Question about Graco Snugride
How do i remove the graco snugride visor? I need to wash it
4 Suggested Answers
SOURCE: Graco Snugride canopy
Slide the fabric all the way to one side to expose the center clasp (hook). Then using both hands grasp the clasp like you were putting you hands on handelbar (placing your thumbs under the bottom of the clasp about 1 inch apart). Then push up with your thumbs while pulling down with your fingers (which should be wraped around the outside of the clasp). You will need to push with your thumbs all the way up in order to separate the two pieces (note - it feels like you are going to break it but you wont).
Putting them back to gether is just a matter of aligning the tabs in the slots and pressing the two parts together.
Posted on Dec 20, 2008
busboy2
  • 50 Answers
SOURCE: Washing canopy on Graco Snugride
if the wash is hot you might melt the plastic parts
Posted on Mar 01, 2008
connorsmama
  • 20 Answers
SOURCE: i want to install the graco snugride carseat,but i
hmm thats easy, theres big hole in the base stream the seatbelt through thsoe and tighetn, if u have ltch., EVEN BETTER! they should already be attached but if not feed through the same holes as regulare seat and tighten (i personally kneel in the base to tighten them up!)
Posted on Jun 26, 2009
  • 903 Answers
SOURCE: install graco snugride to a graco stroller
Fitting your Graco Snug Ride infant seat into a Graco stroller is usually easy to do -- the exact instructions just depend on which stroller you have. Typically, all you have to do is fold the stroller's canopy back, recline the seat (if it reclines), and snap the car seat in (backwards -- facing the rear of the stroller). You can hear it lock in place when it's in correctly. Your stroller's manual will have specific instructions, and if you don't have the manual you can find it online.
Which Graco stroller do you have?
Posted on Nov 16, 2010
DO GRACO SNUGRIDE INFANT CAR SEAT BASES WORK WITH A DIFFERENT MODEL?
Some do, some don't.
From Graco's web site:
What base will work with my car seat?
We have designed many of our car seats to work with more than one base, for your convenience. Please see the chart here for Classic Connect models.
The SnugRide Click Connect 30, 35, 35LX and 40 infant car seat carriers are compatible with any SnugRide Click Connect infant car seat base. Consumers should adhere to the height and weight requirements for the SnugRide Click Connect infant car seat carriers as stated in their owner's manual; however, the SnugRide Click Connect 40 infant car seat carrier is restricted to a height limit of 32 inches when used with a SnugRide Click Connect 30, 35 or 35LX base.
Jun 15, 2014 | Graco Baby Gear
Will a graco snugride car seat fit in the safety 1st double tandem stroller 01668sha?
Hi
Safety 1st do not produce adaptors for a Graco carseat to be fitted to the DuoDeal Tandem. This stroller chassis is not designed to be used with a carseat.
Duodeal Tandem Black Iron
Jan 25, 2014 | Safety 1st 01668 Two Ways Tandem - Sahara...
I cant find what type of snugride i have
Hi Amanda,
We would recommend you contact Graco directly for assistance.
Jan 02, 2014 | Graco Baby Gear
Install graco snugride to a graco stroller
Nov 24, 2009 | Graco Snugride
Dismantleing canopy
If this is for the Graco Snugride (I have the Windsor model from the Quattro Travel System), this will work:
1. Push the Graco canopy to one side, exposing the plastic support bars that hold the canopy in place.
2. The center of the support is where the canopy comes apart. Using both hands, pull the canopy support
bar apart (as if you were playing tug-of-war). It's best to grab the curved ends and pull HARD (and point it away to the side so that you don't hit your face).
3. Once the support bars are apart, remove the old Graco canopy and slip on the new/freshly washed canopy.
4. Secure the support bars by snapping them shut, and then slide the canopy into place.
Aug 26, 2008 | Graco SnugRide - Clover
I need to know how to take the liner out of the baby car seat so I can wash it.
You have to unlatch the shoulder straps from underneath then unscrew the side handle to remove the elastic. Then your able to completely remove the cover. Just pay attention, because getting if off is the easy part, putting it back can proove difficult. Good Luck!
Jul 27, 2008 | Graco SnugRide - Giselle Infant Car Seat
I have a Graco infant car seat and want to remove the padded seat cover to place in the laundry. There are two elastics on either side of the car seat that help secure it to the sides of the handle. I...
What model do you have?
You can call graco at: Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Ensure you do NOT wash the straps/harness, as it will make it unsafe and you will need to replace it.
They also have an online manual fi that will assist you. I checked my seat, and it is an older snug ride with no straps.
Thanks
Apr 30, 2008 | Graco SnugRide - Giselle Infant Car Seat
Feb 28, 2008 | Graco SnugRide 8649
Graco Snugride Logo
162 people viewed this question
Top Graco Baby Gear Experts
Iron
Iron
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
