Question about Garden
I have a broken primer bulb for an Echo CS-3400 chainsaw. I need to replace it but am not sure how to remove the old bulb. I can access it but am not sure if it will be necessary to remove all the guts of the saw to get it out.
  • fvmany May 03, 2009
    Broken purge bulb. Easy to remove air filter cover but not at all obvious how to free it from the black ring holding it to the housing.
  • 42 Answers
You should be able to get to it if you just take off the cover that surrounds it. If you do not yet have a bulb purchased, I would reccomend trying the site I have below. I have also put the part number you will need to enter in the 'Search' box on the site to get the right bulb.
web site: www.m-and-d.com
Part #: ST-615-811
Posted on Mar 07, 2009
Echo Cs-400 chainsaw. Standing the carb up with the sliver vent on top which fuel line goes to the 90° inlet on the bottom and which line from the primer bulb to the carb?
The lengths of the line and,or the bends in the line . I would say the line from the bulb would go the carb since it is used to prime or,choke the carb.
Apr 05, 2015 | Echo Garden
How do I replace the primer bulb on an Echo cs-346 chaln saw?
The part number is 12318139130 and this youtube video covers this part's replacement.
http://www.youtube.com/watch?v=cnzag2RqhRo
Jul 12, 2014 | Echo Garden
How to replace a primer bulb
Small engine shop will have that part u will need make ,
model , s/n some small bolts out with old in with the new good luck
May 29, 2014 | Echo Cs300 Cs 300 3000 305 3450 Top Handle...
Remove case top
What is it exactly are you trying to do? replace the primer bulb?
Apr 09, 2014 | Echo Cs 340 Chainsaw Oil And Gas Caps
BRAND NEW ECHO CS-600P HARD STARTING, HAVE TO PULL THE RECOIL LIKE 20 TIME BEFORE IT WILL START.
Are you pumping the primer bulb until fuel flows into the bulb, setting the choke, and the fast idle is being set? Set the choke at half position after the first 'pop' and don't touch the throttle until it starts running. If you are doing these things per the instructions, take the machine back for warranty adjustment. Hope this helps!
Nov 03, 2010 | Echo CS600P Gas Chainsaw 20 Inch
How to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Apr 04, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do I change the primer bulb on my Echo CS-3000 chain saw
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Sep 06, 2009 | Echo Garden
Garden Logo
747 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
