen and no indicator lights other than the blue light on the very front of the machine. Help!
  • Anonymous Apr 02, 2009
    I have the same problem as well.
    Me too.
  • Anonymous Apr 06, 2009
    what's the deal?
  • Anonymous Apr 07, 2009
    same exact problem. I hibernated mine one afternoon, and when I tried to turn it back on nothing happened. Things been down for 2 days now.
  • Anonymous Apr 09, 2009
    Great. I was hoping someone knew the answer to this one. My computer did the same thing about a month ago. I tried to hook up to another monitor and still nothing. I talked to Best Buy and they said $$$ (around 300.00 to fix it). Everything turns on but the screen. This seriously sucks! I have had it for 2 years, and now I can't find my receipt for my extended warranty. Plus, they can't find it in their system.
  • Anonymous Apr 13, 2009
    I have the same thing happen, It was my motherboard, brought new one. Can't get the bottom off to replace it. Help ?
    cherubs825
    I need to get into the bottom of my Gateway notebook to replace the motherboard.Can"t find all of the screws.
  • dogpilers Apr 26, 2009
    I have the same issue. Laptop will not turn back on, although I managed to get it working (this is the 3rd time it has done it) I pressed F1 F2 F3 F4 and Enter while pressing the power button and it worked, twice. Now it wont work at all.
    All the lights below the mouse buttons flash on. the CD light flashes, as though it's trying to read but nothing happens. Sometimes when I hold enter while powering up, the wireless card light will stay on.
    I've tried powering up with an external monitor plugged in but to no avail. I have removed the battery, and mains power, pressed power button for 30seconds, plugged into the mains and tried to power, but no luck. I've tried F12 on startup and again, nothing. I have tried removing ram, and hard drive. That didn't work, even though the first time it seemed to work. I cannot get into the computer enough to check the motherboard, due to the stupid amount of screws and inaccessible places in which they are placed.
    Help is GREATLY Appreciated.
  • Nicholas Lussier May 11, 2010
    Is this a recent issue? Have you tried removing RAM, Harddrive or battery? Does the battery charging light come on?
This solution worked for me. After Geek Squad had looked at it and said that there would be a new mother board needed. I can vouch for this solution. halo321@comcast.net
Solution #1 posted on May 07, 2009 Asker's Rating Gateway MT3422  Screen will not turn on. - 2%20stars_w.png
noavatar_s.gif captainmfGateway MT3422 Screen will not turn on. - nonexpert_s.gif:nonexpert_s.gif Apprentice
Rating: 75%, 2 votes
iam mohamad fakih from lebanon iv got the same problem but i solve it,the problem of this gateway is the high tempreture from the cpu this is what makes the damage
to fix it, easily just push the keyboard dawn hardly by your hand on the left side above the following keys:E,R,F,4,5 (u can use ur fist) push hardly and press power button and wait 4 seconds
and when the laptop comes on enter the windows and run aprogram that makes the cpu gets hot(a big game) this is to make the motherbaord become hot ,the heat of the cpu will automatically
solder the damaged bus in the motherboard . good luck
Posted on Jun 02, 2009
  • halo321 Jun 02, 2009
    This really worked. I am amazed but it did and now my laptop is working as usual
    This really worked for me. halo321@comcast.net
Iam mohamad fakih from lebanon iv got the same problem but i solve it,the problem of this gateway is the high tempreture from the cpu this is what makes the damage
Posted on May 07, 2009
  • 285 Answers
I had the same thing happen. Got it all apart. The motherboard part number is 4001189R. I couldn't find a MB for less than $350 but I found the same laptop used for $300.
Posted on Jun 04, 2009
I have had the laptop for about 2.5 years and sent it to gateway at least 3 times to fix this problem It just happens that the same problem keeps on repeating itself. Right now, it's dead ( only the blue lights) turn on and I cant see my screen . Right now I am out on my warranty.
Posted on Dec 05, 2009
GATEWAY mt3422 WILL NOT BOOT UP. Power light is
if your harddisk is ok than , u open your notebook motherboard and clean processor fan properly,,than again fitting your laptop than boot from cd rom (make sure that your cd rom is ok )
Apr 14, 2010 | Gateway MT3422 RTL Notebook
Hi my gateway just lost the light on the
Turn it off. Wait 1 hr. Restart. It could be that the video card is overheated.
Mar 23, 2010 | Gateway MT3422 RTL Notebook
My MT3422 gateway will not boot up.
Sounds like an internal graphics problem then motherboard fault.
http://www.notebookforums.com/post2949935.html
Aug 03, 2009 | Gateway MT3422 RTL Notebook
Screen isnt booting up, laptop opens all the way- broken?
The computer will not work without a hard drive.
Most laptops screens will go all the way back.
Enjoy.
Jul 08, 2009 | Gateway MT3422 RTL Notebook
Hi I have a gateway mt6728 and when I start up i get 2 options start windows normally or start launch repair. Both options bring me to a screen that says Gateway please wait and it just stays like that....
sounds like windows is not loading properly. try taking out the hard drive. disconnect everything. plug it all back in and try again. This might work.
May 25, 2009 | Gateway MT3422 RTL Notebook
Black screen will not boot at all
boot it, as it starts, keep tapping the F8 key,
should take you to, system startup utility,
take the top option
" last known good"
let it do it's thing
Reboot.
hope this helps
Regards
Richard.
Apr 20, 2009 | Gateway MT3422 RTL Notebook
Gateway MT3422 won't charge battery
shutdown the notebook - unplug the a/c adaptor - remove the battery - re-insert the battery - plug-in the a/c adaptor
it can also be a systemboard failure
Mar 21, 2009 | Gateway MT3422 RTL Notebook
Gateway MT3422/athlon tk-53 mal-function
some screen failure or graphics failure..
I think you need to send it back there you bought it.
CS.
May 19, 2008 | Gateway 7405GX Notebook
Gateway MT3422 RTL Notebook Logo
4,722 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
