Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Lamp cover melting
I am replacing the bulb in my Sony KDF-42WE655 and happen to notice that the cover for the lamp in melted. No signs of burning, smoking, smoldering, but definitely some heat issues.
Any ideas why this is?
  • wallykris Apr 20, 2009
    Thanks for the info. Will try this.
  • Anonymous Mar 30, 2014
    what is lamp model number
  • 5 Answers
Open the back case (about 10 screws) and clean the lamp cooling fan. This is NOT the one you can see from the outside. It is located in a horizontal position above the lamp area from the rear. A DRY toothbrush can be used to brush out the dust. Keep a vacuum nozzle next to it while cleaning so the dust does not go inside. Some say to use compressed air to blow out the dust, but vacuuming it keeps better control and can prevent unwanted dust from moving down into the optics.
I learned this the hard way when replacement lamp burnt out in one week. I thought the cooling fan that you can see from the outside (it actually is the exhaust fan) was the only fan. The lamp cooling fan sucks in cool air and puts it right down onto the lamp.
Test the fans by turning on unit without lamp installed (the fans will power on for a short period of time and you can see them function to verify airflow). Clean this fan once a year as the dust will be back.
Posted on Apr 20, 2009
Its a warranty issue that Sony is aware of. They are replacing it and any other needed repairs until March 2010. Here is a link to the Sony site for more information.
http://esupport.sony.com/US/perl/news-item.pl?mdl=KF42WE610&news_id=261
Posted on Apr 25, 2009
My lamp cover melted and now i get the 3 blinks of the red light...i have searched and searched but can not find a replacement cover anywhere...the model is a KDF-42WE655 and the number on the cover is...
Google to this website Encompass Parts Distribution and type in your model # they will list parts and prices with PNumber
they have what you are looking for.1-800-638-3328.
Mats Electronics Has Lamps for 99.00 1-800-628-1118
Sep 15, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Where is the bulb loacated on kdf42we655
Bulb/ lamp is located under front lower panel that need to be removed. There are two thumb screws on lower corners of front screen if you see tv from rear, remove these screws and take off lower front panel, you will see lamp cover, remove it to see lamp.
Lamp replacement procedure is written in user manual with exploded views. Click Sony Support to download free copy of user manual of KDF-42WE655 for more details.
Jun 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Lamp replacement Sony KDF-42WE655 TV
Don't do anything to this TV. Per the Sony web site and VERY common to this model is overheating. Follow the given link and contact Sony for extended warranty information on this model.
http://esupport.sony.com/US/perl/news-item.pl?&news_id=261&mdl=KDF42WE655
Mar 02, 2010 | Sony KDF-42WE655 Television
I have a sony wega kdf-42we655 that keeps blacking out and loosing sound and comes on a few minutes later. the stand by light seems to flash around 38 times during the process. please assist
I believe you need the Lamp to be replaced. It is a very common symptom. Call Sony at 1800-222-SONY and they can send you one. I think it will run around 185.00 to 200.00.
I recommend to use only a Sony Lamp and not a After- Market Lamp because they have been known to be unreliable and not rated properly causing melting issues around Lamp area.
I hope this helps,
Skyassoc
Sep 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do I replace the Projection Bulb on a Sony KDF-E55A20 and what where do I get the replacement bulb the cheapest....I have pulled the module...
It is my recommendation that you replace it with a Sony Lamp Assy. Do not go cheap buying a generic or just the lamp only. They have been known to be unreliable and the wattage to be wrong causing the surrounding plastic to melt. Sony will not be responsible for this if it happens. If you have pulled the Lamp Assy. out, just put the new Lamp Assy
in it's place. Be sure to remount the lamp cover properly. Remount the outer cover and you are good to go.
You can contact Sony at 1800-222-SONY
for the lamp.
Hope this helps,
Skyassoc
Jun 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Projection lamp casing melted.
This will be covered covered under warranty by Sony. If you will call 800-282-2848 you can locate a Sony authorized servicer that should be able to repair this at n/c.
Feb 09, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bulb Replacement for Sony TV KDF-42WE655
no you should only replace a bulb with the one made for that brande t.v. you should put in a sony xl-2400 in your sony t.v. and yes you should get both housing and bulb in 1 i bought mine off ebay for about 116.00$ both lamp and housing very easy to replace good luck also if you have a sony kdf-42we655 or 50we655the lamp part # is xl-21oou or xl-2100
Jan 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-42WE655 Replacement Lamp
First thing i would ask is where is the smell coming from?
Jan 26, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
949 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
