My printer will not print
My epson cx3200 will not print or copy or scan anything when we put as piece of paper in it to try it it justsend out the piece of paper blank all the time can you help me thanks
    Scholar:
  • 136 Answers
I have a feeling Your Scanner is Locked, Their is a scanner release switch , make sure the scanner swithc hasn't been moved, these move in away that they could accidentally lock the scanner when you remove paper and stuff.
Posted on Mar 08, 2009
Printer noise
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 25, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
I have an epson CX3200 about 4 years old. If I do
get a bright flashlight and look for tiny bit of paper, hair or other object.
If you see nothing to remove, try blasting the paper path with compressed air.
Feb 04, 2010 | Epson Stylus CX3200 All-In-One InkJet...
My printer not printing at all- paper just rolling out with scant
if you haven't used the printer for a while before you discovered the bad print quality, the print head has most probably completely dried out. i don't think there is anything you can do about that, except for replacing it better having it replaced by an authorised technician.
Jun 08, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Producing blank pages
repeated nozzle cleaning (6 times) which almost emptied the cartridges but it is now printing
Jan 03, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 ( loud noise like paper is jammed) error message comes up.
By pulling the paper out backwards your sister may have caused a gear to jump. You could try pulling a piece of paper out in the other direction and maybe the gear will jump back into place. Otherwise you will probably have to have the printer serviced.
May 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
54 people viewed this question
k24674
jasbo
jasbo
