Question about Apple iPod touch
I touch loses suond in one speaker or in earbuds, is it the connection ? how do I fix it , can I take the itouch apart and check the connection ?
  • CASEYCARLOS Apr 13, 2009
    WHILE PLAYING MUSIC ON THE I TOUCH THERE IS NONE NOTHING NO MUSIC AT ALL! OTHER THAN PAYING SOME ONE THIRTY DOLLARS FOR SOME INFO. ON HOW TO FIX THIS PROBLEM, IS THERE ANY ONE THAT CAN HELP ME?
  • 143 Answers
Do not open up the ipod yourself. This will void your warrenty instantly.
it sounds like a bad connection. Try your earphones on your computer. And try other earphones or speakers on your ipod. This way you can work out if it is a problem with the earphones or the ipod.
If it is the ipod, you will need to bring it in for service.
if you wish to return the ipod for service, you can find a local apple reseller by calling apple on 1-800-MY-APPLE
Or you can visit an apple retail store by visiting http://www.apple.com/retail/
Hope this helps.
Nathan.
Posted on Apr 14, 2009
I can not hear anything out of my right ear bud
Hi there thobe47!
Please test the pair with a different audio device and see if the problem goes away first!
Firstly, make sure you are pressing the plug all the way into your audio device jack. Most are designed with two tiers, so only one ear will sound if only one tier of the electrical connection is fully established. Once you've tried that, continue!
Most earbuds are created with very small working parts with equally small electrical connections. If you have lost sound in one side, the most likely cause is a loose connection somewhere.
If it still doesn't work, your options are sort of limited. I would recommend first gently "jimmying" the wire leading to the bad earbud around while it is in your ear and music is playing. If you manage to get the sound to be restored, wrap sticky tape tightly around the wire and the tapered part of the bottom of the earbud in an attempt to maintain the new connection. It is not a permanent fix but might buy you a bit of time with the pair.
If you can't get it to work in that way, your remaining options are pretty much to either open the earbud and attempt to reestablish the connection (difficult, small parts, and could damage the earbuds if you don't know what you are doing), or to buy a new pair. You can get some pretty nice earbuds for under $5 at most megastores, and anybody who could fix them and would charge you will charge you much more.
If you must try to open the earbud (I don't recommend it!), I have a generic set of steps here. I take no responsibility for damage of your earbuds or devices that may follow!
Gently peel back the gelly cover of the earbud, starting under the top seam and pulling it off.
Unscrew or "pop off" the portion of the earbud that has the small grating. There may be an inner retaining system involving more plastic rings. Just keep these safe and remember the order in which you took them apart.
You will now probably be seeing the speaker of the earbud, looking like what you might see on an uncovered subwoofer speaker (just much smaller!)
Being careful to not touch the flat portion of this disk and avoiding anything magnetic (including your laptop / desktop), see if you can pinch it by the sides and gently pull it out of the casing -- probably less than a quarter centimeter. If you can, look for any severed connections between the solder points on the bottom of the speaker and the wires coming from the bottom of the bud. Soldering these would be extremely difficult, but you can attempt to fix them with small pieces of tape.
Nestle the speaker back into the housing, replace any retaining disks in the correct order, screw/pop the outer clip back on, and slide the gelly back into place.
Hope this helps!
Mar 24, 2011 | JVC Gumy Ear Bud Headphone - Peppermint...
Tip
Fix Disabled ITouch that ITunes will not recognize
If your itouch reads "disabled connect to itunes" and shows the "locked" icon and your itunes will not even recognize the device and itunes says your itouch is locked and enter password, Here is what you do to restore your itouch: (you will lose all itouch contents but it is worth it as almost all say it is broken and worthless)
1. Turn off your itouch or ipod. Do not have charger / usb connected to ipod or itouch.
2. With device off, connect the charger end of the cable to the itouch / ipod but do not plug the usb into the computer.
3. Open Itunes
3. While holding down the menu button (and I mean keep holding it down), plug the usb into the computer.
4. Wait to see the new wonderful graphic on your device and computer screen that shows that your ipod / itouch is recognized.
Your itouch will start immediately restoring itself and you are ready to fill it up with wonderful images, photos and videos again!
So happy to share this tip. It saved me money and time.
on Jun 29, 2010 | Apple iPod touch
Itouch speaker playing while headphones are connected.
1> Disconnect the ear buds from the itouch
2> Reset the ipod - by holding down the sleep wake button and the home button at the same time until you see the apple logo - the ipod will reboot
3> reconnect ear buds mace sure they are flush with the top of the unit ( no gaps )
play a song to test
**If it is still playing out of both - call apple for repair or go to apple store
May 10, 2010 | Apple iPod touch
My ipod is disabled
While your itouch is connected to your computer, and itunes is open, press and hold the sleep/off button (the one on the top of the itouch) until the slider comes up on the screen. Slide the slider to turn off the itouch. Now, press and hold the home button (the one right below the screen) and at the same time, press the off/sleep button again. Hold both until you see your itunes page bring up a "restore" feature. Unfortunately, when restoring, you will lose all data (songs, etc..) Hopefully, you have this data in itunes and can easily download it back onto your itouch. This is the only thing that works. Sucks that you lose everything, but at least your itouch will once again work....
Jul 22, 2009 | Apple iPod touch
When I put my earbuds into my ipod touch only one side works
i have the same problem. its not the headphones. its the itouch. its something to do with the jack-i think. because whenever i jiggle the plug eventually i can hear some of my music eventually. its a pain. and so how do i fix that ish?
Feb 14, 2009 | Apple iPod touch
Docked itouch emits song, but nothing through logitech speakers
Talked to both Apple and Logitech, and uploaded newest firmware ( had assumed since this was a recent purchase it had same), presto, it works.
Jan 29, 2009 | Apple iPod touch
Apple i touch 8 gb speaker not working
maybe u have the 1st gen itouch. the 1st gen itouch doesnt havent speakers. Your friend probably have 2sec gen which has speakers. If u look at each other's itouch carefully, u'll notice a slight difference near the edges. your friend's itouch's edge is probably curved like in the 2sec gen one while urs probably isnt.
This answer is my best shot at helping ya. Good Luck!
Shocker2cool
Jan 09, 2009 | Olympus Camedia D-425 / C-170 Digital...
Itouch loudspeaker, earphones?
No just the models with that feature have the loudspeaker. my girlfriends sisters ipod touch doesnt have it either. I hope that helps you out.
Dec 31, 2008 | Apple iPod touch
Itouch charging
Some speaker systems which are only compatible for charging the ipod nanos and classics do not work with the iPod Touch and the iPhone, the internals are slighly different from one another which will not allow that speaker system to charge your iTouch.
To play & Charge your touch, i suggest getting a speaker system that supports the iPod touch platform.
Hope this helps ?!
Oct 28, 2008 | Apple iPod touch
Apple iPod touch Logo
198 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
