Question about Acer X193W LCD Monitor
How to adjust intensity of Acer X193W LCD monitor manually
I've just turned on my new X193W monitor. All works fine; however, although by using it's push buttons I can browse through the menu, neither button can change the percentage of intensity or contrast. All my old monitors allow for manual adjustments; this one only allows for a choice of 4 automatic settings. The included brief guide does not give any information.
I'd greatly appreciate ypur help. Thanks,
B. T.
  • 408 Answers
If you go into the screens menu, there will be a button for contrast and brightness.  When you have the one you want selected, press munu again and that will bring up the dialog to change the percentages.
Posted on Mar 06, 2009
Hello, I have installed a new 18.5 acer monitor, X193W C but the screen turns blank when I scroll over the task bar. Any suggestions? I have windows xp. Donna
I would check Acer's website in the support section. I suspect you have the wrong driver for your operating system.
Jan 20, 2011 | Acer X193W LCD Monitor
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
My Acer X193W monitor has discoloration, a neon green on the screen wherever the darker colors would have been displayed. Is it dying or just needs adjustment? (Changing the settings to different...
Its dying...as a last resort make sure no magnetic devices such as speakers are near it and look for a reset function...if you can get into settings try turning it off and then turn it on and try again.
Jun 15, 2010 | Acer X193W LCD Monitor
Acer X193W not getting any signal when connected to 8600GT by DVI
If you know the cable and the place it was before
replace it and reboot the dude (Ps if you dont have the referce and instructions for the take a polaroid
Oct 19, 2009 | Acer X193W LCD Monitor
Low volume in acer x193w
install the audio drives again then it will worl fine
Jun 25, 2009 | Acer Aspire 5100 Notebook
Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
Jun 11, 2009 | Acer X193W LCD Monitor
Drivers for the Acer LCD monitor X193W under Windows XP Pro.
The acer LCD monitor is plug and play.You don't need a driver.But unless you have a graphics card that supports at least 1440x900 you have problems. Also if your card has a div connection, use that instead of the analog connector, The monitor comes with that connector. Use the old one to connect a second CRT monitor if you want. Don't connect both to the lcd monitor and to the computer unless you are using a second monitor. Like everything these days, every purchase seems to need an upgrade of sorts, On board graphics **** anyway. Buy at least a 128 MB graphic card with a digital connector and more RAM never goes astray.....
Ron
Nov 09, 2008 | Acer X193W LCD Monitor
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
Acer X193W LCD Monitor Logo
464 people viewed this question
Brian Sullivan
Brian Sullivan
