Question about Plumbing
Mira thermastatic shower problem,pressure&temprature.
I have a mira thermastatic mixer shower installed 2 years ago along with a new combination boiler,the showers been going fine until lately when its started going hot then cold(without any other appliance on&no other taps running)the pressure goes up&down to for no apparent reason.the pressure(bar)on my combi is set at 1,ive put up up to as high as 2 to see if that would make a difference but problem still persists!it was an expensive shower so i would appreciate any assistance!cheers.
  • 3 more comments
  • bov1873 Mar 07, 2009
    the water were i live in scotland is not hard water.how would i take the mixing valve apart?
  • bov1873 Mar 18, 2009
    got mira plumber out and the cold feed into the shower is blocked somewhere in the main pipe so awaiting plumber to clear the pipe.
  • bov1873 Jun 14, 2009
    cut into your hot&cold taps at your bath with t joins and take the feed for them for your mixer shower!just blank off the old shower pipe.its very easy to do especially with flexi pipes and push fittings.you cant go far wrong.
    cut into your hot&cold pipes going up to your bath taps & fit t pieces then take them up to your shower!very simple to do with flexi pipes and push fittings.a local plumbers merchants will keep you right!blank off the pipe going into your old shower as your supply will be coming from your bath pipes.take your time&enjoy it!
    i would just cap that old shower pipe&take your feed from the hot&cold water pipes going into your bath!just cut into them and fit a t piece joint and take the pipes up to where your shower will be located.sounds hars but its easy with flexi fittings,push fittings etc.your local plumbers merchants will keep you right!
    Genius:
  • 1,055 Answers
You mixing valve may be going bad,do you have hard water? you may just need too take it apart and clean it
Posted on Mar 07, 2009
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
Got mira discovery mixer shower. wont get hot just luke warm or cold. taps in rest of house ok? Had it off the wall recently to tile behind it but apart from that been great for 6 years. any ideas?
There should be a hot water limiter behind the knob on the shower - shingle handle, undo the handle and move the adjustment to allow more hot water. Not familiar with mira discovery mixer
Feb 03, 2013 | Home
After about a year after installation our mira thermo shower has started to run cold after about half a minute or so. The same thing happenned to a previous cheaper type of shower which is why we replaced...
Your shower valve has an temp equalizer valve in it, you will have to take it apart, clean all the calcium or debris from it. flush out the hot and cold lines with valve dismantled , cover drain to make sure you don't lose any parts. reassemble with Vaseline. good luck.
Mar 14, 2011 | Home
Mira Excel Mixer shower, it doesn't seem to have an output of water even when connected to a fairly high pressure supply, why is this?
Most shower heads have a flow restrictor in them to meet calf. standards. These can usually be removed but check your local and state laws first. Thanks
Nov 19, 2010 | Home
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
I I have a 3 way bath/shower/overhead shower mixer valve to fit and am not sure where the pipes should go, there is a hot and cold feed in, but only 2 feeds out, I need feeds for 1. bath filler, 2....
When installing a flexishower head, install it in front of the actual shower head with a diverter switch. If you try to operate two shower heads at once, you may suffer poor water pressure. There are handheld shower sets sold which are installed to existing shower assemblies with ease. Rememer to use plumber's tape and protect your stainless steel by wrapping you pliers teeth in electrical tape.
Jan 15, 2010 | Delta 3 Function Showerhead & Grail...
We have two 16 year old shower faucets (house was built in 1993 by Del Webb). Can't tell what model they are. We are guessing they are Moen Legend 3175 (one handle). Problem seems to be pressure balancing...
This is a common problem with this type of shower mixer valve. They are not very good at regulating with pressure change. Your options are somewhat limited to not flushing the toilet or using any other taps when in use, repalce the mixer valve for a modern ceramic unit or installing a 2 vane hot & cold shower pump.
Nov 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Installing a Mixer Shower from a Combi Boiler.
hi there, your boiler will perfectly match the mira excel ( a great choice i might add) a 24cdi will give about 9.8 litres a minute flow rate hot water.
The mira excel is suitable for any plumbing set up and there installation instruction are very well laid out & their helpline is fantastic.
The hot water will fluctuate accordingly to the time of year as the cold water temp coming into the property will vary. but the boiler will modulate to compensate.So in brief in the summer you will notice it hotter than you would in the winter, this has nothing to do with the boiler just the incoming temp of the cold water.
Kindly
Richie
Dec 15, 2008 | Home
Plumbing Logo
1,298 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
