Question about Bush 5693D 24" TV
Bush TV Model No 5693D
When swiched on screen shows:
"NO SIGNAL"
although three aerials tried all work with another TV.
Does this TV require perhaps require digital input ?
  • Bush Master
  • 19,396 Answers
Try using the source button to switch through different inputs.
If that does not work try connecting a signal booster to the aerial, they cost about ten pounds at Argos.
Posted on Apr 29, 2009
My channel 7 keeps freezing and comes up with no signal sometimes for days when it's though my my bush digital recorder box. But when it's just though the tv channel 7 works fine. What's going on??
Different digital boxes and tv's have different levels of RF gain. Some need more signal and some need less to work efficiently.
Possibly your Bush pvr needs a much stronger signal than your tv so the available signal is permanently on the threshold of reception and atmospheric conditions will some of the time reduce the available signal when reception will become impossible for the box but still be above the threshold for the tv set.
Modern Bush is not reknown for being a high quality brand and the purchasers of budget brand pvr's often discover reception or performance problems in fringe signal areas. Because a single aerial must receive a very wide range of frequencies it will be more efficient for some channels than others and so one channel could be a fringe channel and another channel produce a very strong frequency.
The signal strength and quality can be checked for each channel by selecting options in the menu in order to check this theory.
The problem might be solved by replacing the Bush pvr with a premium brand or replacing your aerial for a more efficient type. One of my friends had five different boxes before he gained a satisfactory performance and another friend three boxes and still has problems.
My installation has a new high gain wideband aerial on top of my 3 storey house and a distribution amplifier in the loft to keep the input lead short and the whole lot connected by very good quality double-wrapped co-ax.
I had to add different amounts of attenuation for each box or tv set but in spite of the signal being on average too strong and needing attenuating there are still channels for which the aerial is not as efficient and providing only a weak signal.
Feb 09, 2015 | Bush Televison & Video
When I switch the TV on I just get a message 'No Signal' ,this also happens when I try to play a DVD. The TV is on and I just get a blue blank screen. The other TVs in the house that are all...
You might be on the wrong "channel" on your TV. On the remote for your TV, there should be a set of buttons for if you want the remote to control the TV, or DVD player, or Aux 1 or 2. You want to click the TV button and try changing the TV's "channel". Your cable/DVD player are on different "channels" of the TV. Try scrolling up and down through the "channels" of your TV.
May 25, 2011 | Bush 5693D 24" TV
Have an alba tv with bush dv3 but cannot get signal
not able to play wii on av channel - just comes with blue screen and count down timer? Have connected to the require colour codes on tv
Jan 01, 2010 | Bush 5693D 24" TV
No picture only a blue screen
A blue screen usually means no signal is recieved or supplied - try changing channels to ch. 3 or hooking up a dvd player, if available, to video inputs and select that input on the TV.
Oct 14, 2009 | Bush 5693D 24" TV
TV screen dislay partial horizontal beam
This is a problem with the vertical circuit. Look for a small flat IC attached to a heatsink that will be marked LA7837 or something similar. It should have about 11 pins. Try resoldering the pins on that IC first. If that does not resolve the problem, replace the IC. There may be capacitors that require replacement in that circuit as well.
Keep us posted.
Dan
Oct 07, 2008 | Bush 5693D 24" TV
Bush 2874ntxs aerial problem
i messed around with the remote, searched for my 5 channels and found them on uhf, stored and now i can look at my tv, thanks, gra.
Jul 04, 2008 | Bush 5693D 24" TV
Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Jun 17, 2007 | Bush 5693D 24" TV
White line horizontially through middle of picture
A repair like this is in the vertical drive/output section of the TV set. It could be a simple capacitor causeing this problem or a combination of the capacitor and the output IC. A repair like this should not exceed 120 to 150 US. Is it worth that to you? How much can you replace it for? Good Luck PS please dont forget to rate this thread.
Oct 25, 2006 | Bush 5693D 24" TV
Bush 5693D 24" TV Logo
238 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
