Question about Philips 55PP9352 55" Projection Television
Color change. I have a philips 55pp9352 tv, and the color has changed to a redish orange, and i cannot get the color back... Is it a bulb problem.. What can i do???
    Problem Solver:
  • 5 Answers
Philips is notorious for bad picture tubes. especially the blue. occasionally the coolant leaks out of a tube but this usually causes bigger problems than color change cause it shorts out whatever it leaks onto.
Posted on Mar 30, 2009
The color is extremly messed up...peoples skin is redish and the green is like a neon color? How do I adjust the color frm the back of the tv?
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 05, 2011 | Philips Magnavox 9P6034C 60" Rear...
My tv color is very red and orange but all 3 color bulbs are working it seems... the actual picture only comes through the red and green... help!!!
go to tvrepairkits.com and order the kit that replaces the fluid in the blue and green bulbs, will clear up your color issues no problem :) i just fixed mine, now it looks great.
May 10, 2010 | Philips 55PP9352 55" Projection Television
The color on my tv is awful. sometines it can be bright blue sometimes orange then most times very dull in color
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
  • Halos around objects
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 27, 2009 | Philips 50P8341 50" Rear Projection...
I've got a Philips 50P8341A Projection 50'' TV. My problem started with the screen only showing an orange image. The picture was clear and sharp, but there was no color other than orange. So I tried to fix...
Turn the top left knob down till the pic comes back and the reason your color is off is the fluids in the green and blue chambers needs to be changed.
Nov 12, 2009 | Philips Televison & Video
Color washed out
If the tv has a blue haze and the picture is turning greenish-redish, the problem is that the coolant in the crt's are cloudy due to bacterial growth. The fluid needs changed in the Blue and possibly Green tubes, the red tube usaly does not need the fluid change because the bacteria that seems to inabit the tubes dont seem to like the red light.
To do this yourself is involved and will expose you to electric shock dangers. If you want to tackle this yourself Post back and i can give you explisit instructions.
This service by a Technican could cost around $300.00 to preform, this cost can vary depending on the shop.
Sep 04, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips hd tv
convergence i.c.s change both of them even if only one color is out. if one is bad the other is usually going to give out soon. the part # should be. stk 392-120. also check resistors around i.c.s if the open you wont be able to adjust convergence.
Mar 20, 2009 | Philips 55PP9352 55" Projection Television
Philips projection tv
sounds like your cooling fluids in the tubes needs to be changed. Repairman told me it was common on the philips.
Sep 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
Replaced ic on philips you told me about which resitors are 6.8 ohm ....
your model is 55PP9352/17 correct? If so all the resistors from R3149 - R3160 are all 6.8Ohm 1watt 5% tolerance. metal film resistors. The resistors in your upper pic 3157 and 3158 appear to be open by looking at the pic I cant actually make out the banding colors to determine what rating they are. But if your set is a 55PP9352/17 they should be 6.8 ohm. let me know the actual color of the bands in order and I will post the ratings of 3157 &3158
Apr 04, 2008 | Philips 55PP9352 55" Projection Television
Convergence
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 13, 2008 | Philips 55PP9352 55" Projection Television
Philips 55PP9352 55" Projection Television Logo
130 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
