Question about YouTube Videos
No acces at you tube
No open the window of you tube
  • Nicholas Lussier May 11, 2010
    When you try what happens?
  • 463 Answers
Install the flash!
Posted on Mar 06, 2009
I can't find the fuse for the power windows on a 1998 Lincoln Navigator
All the other windows work ? Not a fuse , one fuse powers all the windows . Test for B+ voltage at the switch an the window regulator would be the proper diagnostic procedure . Do you own a volt meter ? know how to read a wiring diagram ? how to do basic automotive electrical testing . The Faint click you hear is probably a relay , which means the GEM - genaric electronic modual is energizing the window relay . The windows are computer controlled .
The GEM will activate the OTD Relay until one of the following conditions is met:
  • The LF regulator control switch is pushed to the UP position.
  • The LF regulator control switch is released (OFF position) and then moved to the down position (first detent) or one touch down (OTD) position (second detent).
  • Seven seconds have elapsed since the OTD was initiated.
  • A window regulator electric drive stall condition is detected on the one touch down sense line inputs.
The UP window operation is not controlled by the GEM. The feature is activated when the delayed accessory is active and the LF window regulator control switch is pressed to the UP position. The switch provides delayed accessory power to one side of the motor and ground to the other side through the one touch down relay. The one touch down relay is not active when the LF regulator control switch is in the UP position.
Passenger windows may be raised or lowered using the LF master control switches or the appropriate passenger window switch. Passenger window switches receive power when the delayed accessory relay is active and the LF remote lock-out switch is in the UNLOCK position. When in the LOCK-OUT position, the passenger windows are deactivated.
The GEM controls manual down and auto down window movement with the down window relay. The relay is activated by applying ground directly to one side of the down window relay coil, and deactivated by removing the ground signal.
The delayed accessory relay provides power for the operation of the power windows and the power moon roof. The delayed accessory feature is active when the ignition switch is in the RUN or the ACC position, or when the ignition switch is changed from RUN or ACC to the OFF/LOCK position and the LF and RF doors are closed.
The GEM will deactivate the delayed accessory feature when:
  • the LF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • the RF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • 10 minutes have elapsed since the ignition switch was changed from ACC or RUN to the OFF/LOCK position.
Feature inputs:
  • LF door open warning switch (open circuit with door closed, grounded with door ajar).
  • RF door open warning switch (open circuit with door closed, grounded with door ajar).
  • Ignition switch RUN position (battery potential on both the RUN and RUN/ACC inputs).
  • Ignition switch ACC position (battery potential on the RUN/ACC input).
  • Ignition switch OFF/LOCK position (absence of battery potential on the RUN, RUN/ACC, and START inputs).
The Trainer 24 Power Window Troubleshooting
Mar 03, 2017 | 1998 Lincoln Navigator
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
New whirlpool bath installed pump working no air coming through jets
I would guess there could be one of two problems. First, open the access pannel so you have acces to the motor and air tubes. From your actuator that turns on the jets, there should be a small tube (probably clear) that goes from the actuator to the motor. this tube controls the jets, make sure it is connected, finding the small nipple that this tube connects to on the motor can be difficult and they are often not connected when you buy the tub or come loose during instalation. If that is OK, check to make sure the Air Inlet pipe is not blocked. there should be one (maybe 2 but usually 1) of the large tubes that circle the tub undernieth that is open on one end. It is probably the tube that is the highest off the ground. this should not be connected to anything, it almostt appears that the water would rush out if you don't connect it to something, but that is where the air comes in for the bubbles. good Luck
May 07, 2011 | Home
Hi, I bought a TP-Link TL-WA701ND (Wireless Lite N Access Point) today, and am having troubles getting it to work. The Quick Installation Quide gives directions for Windows operating systems XP and Vista...
You must setup manually your acces point. First go to control panel, under network and internet you'll find a task, view network status and tasks click on it and in next page go to change adapter settings, find local area connection and right click on it and go to properties, in next window highlight internet protocol tcp/ip then click on properties in next window click on use the folowing ip adress and write in ip adress box an ip from 192.168.1.2 to 192.168.1.253 at your choice in subnet mask box just leave 255.255.255.0 (this apear when you click in these box). Now connect your acces point to the computer via network cable. Then open your internet browser and type in adress box http://192.168.1.254 and hit enter, a pop up will apear and ask for user name and password, write admin in both boxes user and password and hit enter, after that you will be able to manually configure your acces point and setup a name and password for your wireless network, change your user and password for acces your device. Good luck!
Mar 23, 2011 | ASI TPL WL TLWA701ND 150Mbps AP Wireless...
None of my power windows on 1998 Mercury Mountaineer work, checked fuses but can't find power relay if there is one. Any suggestions
If you checked the fuses and they are fine, try this. With the key on and the window button down or up, open and close the door holding in the up or down position. If the window moves, there is a wire(s) are broken in the wire harness that goes from the door jam to the door. This is a common problem that we find with window and door operating problems. You may find 1 bad or broken wire, or 4-5 broken wires. Let us know if this help you find a repair, for this concern. Craig
Jan 23, 2010 | 1998 Mercury Mountaineer
Front left window switch is not working. checked
the contact is bad you can check this by switching the wires and you can get the front window down, this will verify the switch is bad and need to be replaced for the front window and all the others to operate properly
Oct 18, 2009 | 2000 GMC Jimmy
Where is the low pressure access port located on a 1993 honda civic del sol?
Low side acces (A/C) is in the suction tube, between the compressor and the firewall (thicker tube)
May 12, 2009 | 1994 Honda Civic Del Sol
All 4 windows won't go down
_________________________________
Passenger Compartment Fuse Panel
Fuse Location: 11
Fuse Amp Rating: 10 Amp
Description: Ignition (START) - ON/ACC (window and decklid) relay coil and Police ON/ACC relay coil (Police vehicles only)
Power Distribution Box (Under Hood)
Fuse Location: 304
Fuse Amp Rating: Full ISO Relay
Description: RUN/ACC relay (windows and decklid) (police vehicles only)
Fuse Location: 602
Fuse Amp Rating: 20A Circuit Breaker
Description: RUN/ACC relay feed (windows and decklid) (police vehicles only)
Mar 26, 2009 | 2005 Ford Crown Victoria
Cant open acces panel on washer
no panel to pull off ..remove 2 screws on rear of console ..pull console forward and roll back ..clip each corner remove and lean cabinet forward and lift off ..pressure switch hose is right rear and runs up back to console
Aug 28, 2008 | Whirlpool LSR7333 Top Load Washer
YouTube Videos Logo
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
