Question about Maytag Ensignia MAV2757AWW Top Load Washer
Maytag top loading washer quiet plus, locks up during spin makes
This washer locks up during the spin cycle and makes noise with a burning smell. I know that can't be good,
I had something like this fixed before and they charged my 300+ so I am trying not to go down that road
any advice would be much appreciated.
The belt is located underneath the washer. This a perfect place for small items like socks to get tangled up in it, and cause the belt to stop while the motor spins.
This belt is tensioned and easily replaceable.
Belt part number is 21352320
Call an appliance repair shop and if they don't have it, ask them who they call for parts. Cost you about $30 with shipping.
Watch out for teens who just throw a big pile of whites at the machine top load.
Now you know what happens to the missing sock.
It's a conspiracy of sockdom.
Posted on Feb 25, 2010
What's the solution??? Replace belt's? Or replace drum brake?
Posted on May 18, 2009
  • 463 Answers
Either the drum brake is going bad or is bad,
or, if the unit is belt driven, the belt is slipping, and the friction on the belt is causing the rubber to melt, making that nasty stench you smell.
Posted on Mar 06, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Washer has been making an unusual amount of noise / burning smell
remove the door and screws on opposite side and the front comes off. Then the top will flip up.
Nov 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Maytag Ensignia MAV2757AWW Top Load Washer Logo
268 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
