Question about Vivitar ViviCam 3746 Digital Camera
The shutter is stuck on my vivitar 3746 and won't turn on or respond in any way. what can i do?
This always happens on mine when the batteries are low or taking them out while lens is extended. What I had to do was take it apart and manually wind back in the lens via the gears that extend it. Hope this helps. Otherwise the camera is rendered useless.
Daniel
Posted on Apr 03, 2010
Shutter won't reset after battery replacement
it can fixed only camera fixera company,better if you fix it according to camera company because your problem also be facced to me,i take it to a ordinary camera fixer and then my camera fully get damaged because who fixed my camera they fall acid in battery placce.
Mar 26, 2013 | Vivitar V3800N Zoom 35mm SLR Camera
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
Jun 04, 2011 | Canon PowerShot SD1000 Digital Camera
I bought a new SD card and put it in and the screen display keeps sayd SD card error. Please help.
If you're using an SDHC memory card, the camera doesn't support it according to the specs. If it's the correct card, try another one - you may have a bad one.
Feb 15, 2011 | Vivitar ViviCam 3746 Digital Camera
Canon PowerShot S3 IS shutter problem. Shutter does not respond. Screen is black. No pictures are seen. It sounds like it it taking a picture, but doesn't. When looking into lens, it doesn't appear the...
Dec 20, 2010 | Canon PowerShot S3 IS Digital Camera
Displaying images
You can get the manual from here:-
http://www.retrevo.com/support/Vivitar-3746-Digital-Cameras-manual/id/200ag812/t/2/
As to no images, when you get the manual, there may be a power/battery conserve option which allows you to turn the screen on and off.
Mar 14, 2010 | Vivitar ViviCam 3746 Digital Camera
I lost my cd for #1609761 (9224)i have pics on the cam i need the software where can i get the software online for free
I would go to the vivitar website. I did not see your model of camera on the downloads, but it also said if you do not see your camera on there you can contact them for support. You never know, they may be able email you the driver or send you a c.d. for free. Good Luck!
Here is their support number I found on their site: US: 1-800-592-9541
Hope this helps!
Aug 01, 2009 | Vivitar ViviCam 3746 Digital Camera
I have a question. Can I use a 2GB memory card in my camera?
Any SD card up to 2GB in size should work in this camera.
Nov 29, 2008 | Vivitar ViviCam 3746 Digital Camera
Zoom button is not working
Hi Neil, You have to go to nearest repairer or i strongly suggest to go to Vivitar shop or you can send it to us i dont khow where you are located, but if it is possible for you to send your camera for repair in India courier it to me by DHL. Mail us for more details my e-mail is: cam-tek@sancharnet.in
Jul 25, 2006 | Vivitar ViviCam 3746 Digital Camera
Vivitar ViviCam 3746 Digital Camera Logo
63 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
