Question about Connecticut Electric & SWITCH UBIP130 "PUSHMATIC" SINGLE POLE CIRCUIT BREaker
I have a home built in the 50's. circuit breakers are pushmatic. 7 breakers on a side. The locking bar down the center will not allow me to replace 2 single pole breakers with double pole. It's for an electric dryer. What type of breaker can I use?
  • 44 Answers
You need to put in what we call a sub box. This should be done by a licensed electrician, but if you really want to do it yourself you will need a distribution box some wire and it has to be connected directly to your main lags from the meter box, this box will have a main breaker built into it and spaces for additional breakers, depending on your existing wiring the electrician might chose to wire the additional box directly to your meter base and not your existing box. Either way you really should seek local professional help on this project, just for your safety and to satisfy your home-owners insurance.
Have a great day..
Tim
Posted on Mar 24, 2009
Can i make a 40 amp circuit breaker with two 20 amp breakers?
Yes. A two-pole breaker is just two breakers hooked together. But the very important part is that if one pole trips THEY MUST BOTH TRIP. If only one trips, then the circuit won't operate the appliance (whatever it is) but one of the poles will still be live!
Jul 19, 2012 | RTO Pushmatic 40Amp 2-pole circuit breaker
I have three bulldog pushmatic circuit breakers that will not push back in? Are they gone or can they be reset.
Either they are bad, or are "tripping" If they won't push in when removed, then they are bad. Not unusual. You can still buy them. Look online or Box stores
Jun 17, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
I need to buy a 20/20 Amp Bulldog breaker for a dryer and any installation tipes
Most electrical dryers are 220 volt. They usually require at least a two pole 30 amp circuit with #10 wire. The breakers you need can be found at most hardware and buidling type stores, Ace , Home depot, Lowes.
Yes they would have the 20/20 breaker also.
Please Vote !!
Apr 24, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
Pushmatic breaker keeps tripping everytime I hit
You have it shorted out somewhere along the line. If it is a light switch you are switching, what have you done lately to make this trip? Anything? You might have a bad breaker. You can check it by shutting off the power, pull the wire out of the tripping breaker, put it in another breaker, turn the power back on, switch the breaker on, then hit the switch and see what happens. If it snaps off, it is not the breaker, but the switch, the wires in the box, or the lights, or something along the line, you will have to check each one. New construction has made all lights and all receptacles separate, so if your house is old, you might be looking at receptacles too. Check anything plugged in to an outlet, make sure there is nothing shorting. Hope this helps.
Apr 03, 2010 | RTO Pushmatic 100Amp 2-pole circuit...
Breaker wont push back in
it is still detecting an overload in the circuit. Take the black wire off the breaker and see if it will reset. If so then you will have to trace the wires down to find the short circuit. If it doesn't reset then the breaker is bad
Jan 25, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
My Mom (86) has a bulldog panel with an intermittent 15 amp breaker. How do I remove it?? I was afraid of putting a screwdriver in between it and the main verticle strip (buss bar) and prying it out after...
The pushmatics get sticky more than trip when they shouldn't. Are you sure your Mom isn't just overloading that circuit? If so, changing the breaker or even changing the panel won't help.
Some Bulldog panels have the main breaker separte to the side of the branch circuit breakers - under the meter. I think some of them are designed so that you can de-energize the bus by turning of two of the top breakers, but I'm not sure.
You definitely shouldn't do this live. Have a meter to make sure it's not live when you do it. It would be very easy for your screwdriver to touch the bus bar and the metal frame at the same time.
But, again, maybe the problem is too many things plugged in.
Dec 23, 2009 | Bulldog Electrical Supplies
How do you replace one
It should tip out, probably from the center to the right or the left.
Did you purchase it yet? Your best bet is to go to a electric supply place, NOT THE BIG BOX PLACE, and as you purchase it, talk with the guy that is selling you the product.
You are replacing it in kind, right? Remember,it is the wire you are protecting -
Thanks for using FixYa.com
Oct 29, 2009 | Bulldog Pushmatic 31115 P115 15 Amp...
Pushmatic 15amp breaker was buzzing. I turned it off and then pushed it to on again and the bussing was gone. Is the breaker going
Not necessarily, if the buzzing stopped then its probably ok. When a circuit goes bad, either they fail to trip open, or will not reset to the on position
Aug 02, 2009 | Bulldog Pushmatic 31115 P115 15 Amp...
Looking for 2 15amp single pole pushmatic circuit breakers.
A Google search for "15 amp pushmatic" turned up several links. Here's one for a retailer with new ones and an eBay store with cheaper prices (maybe pullouts):
http://www.aplussupply.com/break/push/push.htm
http://stores.ebay.com/Sparkys-Place_Pushmatic-Categories_W0QQfsubZ10975954
Did you also check the big-box stores like Home Depot or Lowe's or electric suppliers in your area?
Feb 11, 2009 | Connecticut Electric & SWITCH UBIP130...
Connecticut Electric & SWITCH UBIP130 "PUSHMATIC" SINGLE POLE CIRCUIT BREaker Logo
202 people viewed this question
Top Connecticut Electric Electrical Supplies Experts
Steve
Gene Haynes
Steve Pack
Steve Pack
Are you a Connecticut Electric Electrical Supply Expert? Answer questions, earn points and help others
