Question about HP Pavilion dv9000z Notebook
Thanks to Rai55 at solution 11 for his EXCELENT solution.My dv9000 is running fine now.
The service engine soon light is steady on, but the car is running excelent. what should I do?
You should check the engine oil level and the coolant level. Top them up if they are low. If the light stays on take it somewhere to get the codes read.Go from there. Hope this helps.
Aug 23, 2011 | Mitsubishi Lancer Evolution Cars & Trucks
I have a HP dv9000 with some Problems
over heating if you have amd cpu there is know issue call hp and they may fix it for free
Nov 10, 2009 | HP Computers & Internet
I have a Hewlet Parkard desk top that bleeps
dv2000/dv6000/dv9000 recall I have an out of warranty dv9000 and haven't had wireless for months. I just discovered HP issued a recall for the wireless and other problems with several different Pavilion and Presario models. For the wireless problem with the dv9000 they are replacing the motherboard on all notebooks in or out of warranty. I was wondering if anyone has had the repair done under the recall and how it turned out? I'm also wondering if HP is still cosmetically trashing notebooks when they are sent in for repair?
Here is the link for the recall:
http://h10025.www1.hp.com/ewfrf/wc/d...842189&lang=en
Nov 01, 2009 | HP Pavilion dv9000z Notebook
I have a 3 year old hp pavilion dv9000. For 3
Quite often this is caused by someone changing the display type. There should be a function key control that allows you to view just your lcd display, an external display, or both. Try and change that setting and see if it will resolve your issue.
Jul 20, 2009 | HP Pavilion dv9000z Notebook
HP dv9000 display works fine on battery but not AC
It's either the motherboard or the power supply.
I'd start with testing the power supply. If you've got a multi-meter great. Just measure the voltage and see if it fluctuates.
If not, check with a local repair shop to see if they have a power adapter they could use to test with.
Jun 17, 2009 | HP Pavilion dv9000z Notebook
Picture too dark
Capacitors on the Ysus is bad. Buy a new Ysus board or change the 14 components on it from a repair kit
Feb 27, 2008 | Televison & Video
HP Pavilion dv9000z Notebook Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
