Question about Nikon Coolpix 5700 Digital Camera
Flash will not pop up when you turn camera on.
Can you help
  • 60 Answers
That is correct: and it never will !.
For the very reason that it has no automatic pop up function....................
Press the knob on the lh side of the flash and it will, if you have a manual you might want to read it.
It would help.....................
Posted on Mar 06, 2009
Nikon D3100 won't flash
If you have set the main dial to the green camera logo, with automatic in bad light, and the flash still does not pop up, you could start worrying. The mail mode dial is very easy to turn, even without knowing. It happens to me more often than I would like. My next camera must have a special button to lock this dial.
When you chaco the manual, you will see there are settings the flash won't pop up and even when it is up it won't flash, because that menu excludes the flash.
Jan 12, 2014 | Nikon D3100 Digital Camera
Nikon D40. How do i force the flash to work in daylight?
First, you have to be in one of the PSAM modes; in the other modes the camera decides whether it needs the flash and in daylight it will decide there's enough light without it. So, after turning the model dial to one of the PSAM positions, press the flash button on the front of the camera to pop up the flash. In these modes the camera will fire the flash if it's popped up, and not if it's down.
To change the flash mode, hold down the flash button (after it's popped up) and turn the command dial. Depending on the chosen exposure mode, your choices may include Fill flash, Red-eye reduction, Rear-curtain sync, Slow sync, Rear-curtain plus red-eye reduction, and Rear-curtain plus slow sync. Refer to the "Flash Mode" section of the manual for full details.
Jul 30, 2011 | Nikon D40x Digital Camera
I am getting this message on my EOS 450d, (camera's built in flash pop up was obstructed turn the power switch to off and on again). I have done this several times the flash wont pop up - can you please...
Sometimes the pop-up flash on the EOS range of cameras can get stuck. The EOS family have a very tiny micro switch under one blade of the flash hot-shoe.
Get a toothpick and manually pop the switch. It should clear your error, too.
Good Luck.
Mar 28, 2011 | Canon EOS 450D Digital Camera
DSC H-5 the flash pops up but does not flash, camera is set to automatic mode and flash is turned on.
Flash pops up shows that flash release mechanism is working as camera wants to flash.
There are 3 thick wires connecting between flash bulb and flash charging circuit in camera, one of thick wire seems internally broken and causing problem.
Camera will be apart to check wires.
Let me know, if you are willing to apart camera, for further help.
Thanks.
Dec 31, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Flash not popping up
This model does not have a manual flash pop up release, so if the flash is not needed, it won't pop up at all. Use the "flash" button on the back of the camera to set: fill, forced, disable, etc. flash settings.
Jul 05, 2009 | Fuji FinePix S700 Digital Camera
Canon Camera Rebel XTi reads error 05 and the flash will not pop up
Err 05 means: Something obstructed the built-in flash's pop-up operation. Turn off the main switch and turn it on again.
Prepare to press the flash request button with your left hand. With your right hand, position your thumb and finger to gently pry up the flash head, perhaps using fingernails. Push the button and pry. With that help, it should pop up.
Dec 20, 2008 | Cameras
Pop up flash nikon D80
There is a small hex screw on the underside of the flash pop up... next to the latch. I gave it a half turn and presto... fixed...
Jul 07, 2008 | Nikon D80 Digital Camera with 18-135mm...
Flash
This is the AF Assist feature. If you don't have a hot-shoe flash mounted, but you do have the pop-up flash raised, the camera will strobe the pop-up flash in low-light situations to provide illumination for the auto-focus to work. You can disable it by turning off the AF ILLUMINATOR option in the "Wrench 1" settings menu.
Mar 09, 2008 | Olympus EVOLT E-500 Digital Camera
Pop-Up flash - Rebel xti
You will need to send the camera for servicing. There's a lever mechanism inside the flash unit which is responsible for popping up the flash. Since it is a mechanical device, it is sometimes prone to failure. I suggest not to put manual pressure to force the flash to come out, as it may cause permanent damage. Instead, send the camera for service.
Dec 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Built-in flash auto pop-up problem
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
May 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
78 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
