Question about Microsoft Computers & Internet
Host Header, IIS 6.0 not resolving correctly on LAN
I need an IIS and DNS Server expert on this one.
I have an intranet site on 2003 Server in my office. For several months it has been serving up pages internally to our office. Now, I've added a 2nd site on the same IIS server, and set up Host Headers so that both sites can use port 80. The Server Name is CPU1460, so with the Host Headers in place, the new URLs to get to the two sites should be:
Issues.CPU1460
BusinessServices.CPU1460
To make this work, I set the server up to be a local DNS server, and added both of those Host Header names to the forward lookup zone.
Now, what's happening when I try to access the server from a remote client machine, the URL Issues.CPU1460 is resolving to http://www.issues.cpu1460/
What did I miss in setting this up?
  • 21 Answers
Have u add entries for CNAME & A record?
In IIS manager select the website and go to properties->go to documents tab and add file with .html
Posted on Mar 11, 2009
Tip
Server 2003 & client configuration
<p><span>Some days before I have done a job on Windows Server 2003 Enterprise edition & Client XP. It is departmental food court. In the office room of the restaurant have a system which will be Server system and main domain. There was another 8 system in every department of food <span> </span>with printer for billing.I</SPAN><br> <p><span>Windows Server 2003 includes a mission critical Windows Server operating system, such as security, reliability, availability, and scalability.</SPAN><br> <p><span>You have to install DNS server for DC without DNS the client computers wouldn't know which one is DC.You can host DNS on a different server than DC.</SPAN><br> <p><span>Before Starting the DC installation process you need to make sure the <span> </SPAN>following points</SPAN><br> <p><span> </SPAN><br> <p><span>1)You have installed Basic windows server 2003 installation</SPAN><br> <p><span>2)Make sure you have assigned a static ip address to your server</SPAN><br> <p><span><span> </SPAN>Now start DC and DNS Setup process</SPAN><span></SPAN><br> <a><span> </SPAN></A> <span><span>Domain Controller</SPAN></SPAN><span></SPAN> <span>Active Directory is a huge topic in itself. While DCPROMO is easy to run, planning of both the physical and the logical structure is the key to a trouble free active directory. </SPAN> <p><span>Domain controllers do not have to be your most powerful machines, however they must be reliable and always available to answer logon requests. </SPAN><br> <a><span>DNS (Domain Name System)</SPAN></A><span><span> </SPAN></SPAN><span>Role</SPAN> <p><span>Once DNS is setup, it runs itself thanks to the new dynamic component hence DDNS. TCP/IP knowledge plus understanding of how DNS works is essential when troubleshooting connectivity problems.</SPAN><br> <p><span>DNS enables client machines to resolve servers IP addresses. Once the client finds the server, Active Directory uses LDAP to locate services like Kerberos, Global Catalog that clients request.</SPAN><br> <a><span>Print Server Role</SPAN></A><span></SPAN> <p><span>In my experience there is a contrast between the software settings which are easy to configure and the hardware which constantly need for attention e.g. paper jam, 'out of toner'. Check list for print server:</SPAN><br> <p><span></SPAN> <br> <p><span>Printer Priority</SPAN><br> <p><span>Network Printers</SPAN><br> <p><span></SPAN><br> <p><b><span>Client Configuration :- </SPAN></B><span>After</SPAN><span><span> Installation of Windows Xp give the IP Add on TCP/IP of IPV4.If you want to manually configure DNS server addresses, click</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Use the following DNS server addresses</SPAN></b><span><b><span>,</SPAN></B></SPAN><span><span> and then type the preferred DNS server and alternate DNS server IP addresses in the</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Preferred DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>and</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Alternate DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>boxes. After all job try to ping each other. I'm trying this and it also pinging. Files and data also can be shared through it.</SPAN></SPAN>
on Feb 15, 2011 | Computers & Internet
When i go on the internet it says host not found
Hello, I am using this site's domain name and hosting for my website ,here i am faced these kind of problem, you may use this http://www.tucktail.com/ site's DNS,here your expected domains available .visit here for more details.
May 18, 2010 | Computers & Internet
Am trying to set up a Windows 2003 server to serve web pages over the Internet. Have got a DSL line from Embarq. They installed a EQ-660R interface which is really build by Zyxel. I can reach the Internet...
In order to access your default web page remotely, port 80 "INBOUND" must be open to the internet.
To access your web server, two things need to happen.
The first is you or someone else must initiate a http request on port 80 using the public IP Address of your DSL connection.
Second, your router must forward that request to your servers internal ip address.
Ex. Lets say your public ip address is 24.39.45.10. In a browser window from a remote location, you enter the URL http ://24.39.45.10 The request will be sent to your router on port 80.
Your web server will not have the ip address 24.39.45.10 because it's on the private network side of your router. So, lets say the private ip address of you server is 192.168.1.100
You need to configure your router to take the http request coming from the internet on port 80 to ip address 24.39.45.10 and forward that request to 192.168.1.100. This is known as port forwarding.
You also need to configure the host header name of your "web page" so it knows it needs to display the web page.
Since we're just using ip addresses in this example and not an actual FQDN (fully qualified domain name), you would make a host header entry for the web page of 24.39.45.10.
To do this open IIS.
Navigate to the web site in question and right click on it then select properties.
On the website tab, ensure the port number is set to 80 and choose the appropriate internal ip address if you have more than one network adapter in the server.
Next click on the advanced tab and look for the heading Multiple identities for this site. This is where you enter the ip address 24.39.45.10.
If you have a fully qualified domain name, you would enter the domain name instead of the ip address as specified in this example.
Host header names are the key to running multiple websites from one physical server as long as it has the necessary horsepower to do so.
Hope this helps and isn't confising. If you're confused in any way, don't hesitate to ask for clarification.
Sep 13, 2009 | Zyxel P-660RU-T1 ADSL Ethernet/USB Router...
I can't scan.
The Scanning feature must resolve the name you have entered into the host location in the one touch screen. If the system is not able to resolve the name to an address it will fail. The easy way out of this is to enter the destination IP address. The hard way is to fix the reason the printer can not resolve destination name to an Ip address. That will require fixing a DNS problem on your network
Mar 27, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
My website on my network open the netopia router page
You need to somehow setup the internal DNS to route all requests for the specific domain name, to your internal website.
Or, setup the netopia to allow loopback connections.
If you have a 2003 Server OS, chances are that the server is handling DNS requests, at least internally.
This tutorial has a good example of how to create domains internally:
http://www.simongibson.com/intranet/dns2003/
Just a couple of tidbits when using this approach:
You will essentially be controlling the DNS for the domain internally anyways. Meaning, any subdomains, mail exchangers etc., for the domain will have to be configured as well.
Good Luck.
Feb 26, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
How to configure domain
You need to install and run IIS or Apache...they are both web server programs. It doesn't really matter which you use, more of a user preference.
In my case I like to use IIS with Server 2003. Below is a link that is a full guide for setting up your server to host a website. it is step by step and includes pictures along the way. It should have you running in no time!
Step By Step Guide
Feb 23, 2009 | Microsoft Windows Server Standard 2003 for...
Hurricane h5200 modem/router
Hello jmazaredo,
Does your DNS server have your server fqdn in its tables, and does your PC have the address of your DNS server in its lookup table?
One test you can do is to use the hosts file to put the fqdn into and assign it an address this would let you know the the PCs can use host tables to do the translation then this becomes a DNS issue as opposed to a lookup issue and you cut your troubleshooting in half.
In other words edit your hosts tables (hosts file) with the entry (Example 1):
IPADDRESS FQDN ALIAS
192.168.10.2 somesystem.myhome.com. system
192.168.10.5 somesystem2.myhome.com. system2
This as stated will determine if you have a DNS issue or a lookup issue, because the DNS system will use host tables first and the do a DNS lookup.
Once this is done if it works then try this setup:
1) in your router set the DNS to capture the DNS of your ISP (normally the setting will tell the router to use the DNS given to it by the DHCP protocol.
2) turn on DHCP on the LAN side of the connection in the router and set the controls for proxy DNS service (using the router as the local DNS server also called caching DNS server), However set the router up to allow static IPAddreses and if possible to recognize the domain name of the local LAN.
3) set your servers up with static IP addresses and in their host tables set the fqdn up as stated above in Example 1
4) in your PC set the DNS to be the IP Address of your LAN side of your router i.e. 192.168.1.1 and if needed set the host tables of all PCs to the server addresses, fqdn, and aliases this way if DNS fails the system will at least have the host tables to use.
I hope this helps.
Thank you,
Shuttle83
Aug 14, 2008 | Computers & Internet
Asp
Hi, Have you checked your security permissions on the 2003 IIS ?
Are the users using it as Intranet or Internet?
Is the site internal/external or possibly firewalled with rules restricting correct port operation and access permissions?
x-b-m
Feb 19, 2008 | Microsoft Windows Server Standard 2003 for...
Open Questions:
What is Microsoft office applications? Microsoft office is a set of interrelated desktop applications, servers, and services, collectively referred to as an office suite, for Microsoft Word: a word processor included in Microsoft Office and some editions of the now-discontinued Microsoft Works Microsoft Windows and macOS operating systems. Microsoft Excel: a spreadsheet. Microsoft released the first version of Excel for the Mac OS in 1985, and the first Windows version (numbered 2.05 to line up with the Mac) in November 1987. Microsoft PowerPoint: a presentation program used to create slideshows composed of text, graphics, and other objects, which can be displayed on-screen and shown by the presenter or printed out on slides. Microsoft Access: a database management system for Windows that combines the relational Microsoft Jet Database Engine with a graphical user interface and software development tools. Microsoft Access stores data in its own format based on the Access Jet Database Engine. Microsoft Outlook: a personal information manager that replaces Windows starting in Office 97, it includes an e-mail client, calendar, task manager and address book. Microsoft OneNote: a notetaking program that gathers handwritten or typed notes, drawings, and audio commentaries. Notes can be shared with other OneNote users over the Internet or a network. Microsoft Publisher: a desktop publishing app for Windows mostly used for designing brochures, labels, calendars, greeting cards, business cards, newsletters, website, and postcards. Microsoft Project: a project management app for Windows to keep track of events and to create network charts and Gantt charts, not bundled in any Office suite. Microsoft Visio: a diagram and flowcharting app for Windows not bundled in any Office suite
Dec 28, 2017 | Microsoft Computers & Internet
Computers & Internet Logo
402 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
