Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Rear fan reinstall
Wich way does the rear fan go back in housing, one side has yellow lable, is fan suppose to blow back or forward?
  • 294 Answers
THE FAN SHOULD BLOW AIR INTO THE T.V. FOR THE FAN MOUNTED ON THE BACK OF THE T.V.
Posted on Mar 07, 2009
How do i remove the housen to clean the fans
If computer case tower housing you normally remove screws around perimeter at back then slide the covers back a little bit to unhook from chassis.
If not please elaborate.
Nov 27, 2017 | The Computers & Internet
How to change the belt on dryer
CHANGING THE DRIVE BELT
1. Remove the top cover and the rear panel.
2. T720/780: Remove the external fan housing.
3. Remove the special tool.
4. Remove the belt from the belt pulley and take off the belt.
5. Feed the belt over the drum onto the motor shaft and over the belt pulley.
6. Install the special tool.
7. T720/780: Replace the external fan housing.
8. Replace the rear panel and top cover.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
25758001-gtkp3url2ghtdqenstp5bokb-1-0.jpg REMOVING THE REAR PANEL
1. Remove the top cover.
2. Unscrew the centering nut until the face of the nut is level with the end of the thread and knock out the bearing.
3. Fit the special tool (part no. 88 011 54) by fitting the tube end into one of the stamped out keyholes in the front rail. Lift the rear edge of the drum and press the drum edge onto the roller.
4. Remove the ground connection (yellow/green wire) from the input terminal block (see pages 8 and 9).
5. Take the cable bundle out of the cable clamp and pull the header block off its terminal pins.
6. Remove the wiring:
T700/T720: R1 a, R1 b, R1 13, R1 14, R1 34 on the contactor.
T760/T780: Ra, Rb, R13, R14, R34 on the contactor and F3 and F4 on the radio interference filter.
7. T720/T780: Remove the hoses to the water tank housing.
8. Remove the centering nut and the eight screws.
NOTE: Do not remove or loosen the screws around the heater housing or drum bearing.
9. T720/T780: Remove the three plastic screws at the lower part of the rear panel.
10. Lift off the rear panel.
25758001-gtkp3url2ghtdqenstp5bokb-1-5.jpg 25758001-gtkp3url2ghtdqenstp5bokb-1-20.jpg
25758001-gtkp3url2ghtdqenstp5bokb-1-27.jpg REMOVING THE EXTERNAL REAR FAN HOUSING
1. Remove the top cover and rear panel.
2. Unclip the external rear fan housing suction side.
3. Unscrew the 10 mm nut on the external rear fan wheel and remove it.
4. Lift the external rear fan housing motor side and pull it toward you.
Dado
Jun 23, 2015 | Asko T701 Electric Dryer
Where is the expansion valve located on the 2004 KIA Sedona
Kia Sedona expansion FRONT valve located under dash, behind glove box, fan and coil. Evacuate freon first. Disconnect Freon lines from firewall., Lay right front seat back to flat horizontal position and lay on top or totally remove the seat for easier working access. Remove under dash cover, fan, glove box, coil housing, remove coil mounting bolts, remove old expansion valve. (Inspect old valve, if debris inside, blow out coil before installing new valve. If visible debris best to consider replacing REAR expansion valve and DRIER/FILTER in front of radiator too and blow out all lines and coils while servicing.) Use compressor oil to lubricate "O" rings on new FRONT or REAR expansion valve, install valve bolts, reinstall coil bolts to FRONT firewall or REAR frame, reconnect freon lines to firewall in engine compartment. Evacuate AC system, install freon (35 1/2 ounces, nominal 3 pounds), check system for leaks, check for proper operation, enjoy.
Sep 12, 2012 | 2004 Kia Sedona
How to reinstall fan after cleaning?
The fan should more than likely be blowing air out through the back of a desktop PC. I haven't seen a fan blowing in when it's installed in the rear. Most fans have arrows that tell you which direction they blow, if not plug it in and test it :)
May 05, 2012 | HP Pavilion a1410n (ER890AA) PC Desktop
Hi i just bought 3 chassis fan and i installed 2 on top and 1 rear... there is already one installed in the front when i bought the case....i want to know wich direction i have to put my 3 chassis fans (2...
Case fans tend to blow in the air out of the side of the fan which has the four plastic bars and normally the sticker. The fan may also have a set of arrows describing direction of rotation and flow of air.
May 18, 2011 | Computers & Internet
Hi there...i'm having a little problem installing my pioneer avh-p6600dvd unit...couple questions. I can't seem to identify the accessory line for the unit what color is it? Do i still need the brain even...
on the back end of the deck there are a series of wire thats attached to a push-in plug.you will find:
plain yellow-wich goes to permanent live(12-14v)
red -wich allso goes to permanent live(12-14v)
black-wich goes to ground/earth
light green-wich goes to ground/earth
blue and white-wich goes to the ignition wire of your vehicle(remote)
2 x green(rear speakers)
2 x purple(rear speakers)
2 x white(front speakers)
2 x grey(front speakers)
Mar 06, 2011 | Pioneer AVH-P6600DVD Car DVD Player
The panel between the two doors are heating up as well as on side panel of freezer. The freezer is only cooling down to -8 deg Celsius. The door is closed properly.
you need to check the condenser fan motor located in back of the refrig behind cardboard cover. most likely the motor is bad or something is obstructing the fan from turning. also be sure the coil under the unit is clean as well. temporarily you can place a house fan blowing in the rear of the unit to keep it operating normally until you get it repaired.. peyton
Jan 25, 2009 | LG LRSC-26922 Side by Side Refrigerator
Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Dec 20, 2008 | Dell Dimension 2400 PC Desktop
Hot refrigerator
Jul 14, 2008 | Whirlpool ED2FHSS Side by Side...
1997 dodge grand caravan a/c
What are the readings on your A/C service gauges, hi and low sides? If you don't have service gauges, inexpensive ones can be purchased at stores like: Harbor Freight, Walmart, Pep Boys, etc. The gauge readings are the first step to a correct diagnosis.
Your system may be low on refrigerant. If you also have a rear heating unit, the air mixing door or water valve may not be shutting off. Your expansion valve may be bad in the rear unit.
If you can access your rear a/c, check to see if the inlet hose is hot or cold. If it is cold, you are low on refrigerant. If it is hot and the tube coming out of the expansion valve/orifice is cold, this is the way it is supposed to be. If the tube on the outlet of the evaporator is not cold, then you are low on refrigerant or the expansion valve/orifice may be bad.
Jun 08, 2008 | 1997 Dodge Caravan
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
