Question about Brother MFC 420CN All-In-One InkJet Printer
Brother MFC-8820D Prints a COmpletely Black Page
I got no help at all from the Brother Tech Support Team.
The day after I installed a new Dell Computer, I was unable to copy or scan from my MFC-8820D. The machine prints OK from a computer, so the computer recognizes the MFC. It prints OK when a fax is received..
If I try to copy or scan a page on the glass surface, the result is completely black. I could understand if there were black lines, perhaps indicating a dirty scanner or glass or something like that.
I would appreciate any suggestions. I could not find anything in the manual, online FAQ, or Tech Support at Brother.
Thank you.
    Genius:
  • 2,120 Answers
You have a defective or disconnected SCANNER BLOCK
Posted on Mar 07, 2009
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
How to remove shadow on prints - Brother MFC-9840CDW
Call on Brother technical support number 1-800-243-0019 Toll free. And get Instant support for your Brother Printer from our Brother tech support team?
Apr 14, 2017 | Brother MFC-9440CN Laser Printer
Maintenance error 7 on a mfc 8820D
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have scanned through the appropriate sections of the
Brother MFC-8820D User Manual & Brother MFC-8820D SERVICE MANUAL
and find no referance to a "maintenance error 7". Please include any and all messages given on the panel LCD!
Please press the reply button and I will check back tomarrow.
It is always a pleasure to help!
Jun 15, 2011 | Brother MFC-8820D Laser Flatbel...
New computer is Windows 7 - 64 bit Printer is Brother MFC-8820D. Printer works fine - computer does not recognize the scanner feature of the MFC. Have tried both USB and LPT1 connection to the new...
I lost my network fax and scanning when I upgraded to Win 7 as Brother had no support for Win7 and this printer. Very disappointing.
However, I recently downloaded the MFC-8370DN install package from the Brother website and installed it on my Win7 64 bit Asus laptop. The installer couldn't find my MFC8820DN, but I manually entered the IP address (192.168.0.100 in my case). The install completed cleanly, after a reboot I can now start Brother Control Centre 3 and scan and fax from my 8820DN over the network. All good, no need to buy a new printer just yet...
Apr 26, 2011 | Brother MFC 8820D All-In-One Laser Printer
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
My machine displays on the LCD: "machine error 68"
First, I would recommend NOT trying to manually install this printer by using the add printer wizard in windows and selecting the the port and drivers to use. I would use the install cd to set this all up, it makes setting up this printer MUCH easier. If you are unable to use the install cd then get the IP address for the printer from your router admin page then with the printer "installed" go into the printer properties, go into the port, add a port, and instead of using a printer name just type the IP address for the printer in. Also for any networked printer make sure you don't have a firewall blocking it (this would include making sure that if the printer requires a port opened in the router that all requests for that port are routed to the IP address of the printer).
Jun 18, 2009 | Brother MFC-8820D Laser Flatbel...
Brother MFC-7420 prints black pages
The drum is defective. The cleaning blade has failed.
Jan 31, 2009 | Brother HL-2040 Laser Printer
Prints completely black page when copying.
hello! are you usinga brother oen toner and drum cartrdige? that is the first thing to try, you are welcome to post back to me for additional help good luck brother tech
Jan 22, 2009 | Brother IntelliFax-2820 Laser Fax
MFC 7420 ... I can't get the printer to print a test page after setting up a a new printer driver on a Windows XP edition with service Pack 3 in my Dell Dell Dimension E521
press the reports button and scroll down to the bottom where it says help page. print this page , it has all the help problems and what buttons to push. let me know, am brother tech
Jan 11, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother Scanner, scans the page but prints black and vertical
I called technical support for this issue previously with my brother mfc. It would only do this during color scanning. b&w scanning was just fine. The tech support put me through resetting the reference point of the scanner through a series of button pressing and closing and opening the paper feeder. I kept gettting the same lousy results. Then they determined that the scanner module needs replacing and I needed to take to the nearest service center.
Dec 23, 2008 | Brother MFC-8640D Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
229 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
