Question about Kenmore Dryers
Kenmore 90 Series Dryer start button humms, but that's it.
I have a Kenmore 90 series Dryer. A few days ago when I was doing laundry I would push the start button and it would struggle to get going, but it would go. BUT it would also stop before the time was up. Now when I push the start button it just hummms and won't actually start working.I have taken the dryer apart (to see if the belt was broken...it's not.) I have cleaned everything out...lots of lint. If I put things back together, will it work? If not, how much will repairs cost? Or should I just buy a new one. It's 10 years old.Thanks!
  • brandiginn Mar 11, 2009
    THANK YOU Mike!
    It WAS the motor. AND we fixed it!!! The motor was $150. I took the whole dryer apart. My husband and I both removed/replaced the motor and then put the dryer back together. We took a few close up pictures along the way so we could "see" how the wiring went back together.
    And the moment of truth...pushing the start button. ;) It all came back on and seems to be working fine.
    We'll see if there are any problems today as I attack the massive laundry build up by my family of 6.
    Thanks for your help!
    Brandi
    Genius:
  • 1,122 Answers
MOTOR HAS GONE BAD,IF YOU WANT TO TACKLE IT THE MODEL NUMBER IS INSIDE THE DRYER DOOR,YOU MIGHT FIND A GOOD DEAL ON EBAY OR GO TO SEARS.COM UNDER APPLIANCES,LET ME KNOW AND I WILL HELP YOU WITH IT-MIKE
Posted on Mar 08, 2009
  • MIKE major Mar 11, 2009
    gret job,always check ebay or your local appliancex part store first for the best prices-mike
I have a Series 90 Kenmore Dryer that will not start. I cleaned out the blower assembly. The timer works fine and it was drying and working up until a few hours ago. Now you push the start button and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 17, 2011 | Dryers
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
heatman101
Jun 30, 2011 | Kenmore Dryers
I have a kenmore 90 plus series model # 11068972892............... when i push start button the dryer motor will humm and mabey start to run or it will just humm and not run at all..if it...
Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
Sep 06, 2010 | Kenmore Dryers
Kenmore Dryer-90 Series- Pushed Start button nothing happened
get a meter,unplug the dryer and read out the fuse,pull one of the wires off when you read it out,also when was the last time you cleaned out the dryer?if it's the fuse usually the air isn't moving very well,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line and make sure the outside vent is clear,if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the vent line,make sure you have 240 coming in at the back of dryer,you could have a blown fuse,if the thermal fuse is good,check the thermostats on the heater box and read out the heater,good luck,if i can help with anything else let me know
Mar 26, 2010 | Kenmore 62802 Electric Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Kenmore 80 Series Dryer makes loud humming noise while being ran~
good for you a fixya girl. usually, the idler pulley fails. and is a gravy cheap fix. these are great dryer and worth throwing a few bucks at. spin all the pullies and a new belt is a good idea,
AND
How to Replace Kenmore Electric Dryer Idler Pulley How to
LET ME KNOW HOW YOU DID, THE PARTS SHOULD RUN UNDER $20 that's a cool fix !
Jun 09, 2017 | Kenmore Dryers
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
Kenmore Dryer 90 Series will start but suddenly stop...
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
194 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
