Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Dumb Question Are Rinnai and Toyostove the same unit? I have a Laser 73 AT, I'm searching the Net for parts,are these guys the same? Does a new blower with case come pre-assembled with the fans and and gaskets and just bolt it in? Thanks Mike U.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Mike,
NO, Rinnai and Toyotomi (Laser) are not the same. A simple Google search would make that clear. Now, a new blower motor with case for a Laser 73 comes complete. Fans, motor and gasket all put together, ready to plug in and go.
You would be better off contacting a local dealer for your parts. NO authorized Toyotomi dealer is supposed to sell parts over the internet. A Toyotomi dealership is a valved item. It is meant to help sell and service the Toyotomi product in the dealers local area. It is a great help for someone to be able to call his local dealer and have that guy come right over and help you out.
Saty warm,
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Posted on Mar 07, 2009
New fuel pump.removed fuel line to burner ,turned unit on very small amount of fuel beinng pumped
Don't forget, the pump does not turn on for 60-90 seconds after the unit starts as part of the start up purging cycle
Mar 07, 2015 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 73 has EE8 code after we had an electrical outage. The blower fan is not stuck. Could the loss of power damage the fan motorr? Where do we purchase a new fan motor?
Probably wasn't so much the loss of electric power, as it was perhaps, a surge when it came back on that could have damaged the fan motor
You should be able purchase a new fan motor from the dealer your bought the heater from. Or if that's not an option, go to http://www.rinnai.us/ and search for a authorized dealer close to you. That way, you can be sure you're getting an OEM part.
Hope this helps resolve your problem.
Feb 26, 2011 | Rinnai Toyostove Direct Vent Heater:...
Put toyostove laser 73 back together, where to replug wires?
There is a letter on each plug. Look on the circuit board and there is a letter next to each connection. Just match up the letters. If you have any trouble contact me a nitensheaterservice@earthlink.net
Nov 03, 2010 | Rinnai Toyostove Direct Vent Heater:...
Toyo laser 73 error code EE8. What does that mean?
All error codes are explained on the lower left side of the heater. The EE8 message is for the combustion blower motor. If your stove has been unused for the summer you may get away with just spinning the blower wheel by hand to free it up. If this does not work you are in for a new motor or assembly. Either way you need to clean the blower and heat exchanger.
Tom
Aug 23, 2010 | Rinnai Toyostove Direct Vent Heater:...
My laser 73 heater has an error of ee8
Hello
An ee8 message refers to the combustion Blower motor
Unplug unit
Take off front cover
There is a rubber hose from blower case to the base of the unit
Take it off carefuly
Use your finger or a Pencil to try to move the intake fan
Resemble unit
If this doesn't work you may have to replace Blower motor or just clean it up.
If you can't figure it out gimmie a call Total Toyo (907) 488-9179
Dec 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Laser 73 Heat exchanger loose part
GM,
As I mentioned in the last post, you are in need of a big overhaul. The heat exchanger baffle that has become detached is a sign of a heater that has been running very hot. When you get down into the burner you may find a warped bottom. If so, you are looking at a new burner, and heat exchanger. The burner ring and several gaskets will also need replacing. All the above will run around $600+. Despite the high cost of parts you are better off rebuilding than buying new by $1000 or so. When you look at it in the long run you are spending $60 or so a year for the 10 years you have owned the unit. Not bad, I'd say.
good luck,
Tom Hawkins
hawkins111@gci.net
Mar 09, 2009 | Rinnai Toyostove Direct Vent Heater:...
EE 8 code on TR-73 toyostove!
If you can't get rid of the EE8 message and you think the motor is really turning it may be turning too slow. This will be caused by corrosion that has dripped down into the blower and gotten on the Rev sensor. The solution is to change the motor. If you are not handy with tools you may have to just change the whole blower. The motor is around $150, the whole blower is $350. The corrosion may have happened over the summer and fall.Heating and cooling causes condensation and the water drips down into the blower.
Tom Hawkins
hawkins111@gci.net
Feb 25, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 73
There are 2 fuses on the mother board. You can go to the Toyotomi website download the Owners Manual and look at 49 and 50 in the parts list and picture.
Mar 05, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
183 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
