Question about HP Officejet 5610 All-In-One InkJet Printer
WANT SCAN. I CAN FAX AND PRINT, BUT I CAN NOT SCAN. ITS TELLING ME THE DEVICE IS NOT HOOKED UP?
  • oleman1941 Mar 07, 2009
    please disgard on the 5610 all-in one printer. i have resolved my problem. thanks
  • 4 Answers
Could u plz tell me wat is the exact error
Posted on Mar 07, 2009
  • virendra_jha Mar 07, 2009
    please download the complete and updated software from hp.com and install it if u can give me the complete error msg i will help u in resolving this issue
Keeps telling me it is off line-how can I correct it so I can print
First check on the device and printer under control panel if the status of your printer is offline or ready. If it is offline check your usb cable if properly connected and if ready state then if you send print job set to offline try to reinstall the driver. hopefully it will help you.
May 13, 2015 | Brother Fax-2840 High Speed Mono Laser Fax
HP 4300 officejet fax mode to print mode
Hello etilton
Are you trying to print from a pc or do a copy?
Button 11 Fax: Places the HP All-in-One in fax mode and presents the Fax Menu. Press Fax
repeatedly to scroll through the options in the Fax Menu.
Button 12 Scan: Places the HP All-in-One in scan mode and presents the Scan To menu for
selecting a scan destination.
Button 13 Copy: Places the HP All-in-One in copy mode and presents the Copy Menu.
Press Copy repeatedly to scroll through the options in the Copy Menu.
heres the rest of the manual pdf reader required
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
If this solution was any help at all please press accept or ask more questions with the other button.
And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
May 04, 2008 | Office Equipment & Supplies
Keeps telling me to enable bidirectional communication
Hi:
When you first loaded the print driver there should have been a box to check to enable bidirectional communication. Most Lexmark printers require this to work properly
Andrew.
Feb 27, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Never send a fax how do i do it?
Assuming the fax machine is properly hooked up...
Put the paper in the scan slot facing the right way (usually with the print away from you).
Dial the number, then click OK or SEND. The fax machine should do the rest.
Oct 15, 2009 | Office Equipment & Supplies
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Wireless
Printing you could do through a wireless print server. The other day I hooked a copier up into customers office using this device Netgear device:
http://www.bestbuy.com/site/olspage.jsp?skuId=7250707&st=wireless+print+server&lp=2&type=product&cp=1&id=1115366648118
By plugging the ethernet connection from the copier into the ethernet port of the wireless adaptor. I was able to use it as a scanner. Now the wireless print server was converted into a wireless access point. It's works quite well.
Nov 15, 2008 | Canon PC-860 Black and White Copier
Hp laserjet m1319 mfp series
Are you using the software that shipped with the machine? I use the" HP Scan To" program which allows me to scan it to a slew of file types.
The only downer: I can't put the software on more than 1 computer. Apparently, it recognizes that the printer is hooked up to another machine and won't let me install any drivers on other computers (except the print driver).
Sep 25, 2008 | HP Laserjet M1319F Laser Multifunction...
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
