Question about Dometic RM2652 Refrigerator
My dometic 2652 runs is not cooling on gas or electric .inside switching seems to function properly .heater is engaging. any suggestions?
  • Anonymous Mar 09, 2009
    We have a RM4400 and on a recent holiday noticed that it was equally ineffircient on both gas and 240V not cooling below about 10oC even overnite without being opened for 8hrs.
Is there a yellow powder substance on the coils, heating tube or anywhere towards the bottom? If so, you have a leak. The best thing to do is:
1-Find a replacement unit online( ebay is a good place to start)
2-unhook electric line and gas line from the access panel
3-remove the refrigerator from the inside and place doors down(its heavy and you will probably need another person to help)
4-remove cooling unit from back of refridgerator
5-make sure you have enough thermo-mastik for the unit/coil contacts
6-replace cooling unit and hook up everything in reverse
7-turn on and let it cool for a few hours. My unit stays below 32F and works great.
Found the first one listed on ebay just now for $399.00 with a five (5) year warranty.
Posted on May 27, 2009
  • 93 Answers
Depending how old your frige is first is it in a trailer is your trailer levell then sometimes you can remove your fridge reverse it upside down to bring he gas to its receiver or yoy may have a leak most of theese fridge if they are to old will need to be replaced cause they use amoniac witch is not legal to use anymore no one can fix it if is amoniac but try this first by fliping it then retry .i have done it several times it works 50 50 chance thanks from gilles
Posted on Mar 15, 2009
Question: I have a trailer camper it has a Dometic Rm 2652 Ameri. refrig.
If I remember right on those, the system works off 12 volt--120 volt-- or propane (LP gas). have you tried one of the other power source to run it off of?? If you get the same type cooling results the problem is probably a small leak in the freon system. Those use special internal gas. When I worked for GE the only way to fix them was to replace the complete cooling system which came pre-charged with the special internal gas. Quite expensive after the warranty. Now if you switch power source and one of the other sources make it work the problem will be with the type power you were using when it failed to cool properly. Many people that had system problems with those camper type refrigerators removed them and installed a small regular dorm style refrigerator that could only be run off a 120 volt power system. You would need a 12 volt to 120 converter to run it while on the road if thats what you want to do.
May 01, 2015 | Dometic Refrigerators
Dometic rm 2652 refrigerator will not cool
if voltage to unit remove thermistor let run if ok replace thermistor if not see if chimney hot if not heater element if doesn't work on LP bad control board
Nov 18, 2013 | Dometic RM2652 Refrigerator
Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
May 26, 2012 | Dometic RM2652 Refrigerator
Hello, my dometic camper fridge runs great on gas but just clicks when i switch it to electric...??? any advice thanks Stephanie
The mains heater has a different thermostat. Check power to the heater, and the back coil is getting warm
Apr 27, 2012 | Dometic RM2652 Refrigerator
My dometic refrigerator unit is not cooling properly on gas or electric. The freezer gets cool but the fridge stays warm. What could cause this?
my domestic refrg will not work on electric but will lite on gas. freezer will get cold on gas but bottom will not cool.you can plug refrg in and it will kick the gas off. you unplug refrg on gas will lite.that part of the power board seems to be working.
Apr 17, 2011 | Dometic RM2652 Refrigerator
I have a Dometic RM 2652 LP gas/electric its hooked up to 120V but no gas. will it cool if so how long will it take to cool and how cold is it suppost to get it
I just saw where they have a recall on this model Dometic Refrigerator RM 2652. If you go to the www.Dometic.com and find the recall info you can type your Model and Serial Number into the boxes and see if your model is one of the ones recalled. Don't know if this link will work but try it first and it will bring you straight to that box I am talking about on their website. Its http://67.238.126.140/recall.php, if not go to the one above and find the recall information. Hope this helps.
Sep 12, 2010 | Dometic RM2652 Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
958 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
