Question about Yamaha RX-V663 Receiver
Cannot get my yamaha rx-v663 to decode DolbyTrueHD audio of get my SBL/SBR speakers to work without turning the bi-amp on.
  • Anonymous Mar 16, 2009
    Same issue.  It is only reading PCM from my blu-ray and hd-dvd players.
    Scholar:
  • 144 Answers
You should always connect with HDMI when using and decoding HD sound formats. If you use the normal digital option it will use PCM. Also check if your source is set to HD formats via HDMI connections.
Posted on Apr 17, 2009
I have a Yamaha RX-V663 I have speakers connected to both the Front A L & R and the Surround L & R for now only because i am in the process of getting more. I have my iPod connected through...
I imagine your FM and any other sources suffer from the same lack of a front speaker function.
Page 43: "Press the A Speakers on the front panel repeatedly to turn on or off the set of front speakers...."
Jun 15, 2010 | Yamaha RX-V663 Receiver
Only get low volume out of sbr and sr speakers.
Without knowing what your speaker arrangement is I could not give any definite answer, but it could be caused by using speakers of differing efficiencies or impedance.
May 26, 2010 | Yamaha RX-V2700 Receiver
With my RX-V663 can I use presence speakers less than 8 ohms?
Basically you can use any speaker as long as you use the volume button wisely. Damage will only occur if you raise the volume level to the extremes. Bigger speakers should be no problem, if you want bi-amping, your speakers should support that as well.
Apr 10, 2009 | Yamaha RX-V663 Receiver
Decoder problems
OK, use the down mix function on your blue ray player. this will decode for your receiver. the down mix feature should be located in the audio options on the blue ray menu screen.
Mar 16, 2009 | Yamaha RX-V663 Receiver
Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
Mar 11, 2009 | Yamaha RX-V663 Receiver
Cannot get yamaha rx-v663 to play DDTrueHD or DTS HD audio
If your Blu-Ray player has TrueHD or DTS-MA decoding, then it will send a already-decoded audio signal to your receiver. The receiver should then just recognize this as "Straight" decoding, because it isn't actually doing any decoding.
Hope this helps.
Mar 01, 2009 | Yamaha RX-V663 Receiver
Tv speaker noise from yamaha rx-v663 hdmi connection
try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial
Jan 19, 2009 | Yamaha RX-V663 Receiver
Onkyo ht-r530 Receiver troubleshooting
the 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
Jan 12, 2009 | Onkyo Audio Players & Recorders
Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V663 Receiver Logo
251 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
