Question about NAD C521 CD Player
It does not sound like the Motors is running
It does not sound like the MOTOR is spinning. When I put in the CD it goes in and nothing happens. Any suggestion is appreciated.
Alvin
  • pasedena32 May 11, 2010
    Is it making any noises at all? there should be a 'clicking' noise as the laser tries to focus....
    Genius:
  • 1,175 Answers
Hi...
I've done work on these .
You need to replace the drawer belt. This requires that you remove the CD assby. The belt is under a thin plastic cover at the front of the CD assby
SBM 3.0 belt at studiosoundelectronics.com
or similar at MCM electronics.
Posted on Mar 19, 2009
    Genius:
  • 1,550 Answers
Clean the laser lens
Posted on Mar 06, 2009
Door won't open, carousel won't spin, buttons light up but nothing happens. If the carousel is out of alignment, how can I fix it?
U have separate motors for the door opening and closing as well as the carousel spinning. Chances of both motors going fubar at same time is nil. .What do they both have in common? Yep, power supply!!!
Feb 03, 2016 | Audio Players & Recorders
The power comes on; however, nothing happens. We took the cover off and nothing happens. We hit :"open/close" and nothing happens, no spinning sounds, nothing. What can be wrong? Where can we...
Looks like the motor is Shot, Don,t evan waste your time to take it in to get repaired, It will cost you more, then to just get a different one, I have got good use ones for friends of mine for $7. to $30, at the most,
Nov 10, 2012 | NexxTech N500D 5-Disc
TECHNICS SL HD81 5 CD MULTICHANGER. The multichanger, when a disc is put into any of the five slots, doesn't sound like the disc spins - almost as soon as the draw is closed, NO DISC appears on th
The motor is shot,Or the gears are jamming up in it, Just look for a different one, It will cost you more to have it repaired, I have got good used disc (Players) For $10 to $40 at the most for friends of mine,
Nov 04, 2012 | Technics Audio Players & Recorders
My MegaStorage Sony CDP-CX250 won't play any CD. The carousal turns to loading position, the cd is loaded, but nothing more happens. It can't spin at all. The CD is then unloaded again. The...
I would check the drive is not blown, as that is what sounds like has happened
take a 5v dc feed and run two wires to the motor to see if it spins up ,if it doesnt spin replace the motor , if it does spin then the problem lies else where in the circuitry
Jun 25, 2011 | Sony CDP-CX250 CD Player
CDC-655 was put in storage (in orig box) and brought back out and plugged in. It loads each CD and fails to read each one. The lighted numbers go out, one by one, as it fails to read them.
This seems to be a "Dust on Lens" problem. No issues... It happens when you keep your CD/DVD players unattended for a long period of time. Even if packed well enough, dust/moisture does tend to gather on the lens and cause this type of an irritating problem.
If you have a lens cleaning CD (if not, go buy one) then just insert it and let it spin regardless of whether or not it reads it. The spinning action will clean off any finely deposited dust particles on the lens. Repeat th process till the Lens Cleaner CD starts playing its audio. If this happens then all your other CDs should read. One more thing, make sure that the motor is indeed spinning. How can you know???
1. Buy listening carefully for a whirring sound the moment you put in your CD/DVD
2. By feeling for minor vibrations on the front panel (CD tray front cover)
3. Putting in a CD/DVD with a label straight as you can read it and see if it comes out differently on ejecting it. I hope you understand what I mean...
If this doesn't then it could be a blown lens circuit or a dead drive motor. In that case your player needs to be taken to a service center.
Hope it answers most of your query. Good luck.
Nov 05, 2010 | Yamaha CDC-655 CD Player
I have a numark cdn 88 just change the transport assemble but the cd wont spin and give me no disc on the display
Chances are that you didn't reassemble the unit correctly or damaged a ribbon cable or limit sensor. Re check your work. Pay attention to small circuit board attached to the spin motor RF310T-11400. De-solder the small circuit board on the 2 motors..and apply 12v to the spin motor. See if it spins with no dead spots on start up. when asseembled, motor will only operate and spin up to the proper RPM only if loading is successful and tray is fully closed ..etc. Hope this Helps. I have a CDN-88 in my shop for skipping issues on both CD players. so I saw your problem here while doing research. Good Luck,
Thanks, Dillon, Trace Electronics, Barrie, ON, Canada.
Jan 20, 2010 | Nu Mark Audio Players & Recorders
Cd player doesn't work
This is doc-fix. The C D motor is supposed to spin spin, at all times when selection. then the C D record makes selection.
in that sequence.
See if motor spins by finger twirl? Is it turn 3,or 4 turns?
if it is binding on the black plastic, then that has to be corrected. if the motor is getting no power (electric power)
then there will be no spinning. need a diagram , showing how
motor power goes into the C D HEAD TO MEASURE VOLTAGE???
IN-HOME JUKEBOX REPAIR 6362273300
Apr 27, 2009 | Audio Players & Recorders
CD PLayer won't play CD's
Hi First of all, you must find all the screws for the top cover and remove it. Make sure the unit is not plugged in! Then, making sure that you are not touching anything inside the unit, plug it back in,put a Cd in the drawer, and watch what happens. If the drawer closes, but you can still hear a motor running, then it is a belt drive unit, and the belt is slipping, if that part is ok, listen carefully for a ticking noise, which is the laser lense going up and down trying to focus on the CD, if the disk starts to spin then the mech has closed properly, and the unit is trying to find the directory. If the unit then spins the disk for a while then ejects it, then the laser is dirty or faulty. I would suggest getting it cleaned at a shop if the lense appears dirty. ***Never look straight down at the laser lense if it is exposed on your model of CD player, it is a class 3 laser, and you will be doing some harmful home laser surgery to yourself!!!*** Hope this helps! Good Luck! P.S. When following the steps above, if you hear the ticking of the lense moving up and down, but the disk does not spin, gently spin it clockwise with your finger, if it starts to play, or finds the directory, then the spin motor is bad.
Aug 13, 2006 | NAD L40 CD Player
NAD C521 discs not spinning
The CD player has a sensor that is supposed to detect when a disc is inserted and spin it up etc. yours might be the problem, either it has some loose connections (that you haven't noticed) or it simply misbehaves. Another thing could be the motor itself that somehow 'misses' the spin up signal and needs a 'manual' boost. The best solution in your case is probably to bring it to some lab.
Sep 14, 2005 | NAD C521 CD Player
NAD C521 CD Player Logo
151 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
krisefisher
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
