Question about HP Color LaserJet 4550n Printer
Hi, I just bought new hp printer all in one a month ago and I have been printing a lot for my daughters school project, so I refilled the ink more than 3 times and it always work, but then this time it shows in my computer screen that I really need to buy the original cartridge,in short my printer is not printing although it is full with ink since I just refilled it. Ehat can I do,it seems like the hp printer is sensing that the cartridge has been refilled many times. Do you have suggestions how to reprogram my printer not to be able recognize refilled cartridges? I cant afford to buy original cartridge they're too expensive. I would appreciate very much an immediate reply. Sincerely, Vivian
    Genius:
  • 2,120 Answers
Hi Vivian,there is no way reprogram this printer .
Posted on Mar 07, 2009
Do refillable cartridges cause HP 3650 printer to not print????????
Get new ink cartridges. If they sit that long without being used the ink will dry out in the print head part of the cartridge and clog the very small holes. The clogs are inside the cartridge so wiping the outside will not clear the blockage. In the future if you have to leave the unit without it being used for over about a week you should remove the ink carts and put them in a sealed zip lock bag to prevent them from drying out.
Mar 28, 2013 | HP DeskJet 3650 InkJet Printer
When i print from my computer to laser printer, it just printed nothing. When i put paper and print direct from the printer, it did the same thing. I can still do it as scanner, but just can not print. No...
Ibuy A EPSON T-60 printer,i month ago,i use refil ,but i need daily head cleen,blue ink print iresult is not good,becuse,daily head clinig must,If daily head clean my printer can damage?
i am bangladshi, what refil drum is good for epson t 60.what is name?
Thak you SIR.
Sep 21, 2011 | Epson TM-T60 Printer
Failure of Printer to Print Color
Try using a new HP ink cartridge. I had the same problem with a printer I purchased off of CraigsList even though the ink level was good. I installed a new color HP ink cartridge and it printed without a problem.
Jul 29, 2010 | HP Photosmart C3180 All-In-One InkJet...
I refilled my tri-color cartridge at Costco and my printer wouldn't print the alignment page. I bought a new cart and it worked fine. Then I re-installed the refilled cart to verify the fix, and it still...
a refilled cartridge IN NO WAY can lead to printer failure
the ink is the last thing on printer and has no effect to mechanical failures.
check here how you can refill your cartridge
http://www.youtube.com/watch?v=II9gpIXs_lE
Jul 02, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printing problems
If you don't use the printer often it is possible that the ink gets dried inside the cartridge, hence you get the print out with low quality or blurred. We suggest you to use original HP cartridges and keep using the cartridges frequently.
Thank you for using Fixya.
Dec 12, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
My yellow ink ran out and I finally replaced all inks this evening. Now, with all new inks, I keep getting a message that the yellow needs to be replaced. Any suggestions? I've turned off the printer,...
I had the same problem with mine but I bought a refill cartridge instead of a new one and went through three refilled cartridges when I found that it was that I needed a brand new one. For some reason, the HP printers and some other printers need to know that you are using the same brand of ink as the printer. if it is another brand it wont except it and it wont let you print anything! So make sure it is a brand new hp brand ;)
Nov 12, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Black is full, colors are "low", refuses to print anything
If you have a look on this site you will see there are far more reported problems related to Canon than Epson however the choice is yours.
As to your cardridge problem. The Epson status monitor measures the amount of inkshots used by each cart individually. You know they have chips which indicate when the cart is empty and yet you have not bothered looking for a reset programme. Who's fault is that? The manufacture?
Give this a try, make sure to read the instructins before using.
http://www.ssclg.com/epsone.shtml
Sep 14, 2009 | Epson Stylus Photo R200 InkJet Printer
Black ink doesn't print
I've had it with printers!
I'm on my second one and it's costing me a fortune!
It's cheaper to go to the library and make copies or take a disk to a photo printing booth.
My first printer was a Lexmark x73 it doesn't print anymore and I'm the un-proud owner of two almost new ink cartridges but I kept it because it sill scans and quite well I might add!
My second printer is a HP and very very inexpensive! I ran out of black ink after printing about 10 pages in a lot of black and haven't even thought about trying new ink cartrides yet!
I now go to the library!
The problem with some of these printers is that if you don't use them often enough the jets will clog and it will never print again unless you rebuild it while. Others just use a lot of ink and cost a lot!
You could try paying for a FixYas' Guaranteed Solution as it's guaranteed and someone might have a way to get it going for you again!
Hope this was helpful.
Good Luck!
Jan 22, 2009 | Office Equipment & Supplies
Lexmark z615 Printer cartridges not printing
First you might want to try and go to Start>Settings>Control Panel>
Double click Printer and Faxes
right click the printer. Then select the services tab. at the very least clean the cartridges.
Keep me posted,
Lee
Jun 18, 2008 | Lexmark Z615 InkJet Printer
HP Color LaserJet 4550n Printer Logo
97 people viewed this question
Seeker5211
Seeker5211
