Question about Samsung 1000W 5.1-Ch. Home Theater System with Upconvert DVD Player
Losing picture while watching dvd
During play of a movie, i lose the picture, but the audio is still there. i have tried different hdmi cables and it is consistant. however, losing the picture doesn't always happen - very random. i have tried to isolate the problem and it is definitely in my dvd player. i have sent my dvd player back in and it was gone-through and guaranteed, but is still doing the same thing that it has always done. not every movie and completely random. could it be in the dvd itself? possibly the connection to the cable?
  • sportsmom586 Mar 06, 2009
    Thanks Glenn - I will try this solution tonight!!! Its beginning to drive me crazy. I'm keeping my fingers crossed! Thanks again
  • shelforjr88 Mar 11, 2009
    i have a the same problem except my picture flash every ten to twenty minutes apart and does it about half way through the movie. i brought the forty dollar hdmi cable from bestbuy which is the best cable
    Novelist:
  • 91 Answers
Your in luck , I just had the same exact issue and it was driving me crazy! and here is the solution ,check the hdmi cable sometimes the bend in the cable is enough to make theese highly sensitive cables cut their signal where the picture goes out but the sound is still on , i have a entertainment cabinet that houses the stereo/lazer disc player/blue ray player / and power amplifiers , well this cable along with other hdmi cables was a cheaper guage wire ,so i replaced it with a guage wire hdmi and never had the problem again , if you take your hdmi cable and just sort of press up against it and move the wire with your hand ,you will probably see your picture cut out , the conector pins that the hdmi cable plug into are like little needles and they are extreemly sensitive to movement and especially the cheaper cables , if you have a better hdmi cable just switch them and you will see what i mean , Another way to test it is to just use component cables and see if your picture cuts out , if it dose,nt then you will know for shure its the hdmi cable , Hope i was able to help you fix your problem , if i was of help please leave a nice rating for me , sincerely glenn mayer and good luck!
Posted on Mar 06, 2009
How do I repair our Samsung LCD Television? I would really appreciate an answer ASAP. Where will my answer appear for my review.
Don't know what service provider you have, free to air, satellite, cable or what? Try feeding the TV another signal and see what it does. Play recorder movie from DVD, or if you have a VCR around even try that. If it plays the DVD etc, with no issues, then TV is not the problem, most likely the cable box, satellite box etc, could be as simple as a bad cable connection at the house, a splitter or street box. Eliminate all the simple things first, then look at the TV.
Mar 04, 2015 | Samsung Televison & Video
Hdmi audio working not video
Have you tried a different HDMI cable? Could be a lose connection in the cable.
Oct 03, 2017 | ASUS Q500A-BHI5N01 Laptop i5 2.5GHz 6GB...
Hdmi on tv loses signal
Try another HDMI input on your set and see what happens.
Jul 26, 2017 | Panasonic Viera TH-50PZ80U Plasma TV
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
While watching blue ray, the receiver loses the Signal
check the continuity of the AV Cables and check for any loose connection/dry solder in the connectors
Jul 13, 2009 | Yamaha RX-V861 Receiver
Dvd to amp to tv hookup has little to no connections
It is a lose connection symptom when you wiggling the chord it will be fine it is a cold solder its needs to resolder the connection base so it become firm and works normal again.
Hope it may helps you;
Regards:
VOTIT
Mar 23, 2009 | Yamaha RX-V463 Receiver
Blu ray not playing on ps3
Could be an overheating issue.. Is there enough air circulation around the unit? Is it possibly dusty? try and perform minor servicing (use a can of compressed air incase if there's dust causing problems)
Does this happen on regular dvd's ?
Jun 15, 2008 | Sony Playstation 3 (PS3) Console
Major problems with PS3 and viewing Bluray movies
did you uncheek the other options when choseing 1080p or it might be your receiver because you have to set that to make the picture quality as much as the ps3
May 19, 2008 | Sony Playstation 3 (PS3) Console
Video disappears within 30 seconds
Hi Mark
I am going to take a stab in the dark here...
Did you plug the hdmi from the receiver to hdmi via the monitor hdmi output? this is needed so when you change the device on the receiver ie. between setop box and dvd the monitor changes with it accordingly.
You may also need to go to the setop box to set it to use hdmi output at the right frequencies too..ie. 720p 1080i or 1080p.Also set it so it only sends the picture via hdmi but audio still with optical out.
good luck
smeags
Jan 08, 2008 | Onkyo HT-SR800 System
Rca hdtv m50wh754s
You need a audio cable for sound. HDMI cable is only for picture. I use the comp 1 plugs myself, better picture. I found with my TV that the HDMI cable is only good if you have a digital box for it. You can also use the plug to hook your computer to off your graphics card and watch downloaded movies on.
Oct 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
Samsung 1000W 5.1-Ch. Home Theater System with Upconvert DVD Player Logo
283 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
